Canon Support for PowerShot G12 | Canon U.S.A., Inc.
PowerShot G12
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
10.0 Megapixel, 1/1.7-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 10.4 Megapixels
Effective Pixels
Approx. 10.0 Megapixels
Focal Length
6.1 (W) - 30.5 (T) mm (35mm film equivalent: 28 (W) - 140 (T) mm)
Digital Zoom
4x
Focusing Range
Normal AF: 2.0 in./5cm - infinity (W), 12 in./30cm - infinity (T);
Normal (With Tele-Converter): 1.8 ft./55cm - infinity (T);
Macro AF: 0.4 in. - 1.6 ft./1 - 50cm (W), 12 in. - 1.6 ft./30 - 50cm (T)
Manual Focus: 0.4 in./1cm. - infinity (W), 12 in./30cm - infinity (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
Real-image optical viewfinder
LCD Monitor
2.8-inch TFT color LCD (Vari-angle type with wide-viewing angle)
LCD Pixels
Approx. 461,000 pixels
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W) - f/4.5 (T)
- f/numbers available in Av and M:
W: f/2.8, 3.2, 3.5, 4.0, 4.5, 5.0, 5.6, 6.3, 7.1, 8.0
T: f/4.5, 5.0, 5.6, 6.3, 7.1, 8.0
Shutter Speed
1 - 1/4000 sec.
15 - 1/4000 sec. (Total shutter speed range)
- Shutter speeds differs depending on the shooting mode.
- Shutter speeds available in Tv and M:
15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 0.8, 0.6, 0.5, 0.4, 0.3,1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80,1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000,1/1250, 1/1600, 1/2000, 1/12500, 1/3200, 1/4000 (Units: sec.)
Sensitivity
Auto, ISO 80/100/125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200
Light Metering Method
Evaluative*1, Center-weighted average, Spot*2
*1 Facial brightness is evaluated (Face Detect AE) in Face AiAF.
*2 Fixed to Center, linked to AF frame.
Exposure Control Method
AE Lock
- Not available when shooting videos
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater, Custom1, Custom2
*Facial color is evaluated in Face AiAF (Face Detect WB).
Built-in Flash
Auto, on, Slow Synchro, off, Red-eye Reduction, FE Lock
- Facial brightness is also evaluated in Face AiAF.
Flash Range
1.6 - 23 ft. (50cm - 70m) (W), 1.6 - 13 ft. (50cm - 4.0m (T)
- Image brightness may diminish depending on the shooting distance.
Recycling Time
10 sec. or less (battery voltage: 7.4V)
Flash Exposure Compensation
Shooting Modes
Smart AUTO, P, Tv, Av, M, C1, C2, Low Light, Quick Shot, SCN*1, Movie*2
1 Portrait, Landscape, Kids & Pets, Sports, Smart Shutter*3, Super Vivid, Poster Effect, Color Accent, Color Swap, High Dynamic Range, Nostalgic, Fisheye Effect, Miniature Effect, Beach, Underwater, Foliage, Snow, Fireworks, Stitch Assist
*2 Standard, Miniature Effect, Color Accent, Color Swap
*3 Smile, Wink Self-timer, Face Self-Timer
Photo Effects
My Colors
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
* Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available.
- Not available in RAW and RAW+JPEG
Self Timer
Custom*
*Delay time (0 - 15 sec. (in one-second increments), 20/25/30 sec.) and number of shots
(1 - 10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
Normal: Approx. 2.0 shots/sec. (when shooting in P mode),Approx. 4.2 shots/sec. (when shooting in Low Light mode)
AF: Approx. 0.7 shots/sec. (when shooting in P mode),Approx. 1.0 shots/sec. (when shooting in Low Light mode)
LV: Approx. 0.8 shots/sec. (when shooting in P mode),Approx. 1.2 shots/sec. (when shooting in Low Light mode)
- Under conditions where the flash does not fire automatically.
- Differs depending on the zoom position.
Storage Media
SD/SDHC Memory Card, SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine, RAW
JPEG Compression Mode
Still Image: Exif 2.3 (JPEG), RAW (CR2 Canon Original))*
* Images processed with DPP.
Videos: MOV (Image data: H.264, Audio data: Linear PCM (Stereo))
Number of Recording Pixels
Still Image:16:9Large: 3648 x 2048Medium 1: 2816 x 1584Medium 2: 1920 x 1080Small: 640 x 360
3:2Large: 3648 x 2432Medium 1: 2816 x 1880Medium 2: 1600 x 1064Small: 640 x 424
4:3Large: 3648 x 2736Medium 1: 2816 x 2112Medium 2: 1600 x 1200Small: 640 x 480RAW: 3648 x 2736- Fixed to 1824 x 1368 when in Low Light
1:1Large: 2736 x 2736Medium 1: 2112 x 2112Medium 2: 1200 x 1200Small: 480 x 480
4:5Large: 2192 x 2736Medium 1: 1696 x 2112Medium 2: 960 x 1200Small: 384 x 480
Videos:Standard, Color Accent, Color Swap:1280 x 720 (24 fps*1), 640 x 480 (30 fps*2),320 x 240 (30 fps*2)Miniature Effect: 1280 x 720 (Shooting: 6 fps/3 fps/1.5 fps;Playback: 30 fps*2)640 x 480 (Shooting: 6 fps/3 fps/1.5 fps,Playback: 30 fps*2)*1 Actual frame rate is 23.976 fps.*2 Actual frame rate is 29.97 fps.
Image data
Movie data
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated fromCanon's standard shooting conditions. Figures for Movie Mode represent total capacityof the particular media.
Playback Modes File
- Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Jump, Slide Show (Playback Interval, Repeat, Effect, Playlist), Smart Shuffle- Still Images: Single, Index, Magnification, Trimming, Resize, Focus Check, Histogram, Overexposure Warning.- Videos: Normal Playback*, Editing, slow motion **, pause, first frame, last frame, next frame, previous frame, fast forward, fast rewind* Auto settings available in 5 levels** 5 levels (including normal playback), sound not available.
Erase Modes
Select image, select range, all images (all filtered images)- The image data in the memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased).- RAW + JPEG images can be erased individually.
Computer Interface
USB 2.0 Hi-Speed USB (dedicated female connector with unified type of digital, audio and video)
Video Out
Analog: NTSC/PAL, digital: HDMI mini connector
Audio Out
Stereo
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1. Rechargeable Lithium-ion Battery NB-7L
2. AC Adapter Kit ACK-DC50
Shooting Capacity
LCD Monitor on: Approx. 370 shotsLCD Monitor off: Approx. 1000 shotsApprox: 310 shots when in Quick Shot mode (LCD monitor on)
Playback Time
Approx. 7 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.41 x 3.00 x 1.90 in. / 112.1 x 76.2 x 48.3mm
* CIPA Compliant
Weight
Approx. 12.4 oz./ 351g (camera body only)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
