Canon Support for PowerShot S300 | Canon U.S.A., Inc.
PowerShot S300
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Image Capture Device
Type | 1/2.7 inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 2.11 million-pixel |
Effective Pixels | Approx. 2.02 million |
Lens
Focal Length | 5.4 (Wide-angle) - 16.2 (Telephoto) mm(35 mm film equivalent: 35 - 105 mm) |
Focusing Range | Standard: 76 cm - infinity (2.5 ft. - infinity)Macro: 16 - 76 cm (6.3 in - 2.5 f) (Wide-angle) / 26 - 76 cm (10.2 in - 2.5 ft.) (Telephoto) |
Autofocus System | TTL 3-point AiAF |
Viewfinders
Optical Viewfinder | 5.4mm (Wide angle) - 16.2mm (Telephoto) |
LCD Monitor | 1.5 inch low-temperature polycrystalline silicon TFT LCD |
LCD Pixels | 117,600 (490 x 240) |
LCD Coverage | 80% |
Aperture and Shutter
Maximum Aperture | Maximum: f/2.7 to f/8 (Wide-angle)Minimum : f/4.7 to f/14 (Telephoto) |
Shutter Speed | 1 - 1/1500 sec.(1-sec. for Slow-Synchro mode or manual mode with flash set to Off)(Noise reduction processing on speeds slower than 1/6 sec.) |
Exposure Control
Sensitivity | Equivalent to ISO 100 (automatically raised to ISO 150 in low light) |
Light Metering Method | Evaluative metering (linked to focusing point) |
Exposure Control Method | Program AE |
Exposure Compensation | +/-2EV (1/3 stops) |
White Balance
White Balance Control | TTL auto white balance, pre-set white balance (available settings: daylight, cloudy, tungsten, fluorescent), Black & White |
Flash
Built-in Flash | Built-in (Auto, On, Off, Red-Eye Reduction, Slow-Synchro) |
Flash Range | Normal: Wide angle - 76 cm-3.5m (2.5 in.-11.5 ft.), Telephoto - 76 cm-2m (2.5 in.-6.6 ft.) Macro Mode: Wide angle - 26-76cm (10.2 in-2.5 ft.), Telephoto - 26-76cm (10.2 in.- 2.5 ft.) |
Recycling Time | Approx. 10 sec. |
Shooting Specifications
Shooting Modes | Auto/Manual/Stitch assist/Movie |
Continuous Shooting | Approx. 2.5 images/sec. (at large/fine mode with the LCD monitor off) |
Image Storage
Storage Media | CompactFlash (CF) Card Type I |
File Format | Design rule for Camera File system (DCF*1) |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1; EXIF Print Compliant (EXIF 2.2) |
Image Recording Format | Images/Thumbnails: JPEG |
Number of Recordable Images
Image data |
Interfaces
Computer Interface | Universal Serial Bus (USB) |
Video Out | Video : NTSC or PAL selectable Audio : monaural Cable type : L-type plug (3.5mm dia) |
Power Supply | 1. Battery Pack NB-1L rechargeable Lithium-ion battery (one) 2. Compact Power Adapter CA-PS500 (with DC Coupler DR-500) 3. AC Power Cord Important safety information |
Power Source | 1. Battery Pack NB-1L rechargeable Lithium-ion battery (one) 2. Compact Power Adapter CA-PS500 (with DC Coupler DR-500) 3. AC Power Cord Important safety information |
Physical Specifications
Operating Temperature | 32 - 104°F (0 - 40°C) |
Operating Humidity | 10 - 90 % |
Dimensions (W x H x D) | 3.7 x 2.5 x 1.2 in. (94.8 x 62.5 x 29.9mm ) (excluding lens protrusion) |
Weight | Approx. 8.5 oz. (240 g) (excluding batteries and CF card) |
Computer System Requirements
Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.6 through 9.1, Quicktime 3.0 or higher (QuickTime 4.1 is in the CD-ROM "DIGITAL CAMERA Solution Disk" included with the PowerShot S110 standard kit) (Please see our Mac OS X Compatibility Statement.) CPU: Power PC Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3/G4, iMac, iBook) RAM: 20MB or more of application memory |
PC Requirements | Hardware: IBM PC/AT compatible OS: Windows 98 (including the Second Edition), Windows 2000, Windows ME (Please see our Windows XP Compatibility Statement.) CPU: Pentium 133 MHz or better Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems RAM: 32MB or more (Windows 98), 64MB or more (Windows 2000/Windows ME) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
