Canon Support for PowerShot G15 | Canon U.S.A., Inc.
PowerShot G15
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 08.08.13
File Size 581.93 KB
Date 04.02.25
File Size 142.00 B
Date 09.18.12
File Size 2.79 MB
Date 05.10.13
File Size 16.82 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/1.7-inch CMOS
Total Pixels
Approx. 13.3 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
6.1 (W) - 30.5 (T) mm (35mm film equivalent: 28-140mm)
Optical Zoom
5.0x
Digital Zoom
4.0x
Focusing Range
Normal: 2.0 in. (5cm) - infinity (W), 1.3 ft. (40cm) - infinity (T)
Normal with Tele-converter: 2.0 in. (5cm) - infinity (W), 2.5 ft. (75cm) - infinity (T)
Auto: 0.4 in. (1cm) - infinity (W), 1.3 ft. (40cm) - infinity (T)
Auto with Tele-converter: 2.5 ft. (75cm) - infinity (T)
Macro AF: 0.4 in. - 1.6 ft. (1-50cm) (W)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
Real-image zoom viewfinder
LCD Monitor
3.0-inch TFT Color LCD with wide viewing angle
LCD Pixels
Approx. 922,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/1.8 (W), f/2.8 (T)
Shutter Speed
1-1/4000 sec.
15-1/4000 sec. (in Tv and M modes)
Sensitivity
Auto, ISO 80/100/125/160/200/250/320/400/500/640/800/1250/1600/2000/2500/3200/4000/5000/6400/8000/10000/12800
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;3 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater, Custom 1, Custom 2
* Camera automatically sets the optimal ISO speed according to shooting mode.
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
- Facial brightness is also evaluated in Face Detect.
Flash Range
1.6 ft. - 23 ft. (W), 1.6 - 15 ft. (T) (50cm - 7.0m (W), (50cm - 4.5m (T))
Image brightness may diminish depending on the shooting distance.
Recycling Time
10 sec. or less (battery voltage: 7.4 V)
Flash Exposure Compensation
+/-2 stops in 1/3-stop increments
Shooting Modes
C1, C2, M, Av, Tv, P, Auto, Movie Digest, SCN*1, Creative Filters*2, Movie*3
- Shooting movies is possible with the movie button
*1 Portrait, Smooth Skin, Smart Shutter*4, High-Speed Burst HQ, Handheld NightScene, Underwater, Snow, Fireworks, Stitch Assist
*2 High Dynamic Range, Nostalgic, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap
*3 Standard, iFrame Movie, Super Slow Motion Movie
*4 Smile, Wink Self-timer, Face Self-timer
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
*Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
1)Normal: Approx. 2.1 shots/sec. (in P mode)
Approx. 10 shots/sec.* (in High-Speed Burst HQ)
2)AF: Approx. 0.9 shots/sec. (in P mode)
Approx. 5.2 shots/sec.* (in High-Speed Burst HQ)
3)LV: Approx. 0.9 shots/sec. (in P mode)
- Under conditions where the flash does not fire automatically
- Differs depending on the zoom position.
*Maximum continuous capture is 10 frames.
Storage Media
SD Memory Card, SDHC Memory Card, SDXC Memory Card
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Superfine / Fine
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG)
Video: MOV (Image: H.264; Audio: Linear PCM (Stereo))
Number of Recording Pixels
Still Images:
1) 16:9 - Large: 4000 x 2248; Medium 1: 2816 x 1584; Medium 2: 1920 x 1080; Small: 640 x 360; RAW: 4000 x 2248
2) 3:2 - Large: 4000 x 2664; Medium 1: 2816 x 1880; Medium 2: 1600 x 1064; Small: 640 x 424; RAW: 4000 x 2664
3) 4:3 - Large: 4000 x 3000; Medium 1: 2816 x 2112; Medium 2: 1600 x 1200; Small: 640 x 480; Raw: 4000 x 3000
4) 1:1 - Large: 2992 x 2992; Medium 1: 2112 x 2112; Medium 2: 1200 x 1200; Small: 480 x 480; RAW: 2992 x 2992
5) 4:5 - Large: 2400 x 3000; Medium 1: 1696 x 2112; Medium 2: 960 x 1200; Small: 384 x 480; RAW: 2400 x 3000
Videos:
Full HD 1920 x 1080: 24 fps (23.976)
HD 1280 x 720: 30 fps (29.97)
iFrame Movie HD 1280 x 720: 30 fps (29.97)
Movie Digest HD 1280 x 720: 30 fps (29.97)
Miniature Effect HD 1280 x 720: 6 fps / 3 fps / 1.5 fps
Miniature Effect 640 x 480: 6 fps / 3 fps / 1.5 fps
Super Slow Motion Movie 640 x 480: 120 fps
Super Slow Motion Movie 320 x 240: 240 fps
640 x 480: 30 fps (29.97)
Image data
Note: SF=Superfine F=Fine
&#42;The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
&#42;1Movie Digest refers to the created movie.
&#42;2Actual frame rate is 29.97 fps.
&#42;3Playback frame rate is 30 fps&#42;2.
&#42;4Actual frame rate is 23.976 fps.
Playback Modes File
Stills & Videos:
Auto Rotate (Automatic vertical/horizontal detection), Index Continuous Display, Image Advance (Operation Tools, Transition Effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Movie Digest, Slideshow (Playback Interval, Repeat, Effect, Playlist)
Still Images:
Single, Index, Magnification (2-10x), Switch to other images while zoomed, Information Display, Red-eye Correction, i-Contrast, Photobook Setup, Trimming, Resize, My Colors, Face ID info, Focus Check, Histogram, RGB Histogram, Location Information, Overexposure Warning
Videos:
Normal Playback*1, Slow Motion, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2, Erase chapters, Editing
Using the software included with the camera (ImageBrowser EX), there are 8 levels (1/8x to 1x) of playback speed for Super Slow Motion Movies possible on a computer.
*1 Audio settings available in 5 levels
*2 Approximately 4 seconds
*3 Slow motion available
Erase Modes
Select Image, Select Range, Select All Images
- The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).
- Using the Movie editing function, sections of the movie can be deleted.
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Mini-HDMI connector
Audio Out
Stereo (dedicated connector (female) with unified type of digital, audio and video)
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-10L, Compact Power Adapter CA-PS700 (included with AC Adapter Kit ACK-DC80)
Shooting Capacity
Approx. 350 shots using LCD monitor
Approx. 770 shots when LCD monitor is off
Playback Time
Approx. 7 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.20 x 2.99 x 1.58 in. / 106.6 x 75.9 x 40.1mm
Weight
12.4 oz. / 352g (CIPA standard)
10.9 oz. / 310g (camera only)30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malay, Indonesian and Vietnamese).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
