Canon Support for PowerShot S100 Digital ELPH | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.31.07
File Size 3.84 MB
Date 03.31.07
File Size 2.99 MB
Date 03.31.07
File Size 2.85 MB
Date 12.31.01
File Size 13.35 MB
Date 03.31.07
File Size 3.59 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Image Capture Device
Type 1/2.7 inch Charge-Coupled Device(CCD)
Total Pixels Approx. 2.11 million
Effective Pixels Approx. 2.02 million
Lens
Focal Length 5.4mm (Wide-angle) - 10.8mm (Telephoto) (35 mm film equivalent: 35 - 70 mm)
Focusing Range Standard: 57 cm - infinity (22 in. - infinity);Macro: 10 cm - 57 cm (4 - 22 in.) (Wide-angle) / 27 cm - 57 cm (11 - 22 in.) (Telephoto)
Autofocus System TTL 3-point AiAF
Viewfinders
Optical Viewfinder 5.4mm (Wide angle) - 10.8mm (Telephoto)
LCD Monitor 1.5 inch low-temperature polycrystalline silicon TFT LCD
LCD Pixels 117,600 (490 x 240)
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture Maximum: f/2.8 to f/4 (Wide-angle)
Minimum : f/4 to f/5.6 (Telephoto)
Shutter Speed 1 - 1/1500 sec.(1-sec. for Slow-Synchro mode and manual mode with flash set to Off)
Exposure Control
Sensitivity Equivalent to ISO 100
Light Metering Method Center weighted metering
Exposure Control Method TTL program AE
White Balance
White Balance Control TTL auto/manual
Flash
Built-in Flash Built-in (Auto, On, Off, Red-Eye Reduction, Slow-Synchro)
Flash Range Wide angle : 27cm - 3m (11 in. - 10 ft.); Telephoto : 27cm - 2m (11 in. - 7 ft.)
Recycling Time Approx. 10 sec.
Shooting Specifications
Shooting Modes Shooting/ Replay
Self Timer 10 seconds
Continuous Shooting Approx. 2 images/sec. (when the LCD monitor is off.)
Image Storage
Storage Media CompactFlash&#153; card (Type I)
File Format Design rule for Camera Format (DCF*1), Images/Thumbnails: JPEG
Print Order Format Digital Print Order Format (DPOF)
Image Recording Format JPEG
JPEG Compression Mode Normal, Fine, Super-Fine
Number of Recording Pixels Large: 1,600 (H) x 1,200 (V)Middle: 1280 (H) x 960 (V)Small: 800 (H) x 600 (V)
Interfaces
Computer Interface Universal Serial Bus (USB)
Video Out Video out
Other CF Card Slot (Type I)
Power Supply 1. Battery Pack NB-1L
2. Compact Power Adapter CA-PS300 (with DC Coupler DR-300)
Important Safety Information
Power Source 1. Battery Pack NB-1L
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10% - 90%
Dimensions (W x H x D) 3.4 x 2.2 x 1.1 in. (87.0 x 57.0 x 26.9 mm ) (excluding protrusion)
Weight Approx. 6.7 oz. (190 g) (excluding batteries and CF card)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook
OS: Mac OS 8.1 through 9.0.4, Quicktime 3.0 or higher, (QuickTime 4.1 is in the CD-ROM "DIGITAL CAMERA Solution Disk" included with the PowerShot G1 standard kit) (Please see our Mac OS X Compatibility Statement.)
CPU: PowerPC
USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook). iMac computers running OS 8.1 require installation of "iMac Update 1.0" and "iMac Firmware Update 1.0" or higher.
RAM: 20 MB or more of application memory
PC Requirements Hardware: IBM PC/AT compatible
OS: Windows 95/98 (including the Second Edition), Windows NT 4.0 (Service Pack 3 or higher required), Windows 2000, Windows ME(Please see our Windows XP Compatibility Statement.)
CPU: Pentium 133 MHz or better
Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems.
RAM: 32MB or more (Windows 95/98), 64MB or more (Windows NT 4.0/Windows 2000/Windows ME)
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronic Industry Development Association (JEIDA).
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
