Canon Support for PowerShot S100 Digital ELPH | Canon U.S.A., Inc.
- Windows 11
 - Windows 10 (x64)
 - Windows 10
 - Windows 8.1 (x64)
 - Windows 8.1
 - Windows 8 (x64)
 - Windows 8
 - Windows 7 (x64)
 - Windows 7
 - Windows Vista (x64)
 - Windows Vista
 - Windows Me
 - Windows XP (x64)
 - Windows XP
 - Windows 98
 - Windows 95
 - Windows Server 2022
 - Windows Server 2019 (x64)
 - Windows Server 2016 (x64)
 - Windows Server 2012 (x64)
 - Windows Server 2008 (x64)
 - Windows Server 2003 (x64)
 - Windows Server 2003 R2
 - macOS Tahoe v26
 - macOS Sequoia v15
 - macOS Sonoma v14
 - macOS Ventura v13
 - macOS Monterey v12
 - macOS Big Sur v11.0
 - macOS Catalina v10.15
 - macOS Mojave v10.14
 - macOS High Sierra v10.13
 - macOS Sierra v10.12
 - OS X El Capitan v10.11
 - OS X Yosemite v10.10
 - OS X Mavericks v10.9
 - OS X Mountain Lion v10.8
 - OS X Lion v10.7
 - Mac OS X Snow Leopard v10.6
 - Mac OS X v10.1
 - Mac OS 9
 - Linux ARM
 - Linux MIPS
 - Linux 64bit
 - Linux 32bit
 - SAP
 - Windows Server 2025
 - Windows NT
 - Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Image Capture Device
| Type | 1/2.7 inch Charge-Coupled Device(CCD) |
| Total Pixels | Approx. 2.11 million |
| Effective Pixels | Approx. 2.02 million |
Lens
| Focal Length | 5.4mm (Wide-angle) - 10.8mm (Telephoto) (35 mm film equivalent: 35 - 70 mm) |
| Focusing Range | Standard: 57 cm - infinity (22 in. - infinity);Macro: 10 cm - 57 cm (4 - 22 in.) (Wide-angle) / 27 cm - 57 cm (11 - 22 in.) (Telephoto) |
| Autofocus System | TTL 3-point AiAF |
Viewfinders
| Optical Viewfinder | 5.4mm (Wide angle) - 10.8mm (Telephoto) |
| LCD Monitor | 1.5 inch low-temperature polycrystalline silicon TFT LCD |
| LCD Pixels | 117,600 (490 x 240) |
| LCD Coverage | 100% |
Aperture and Shutter
| Maximum Aperture | Maximum: f/2.8 to f/4 (Wide-angle) Minimum : f/4 to f/5.6 (Telephoto)  |
| Shutter Speed | 1 - 1/1500 sec.(1-sec. for Slow-Synchro mode and manual mode with flash set to Off) |
Exposure Control
| Sensitivity | Equivalent to ISO 100 |
| Light Metering Method | Center weighted metering |
| Exposure Control Method | TTL program AE |
White Balance
| White Balance Control | TTL auto/manual |
Flash
| Built-in Flash | Built-in (Auto, On, Off, Red-Eye Reduction, Slow-Synchro) |
| Flash Range | Wide angle : 27cm - 3m (11 in. - 10 ft.); Telephoto : 27cm - 2m (11 in. - 7 ft.) |
| Recycling Time | Approx. 10 sec. |
Shooting Specifications
| Shooting Modes | Shooting/ Replay |
| Self Timer | 10 seconds |
| Continuous Shooting | Approx. 2 images/sec. (when the LCD monitor is off.) |
Image Storage
| Storage Media | CompactFlash™ card (Type I) |
| File Format | Design rule for Camera Format (DCF*1), Images/Thumbnails: JPEG |
| Print Order Format | Digital Print Order Format (DPOF) |
| Image Recording Format | JPEG |
| JPEG Compression Mode | Normal, Fine, Super-Fine |
| Number of Recording Pixels | Large: 1,600 (H) x 1,200 (V)Middle: 1280 (H) x 960 (V)Small: 800 (H) x 600 (V) |
Interfaces
| Computer Interface | Universal Serial Bus (USB) |
| Video Out | Video out |
| Other | CF Card Slot (Type I) |
| Power Supply | 1. Battery Pack NB-1L 2. Compact Power Adapter CA-PS300 (with DC Coupler DR-300) Important Safety Information  |
| Power Source | 1. Battery Pack NB-1L 2. Compact Power Adapter CA-PS300 (with DC Coupler DR-300) Important Safety Information  |
Physical Specifications
| Operating Temperature | 32 - 104°F (0 - 40°C) |
| Operating Humidity | 10% - 90% |
| Dimensions (W x H x D) | 3.4 x 2.2 x 1.1 in. (87.0 x 57.0 x 26.9 mm ) (excluding protrusion) |
| Weight | Approx. 6.7 oz. (190 g) (excluding batteries and CF card) |
Computer System Requirements
| Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.1 through 9.0.4, Quicktime 3.0 or higher, (QuickTime 4.1 is in the CD-ROM "DIGITAL CAMERA Solution Disk" included with the PowerShot G1 standard kit) (Please see our Mac OS X Compatibility Statement.) CPU: PowerPC USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook). iMac computers running OS 8.1 require installation of "iMac Update 1.0" and "iMac Firmware Update 1.0" or higher. RAM: 20 MB or more of application memory  |
| PC Requirements | Hardware: IBM PC/AT compatible OS: Windows 95/98 (including the Second Edition), Windows NT 4.0 (Service Pack 3 or higher required), Windows 2000, Windows ME(Please see our Windows XP Compatibility Statement.) CPU: Pentium 133 MHz or better Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RAM: 32MB or more (Windows 95/98), 64MB or more (Windows NT 4.0/Windows 2000/Windows ME)  |
| *1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronic Industry Development Association (JEIDA). |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
 - Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
 next to your download
