Canon Support for PowerShot G6 | Canon U.S.A., Inc.
PowerShot G6
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash and 4.0x Optical/4.1x Digital/16x Combined Zoom |
Image Capture Device
Type | 1/1.8 inch type Charge-Coupled Device (CCD) |
Total Pixels | Approx. 7.4 Million |
Effective Pixels | Approx. 7.1 Million |
Lens
Focal Length | 7.2-28.8mm, f/2.0-3.0 zoom Lens (35mm film equivalent: 35 - 140mm) |
Digital Zoom | 4.1x |
Focusing Range | Normal AF: 50cm/20 in. Infinity Macro AF: 5-50cm/2.0-20 in. (WIDE), 15-50cm/6-20 in. (TELE)-Super Macro: 5cm/2 in. (WIDE) |
Autofocus System | 9-point AiAF (Automatic Focus Point Selection)/1-point AF (Fixed to center) |
Viewfinders
Optical Viewfinder | Real-image optical zoom viewfinder |
LCD Monitor | 2.0 inch low-temperature polycrystalline silicon TFT color LCD (with vari-angle function) |
LCD Pixels | Approx. 118,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.0-8.0 (W), f/3.0-8.0 (T) |
Shutter Speed | 1-1/2000 sec. Slow shutter of 1.3 sec. and more operates with noise reduction |
Exposure Control
Sensitivity | AUTO*, ISO 50/100/200/400 equivalent *Camera automatically sets the optimum speed. |
Light Metering Method | Evaluative/Center-weighted average/Spot* *Metering frame with Spot mode is center fixed. |
Exposure Control Method | Program AE, Shutter-priority AE, Aperture-Priority AE or Manual |
Exposure Compensation | +/- 2 EV in 1/3 stop increments |
AE Lock | Available |
ND Filter | Built-in |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H or Flash), or Custom White Balance (2 positions) |
Flash
Built-in Flash | Operation Modes: Auto On/Off, Red-Eye Reduction On/Off |
Flash Range | WIDE: 70cm-5.0m/2.3-16 ft. TELE: 70cm-4.0m/2.3-13.1 ft.(Sensitivity setting: ISO 100 equivalent) |
Recycling Time | Approx. 10 sec. or less |
Terminals for External Flash | Sync-terminals at accessory shoe |
Flash Exposure Compensation | +/- 2.0 EV in 1/3 stop increments |
Shooting Specifications
Shooting Modes | Auto, Creative Zone (P, Av, Tv, M), Image Zone (Portrait, Landscape, Night Scene, Stitch Assist, Movie), Custom 1, Custom 2 |
Photo Effects | Vivid, Neutral, Low Sharpening, Sepia and Black & White |
Self Timer | Operates with approx. 2 sec. or approx 10 sec. count-down. |
Wireless Control | Available (playback is available too) |
Continuous Shooting | High Speed approx. 2.0 fps, Normal Speed approx. 1.2 fps |
Image Storage
Storage Media | Compact Flash (CF) Card Type I or Type II |
Print Order Format | Design rule for camera file system, Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Exif 2.2 (JPEG) |
JPEG Compression Mode | SuperFine, Fine, Normal |
Number of Recording Pixels | Still Image: 3,072x2,304 (RAW/Large), 2,592x1,944 (Medium 1), 2,048x1,536 (Medium 2), 1,600x1,200 (Medium 3), 640x480 (Small) |
Number of Recordable Images
Image data | These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.  |
Time of Recordable Movies
Movie data | Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual 640 x 480 movie clips are limited to 30 seconds maximum per clip; individual 320 x 240 and 160 x 120 movie clips are limited to 3 minutes maximum per clip. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnails), Magnification (Approx. 2.0x to 10x), Slide Show or Movie Magnified, Auto rotate, Rotation, Histogram, Sound memos (up to 60 sec.), Auto Play |
Erasing Specifications
Erase Modes | Still Images: Single Image, All Images Movie: Part of Movie, All Movie |
Interfaces
Computer Interface | Universal Serial Bus (USB) mini-B |
Video Out | NTSC or PAL |
Audio Out | Monaural |
Other | CF card slot (accepts Type I & Type II cards). Direct connection to Canon CP Printers and select BJ Photo Printers (no computer required) |
Power Supply | 1. Rechargeable Lithium-ion battery (type: BP-511A, BP-511, BP-512 or BP-514) 2. AC adapter (type: CA-560) 3. Car battery adapter (type: CR-560) 4. Coin-type secondary Lithium battery (CR-2025)BP-511A: LCD On - Approx. 300; LCD Off - Approx. 900Approx. 400 minutes (Under Canon's standard conditions with fully charged battery) Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23° C). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot. Canon's standard conditions of measuring playback time are as follows: Normal temperature (23° C). Repeat playback automatically at a speed of 1 image per 5 seconds. |
Power Source | 1. Rechargeable Lithium-ion battery (type: BP-511A, BP-511, BP-512 or BP-514) 2. AC adapter (type: CA-560) 3. Car battery adapter (type: CR-560) 4. Coin-type secondary Lithium battery (CR-2025) |
Shooting Capacity | BP-511A: LCD On - Approx. 300; LCD Off - Approx. 900 |
Playback Time | Approx. 400 minutes (Under Canon's standard conditions with fully charged battery) Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23° C). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot. Canon's standard conditions of measuring playback time are as follows: Normal temperature (23° C). Repeat playback automatically at a speed of 1 image per 5 seconds. |
Physical Specifications
Operating Temperature | 32-104° F/0-40° C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.1 x 2.9 x 2.9 in./104.9 x 72.8 x 73.1mm (Excluding protrusions) |
Weight | Approx. 13.4 oz./380g (camera body only) |
14 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Japanese, Russian and Portuguese) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
