Canon Support for PowerShot G9 | Canon U.S.A., Inc.
PowerShot G9
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash, 6x Optical / 4x Digital / 24x Combined Zoom with Optical Image Stabilizer System |
Image Capture Device
Type | 12.1 Megapixel, 1/1.7 inch type Charge Coupled Device (CCD) |
Total Pixels | Approx. 12.4 Megapixels |
Effective Pixels | Approx. 12.1 Megapixels |
Lens
Focal Length | 7.4-44.4mm f/2.8-4.8 (35mm film equivalent: 35-210mm) |
Digital Zoom | 4x |
Focusing Range | Normal: 1.6 ft./50cm-infinity Macro: 0.39 in.-1.6 ft./1-50cm (WIDE) |
Autofocus System | TTL Autofocus |
Viewfinders
Optical Viewfinder | Real image optical zoom viewfinder |
LCD Monitor | 3.0 inch low-temperature polycrystalline silicon TFT color LCD with wide viewing angle |
LCD Pixels | Approx. 230,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.8 (W) - f/4.8 (T) |
Shutter Speed | 15-1/2500 sec. (settable in Tv and M) |
Exposure Control
Sensitivity | Auto, High ISO Auto, ISO 80/100/200/400/800/1600 equivalent (Standard Output Sensitivity. Recommended Exposure Index) |
Light Metering Method | Evaluative*, Center-weighted average, Spot*** Control to incorporate facial brightness in Face Detection AF ** Metering frame is fixed to the center or linked to the AF frame |
Exposure Control Method | Program AE, Shutter Speed-Priority AE, Aperture-Priority AE, Manual; AE Lock, Safety Shift, Auto ISO Shift |
Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance
White Balance Control | Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater), Custom1, Custom2 |
Flash
Built-in Flash | Auto, Auto w/ Red-eye Reduction, Flash On, Flash On w/ Red-eye Reduction, Flash Off; FE lock, Safety FE, Slow Synchro, Second-curtain synchro |
Flash Range | 1.0-13 ft./30cm-4.0m (W), 1.6-8.2 ft./50cm-2.5m (T) (when sensitivity is set to ISO Auto) |
Recycling Time | 12 sec. or less (battery voltage=7.4V) |
Flash Exposure Compensation | +/-2 stops in 1/3-stop increments |
Shooting Specifications
Shooting Modes | Auto, P, Av, Tv, M, C1, C2, Special Scene (Portrait, Landscape, Night Scene, Sports, Foliage, Snow, Beach, Fireworks, Aquarium, Underwater, Indoor, ISO 3200, Kids & Pets, Night Snapshot, Color Accent, Color Swap), Stitch Assist, Movie |
Photo Effects | My Colors Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom |
Self Timer | Activates shutter after an approx. 2-sec./10-sec. delay, Custom |
Wireless Control | Not available |
Continuous Shooting | Normal: approx. 1.5 fps; AF: approx. 0.7 fps; LV: approx. 0.8 fps (Large/Fine) |
Image Storage
Storage Media | SD/SDHC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card |
File Format | Design rule for camera file system, DPOF Version 1.1 |
Image Recording Format | Normal, Fine, SuperFine, RAW |
JPEG Compression Mode | Still Image: Exif 2.2 (JPEG) Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural)) |
Number of Recording Pixels | Still Image: 4,000 x 3,000 (Large), 3,264 x 2,448 (Medium 1), 2,592 x 1,944 (Medium 2), 1,600 x 1,200 (Medium 3), 640 x 480 (Small), 4,000 x 2,248 (Widescreen) Movie: 1024 x 768 (15 fps), 640 x 480 (30 fps/30 fps LP), 640 x 480 (2 hours at 0.5 fps/1 fps), 320 x 240 (30 fps) available up to 4GB or 60 minutes, 160 x 120 (3 minutes at 15 fps) |
Number of Recordable Images
Image data |
Time of Recordable Movies
Movie data | Note: N=Normal F=Fine SF=SuperFine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Specifications
Playback Modes File | Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Colors, My Category, Histogram, Index (9 thumbnails), Sound Memos, Slide Show, Red-eye Correction, RAW playback, Resize, Image Inspection Tool Movie: Normal Playback, Special Playback, Editing |
Erasing Specifications
Erase Modes | Still Image: single image, select by date, select by category, select by folder, all images Movie: part of movie, all of movie |
Interfaces
Computer Interface | USB 2.0 Hi-Speed (mini-B jack) |
Video Out | NTSC/PAL |
Audio Out | Monaural |
Other | SD Memory card slot; direct connection to Canon CP and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
Power Supply | 1. Rechargeable Lithium Battery NB-2LH 2. AC Adapter Kit ACK-DC20 (optional)Still Image: approx. 240 shots (NB-2LH/LCD on)*, approx. 600 shots (NB-2LH/LCD off) * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.Approx. 300 min. (NB-2LH) |
Power Source | 1. Rechargeable Lithium Battery NB-2LH 2. AC Adapter Kit ACK-DC20 (optional) |
Shooting Capacity | Still Image: approx. 240 shots (NB-2LH/LCD on)*, approx. 600 shots (NB-2LH/LCD off) * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
Playback Time | Approx. 300 min. (NB-2LH) |
Physical Specifications
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.19 x 2.83 x 1.67 in. / 106.4 x 71.9 x 42.5mm |
Weight | Approx. 11.29 oz. / 320g (camera body only) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
