Canon Support for PowerShot G7 | Canon U.S.A., Inc.
PowerShot G7
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 11.21.07
File Size 351.12 KB
Date 03.31.07
File Size 2.11 MB
Date 10.24.07
File Size 3.73 MB
Date 03.31.07
File Size 1.82 MB
Date 05.18.08
File Size 1.82 MB
Date 05.18.08
File Size 2.11 MB
Date 05.18.08
File Size 1.18 MB
Date 05.18.08
File Size 27.83 MB
Date 03.04.10
File Size 6.07 MB
Date 03.04.10
File Size 6.23 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and the lens shift-type image stabilizer (IS) system, 6x Optical / 4x Digital / 24x Combined Zoom
Image Capture Device
Type 10.0 Megapixel, 1/1.8 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 10.40 Megapixels
Effective Pixels Approx. 10.0 Megapixels
Lens
Focal Length 7.4-44.4mm f/2.8-4.8 (35mm film equivalent: 35-210mm)
Digital Zoom 4x
Focusing Range Normal: 1.6 ft./50cm-infinity
Macro: 0.39 in.-1.6 ft./1-50cm (WIDE)
Autofocus System TTL Autofocus
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 2.5 inch low-temperature polycrystalline silicon TFT color LCD
Brightness adjustment: 15 levels
LCD Pixels Approx. 207,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 (W) - f/4.8 (T)
Shutter Speed 15-1/2500 sec.; Long Shutter operates with noise reduction when manually set at 1.3-15 sec.
Exposure Control
Sensitivity Auto, High ISO Auto, ISO 80/100/200/400/800/1600 (Standard Output Sensitivity/Recommended Exposure Index)
Light Metering Method Evaluative, Center-weighted average, Spot*
* Metering frame is fixed to the center or linked to the AF frame
Exposure Control Method Program AE; AE Lock is available
Exposure Compensation +/-2 stops in 1/3-stop increments
White Balance
White Balance Control Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), Custom
Flash
Built-in Flash Auto, Auto w/ Red-Eye Reduction, Auto w/ Slow Synchro, Flash On, Flash On w/ Red-Eye Reduction, Flash On w/ Slow Synchro, Flash Off
Flash Range Normal: 1.6-13 ft./50cm - 4.0m (W), 1.6-8.2 ft./50cm - 2.5m (T)
Macro: 1-1.6 ft./30-50cm (W/T) (when sensitivity is set to ISO Auto)
Recycling Time 12 sec. or less (battery voltage=6.0V)
Flash Exposure Compensation +/-2 stops in 1/3-stop increments
Shooting Specifications
Shooting Modes Auto, P, Av, Tv, M, C1, C2, Special Scene (Portrait, Landscape, Night Scene, Sports, Foliage, Snow, Beach, Fireworks, Aquarium, Underwater, ISO 3200, Indoor, Kids & Pets, Night Snapshot, Color Accent, Color Swap), Stitch Assist, Movie
Photo Effects My Colors
Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom Color
Self Timer Activates shutter after an approx. 2-sec./10-sec. delay, Custom
Wireless Control Not available
Continuous Shooting Approx. 2.0 fps
Image Storage
Storage Media SD Memory Card, SDHC Memory Card, MultiMediaCard
File Format Design rule for camera file system, DPOF Version 1.1
Image Recording Format Normal, Fine, SuperFine
JPEG Compression Mode Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural))
Number of Recording Pixels Still Image: 640 x 480 (Small), 1,600 x 1,200 (Medium 3), 2,272 x 1,704 (Medium 2), 2,816 x 2,112 (Medium 1), 3,648 x 2,736 (Large), 3,648 x 2,048 (Widescreen)
Movie: 1,024 x 768 (15 fps), 640 x 480 / 320 x 240 (30 fps/15 fps) available up to 4GB, 160 x 120 (3 min. at 15 fps)
Number of Recordable Images
Image data
Time of Recordable Movies
Movie data Note: N=Normal F=Fine SF=SuperFine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Specifications
Playback Modes File Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume Playback, My Category, Histogram, Index (9 thumbnails), Sound Memos, Slide Show
Movie: Normal Playback, Special Playback, Editing
Erasing Specifications
Erase Modes Still Image: single image, by date, by category, by folder, all images
Movie: part of movie, all of movie
Interfaces
Computer Interface USB 2.0 Hi-Speed (mini-B jack)
Video Out NTSC/PAL
Audio Out Monaural
Other Memory card slot; direct connection to Canon CP and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply 1. Rechargeable Lithium Battery NB-2LH
2. AC Adapter Kit ACK-DC20Still Image: approx. 220 shots (NB-2LH/LCD on)* approx. 500 shots (NB-2LH/LCD off)
* The above figures comply with CIPA testing standards and apply when a fully-charged battery is used.Approx. 300 min. (NB-2LH)
Power Source 1. Rechargeable Lithium Battery NB-2LH
Shooting Capacity Still Image: approx. 220 shots (NB-2LH/LCD on)* approx. 500 shots (NB-2LH/LCD off)
Playback Time Approx. 300 min. (NB-2LH)
Physical Specifications
Operating Temperature 32-104&deg;F/0-40&deg;C
Operating Humidity 10-90%
Dimensions (W x H x D) 4.19 x 2.83 x 1.67 in. / 106.4 x 71.9 x 42.5mm
Weight Approx. 11.3 oz. / 320g (camera body only)
Note: 25 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, PowerShot, ELPH and DIGIC are registered trademarks, and SELPHY and PIXMA are trademarks, of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft and Windows are trademarks or registered trademarks of the Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple Computer, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
