Canon Support for PowerShot S20 | Canon U.S.A., Inc.
PowerShot S20
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
Software Development Kit
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at https://www.usa.canon.com/support/sdk. To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
SELECT ERROR CODE
Image Capture Device
Type | 1/1.8 inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 3.34 million |
Effective Pixels | Approx. 3.24 million |
Lens
Digital Zoom | 6.5mm (Wide-angle)-13mm (Telephoto) (35 mm film equivalent: 32 - 64mm) |
Focusing Range | Standard:66cm (2.2ft) - infinity; Macro: 12cm (0.4 ft) - 66cm (2.2 ft) |
Autofocus System | TTL AF |
Viewfinders
Optical Viewfinder | Real-image optical viewfinder Magnification: 0.35 (Wide-angle) - 0.70 (Telephoto) Coverage: (V) 80% (H) 80% (when object is 2m away) |
LCD Monitor | 1.8 inch low-temperature polycrystalline silicon TFT LCD |
LCD Pixels | 113,578 dots (521 x 218) |
LCD Coverage | 88.7% |
Aperture and Shutter
Maximum Aperture | Maximum: F2.9-F8.0 (Wide-angle) Minimum: F4.0-F8.0 (Telephoto) |
Shutter Speed | 2-1/1,000 sec. (2 sec. for Slow Shutter or Night Scene mode) |
Exposure Control
Sensitivity | Equivalent to ISO 100-400 (ISO 400 for gain up setting) |
Light Metering Method | Center-weighted metering/spot metering |
Exposure Control Method | Program AE |
Exposure Compensation | +/- 2EV in 1/3-stop increments |
White Balance
White Balance Control | TTL |
Flash
Flash Range | 0.17 (0.6 ft) - 3.3m (10.8 ft) (wide-angle) 0.17 (0.6 ft) - 2.3m (7.5 ft) (telephoto) (in total darkness) |
Recycling Time | Approx. 10 sec. or shorter (battery voltage = 6.0V) |
Shooting Specifications
Shooting Modes | Auto, manual, flash, self-timer, macro, continuous, (1.2 fps), Stitch Assist, Image (5 menu) |
Continuous Shooting | 1.2 images/sec. (large/Fine in using optical finder) |
Image Storage
Storage Media | CompactFlash card (type I and II) |
File Format | Design rule for Camera File System/CIFF (playback only) |
Print Order Format | DPOF |
JPEG Compression Mode | Normal, Fine, SuperFine |
Number of Recording Pixels | Large: 2,048(H) x 1,536(V)Middle:1,024(H) x 768(V)Small: 640(H) x 480(V) |
Number of Recordable Images
Image data |
Playback Specifications
Playback Modes File | Playback Modes Single image, multiple images (9 thumbnails), slideshow |
Erasing Specifications
Erase Modes | Single image, all images |
Interfaces
Computer Interface | Serial (RS 232C)/USB |
Video Out | NTSC |
Other | CF Card Slot (Type I and Type II) |
Power Supply | 1. 2CR Lithium-manganese Battery (Non-rechargeable) 2. NB-5H Nickel-Metal Hybrid Battery (Rechargeable) 3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter) |
Power Source | 1. 2CR Lithium-manganese Battery (Non-rechargeable) 2. NB-5H Nickel-Metal Hybrid Battery (Rechargeable) 3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter) |
Physical Specifications
Operating Temperature | 32 - 104°F (0 - 40°C) |
Operating Humidity | 10% - 90% |
Dimensions (W x H x D) | 4.1 x 2.7 x 1.3 in / 105.4 x 69.4 x 33.8mm |
Weight | 4.1 x 2.7 x 1.3 in / 105.4 x 69.4 x 33.8mm |
Computer System Requirements
Mac Requirements | Hardware Power Macintosh, PowerBook, iMac or iBook OS Mac OS 7.5, Quicktime 2.1 (Please see our Mac OS X Compatibility Statement.) CPU PowerPC RAM 20 MB or more of application memory Interface USB (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook)- Limited to genuine Apple Computer brand models with built-in USB interface - iMac computers running Mac OS 8.1 require installation of the "iMac Update 1.0" and "iMac Firmware Update 1.0" RS 422 (Printer or modem port for PowerShot S10/S20 models only) Free Hard Disk Space Canon Utilities Image Browser: 20 MB or more Canon Utilities PhotoStitch: 30 MB or more Canon Digital Camera Plug-in Module: 15 MB or more Adobe PhotoDeluxe: 70 MB or more Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, Thousands of colors or more |
PC Requirements | Hardware IBM PC/AT compatible OS Windows 95/98 (including the Second Edition) Windows NT 4.0 (Service Pack 3 or higher required) Windows 2000Windows ME(Please see our Windows XP Compatibility Statement.) CPU Pentium 133 MHz or better RAM 32 MB or more (Windows 95/98) 64 MB or more (Windows NT/2000/ME) Interface USB (Limited to pre-installed Windows 98, Windows 2000 or Windows ME Systems as well as Windows ME Systems upgraded from Windows 98) RS-232C (Serial/COM port for PowerShot S10/S20 only) Free Hard Disk Space Canon Utilities ZoomBrowser EX: 120 MB or more (including the PhotoRecord printing utility) Canon Utilities PhotoStitch: 40 MB or more Canon Digital Camera USB TWAIN Driver: 15 MB or more Canon Digital Camera RS-232C TWAIN Driver: 15 MB or more Adobe PhotoDeluxe Home Edition: 140 MB or more (works with the Windows 95/98/NT 4.0 operating systems) Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, High Color (16 bit) or more |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
