Canon Support for PowerShot SD100 | Canon U.S.A., Inc.
PowerShot SD100
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash and 2x Optical/ 3.2x Digital/ 6.4x Combined Zoom |
Image Capture Device
Type | 1/2.7 inch Charge-Coupled Device (CCD) |
Effective Pixels | Approx. 3.2 million |
Lens
Focal Length | 5.4 - 10.8mm, f/2.8 - 3.9 zoom lens (35mm film equivalent: 35 - 70mm) |
Digital Zoom | 3.2x Digital Zoom (Maximum 6.4x digital zoom is available when combined with optical zoom) |
Focusing Range | Normal: AF: 18 in. - Infinity/ 47cm - Infinity, Macro AF: 4 in. - 18 in./ 10cm - 47cm (WIDE); 9 in. - 18 in./ 23cm - 47cm (TELE) |
Autofocus System | 9-point AiAF/ 1-point AF (Fixed to center) |
Viewfinders
Optical Viewfinder | Real-image zoom viewfinder |
LCD Monitor | 1.5 inch low temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approx. 118,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.8/ 7.1 (W), f/3.9/ 10 (T) |
Shutter Speed | 15 - 1/1,500 sec. |
Exposure Control
Sensitivity | Auto/ ISO 50/ 100/ 200/ 400 (equivalent ISO) |
Light Metering Method | Evaluative, Center-weighted Average or Spot Metering |
Exposure Control Method | Program AE |
AE Lock | Available |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom |
Flash
Built-in Flash | Operation Modes: Auto, Red-Eye Reduction On/ Off, Slow-Sync |
Flash Range | 1.6 - 9.8 ft./ 47cm - 3.0m (WIDE); 1.6 - 6.6 ft./ 47cm - 2.0m (TELE); 11 - 18 in./ 27 - 47cm (Macro) (When ISO is speed is set to AUTO) |
Recycling Time | Approx. 10 sec. or less |
Shooting Specifications
Shooting Modes | Auto, Program, Manual, Stitch Assist, Movie. |
Photo Effects | Vivid color, Neutral color, Low sharpening, Sepia, Black & White |
Self Timer | Operates with approx. 2 sec. or approx 10 sec. count-down. |
Wireless Control | Not Available |
Continuous Shooting | Approx. 2.2 shots/sec. (Large/ Fine Mode and LCD monitor is Off) |
Image Storage
Storage Media | SD Memory Card |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still Image: JPEG (Exif 2.2 compliant) |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | Large: 2,048 x 1,536, Medium1: 1,600 x 1,200, Medium2: 1,024 x 768, Small: 640 x 480 pixels Movie: 640 x 480, 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
Movie data |  Individual movie clips are limited to 3 minutes maximum per clip. Above figures show total movie capacity on various SD memory cards, measured under Canon’s standard test conditions, and may vary depending upon scene, subjects or camera settings. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images), Magnification (2x to 10x), or Slide Show or Movie |
Erasing Specifications
Erase Modes | Still images: Single Image, All Images Movie: Part of movie, All movie |
Interfaces
Computer Interface | USB (mini-B jack) |
Video Out | NTSC or PAL |
Other | SD memory card slot. Direct connection to Canon CP Printers and select Bubble Jet Direct Photo Printers (no computer required), using camera's USB cable. |
Power Supply | 1. Rechargeable Lithium-ion battery (NB-3L) 2. Compact Power Adapter (CA-PS500 & DC Coupler DR-900) Important safety informationApprox. 180 shots (LCD monitor ON) Approx. 480 shots (LCD monitor OFF)(At 73°F/23°C, flash used for every fourth shot)Approx. 150 min. |
Power Source | 1. Rechargeable Lithium-ion battery (NB-3L) 2. Compact Power Adapter (CA-PS500 & DC Coupler DR-900) Important safety information |
Shooting Capacity | Approx. 180 shots (LCD monitor ON) Approx. 480 shots (LCD monitor OFF)(At 73°F/23°C, flash used for every fourth shot) |
Playback Time | Approx. 150 min. |
Physical Specifications
Operating Temperature | 32 - 104°F (0 - 40°C) |
Operating Humidity | 10 - 90% |
Dimensions (W x H x D) | 3.35 x 2.20 x 0.94 in./ 85 x 56 x 23.9mm (Excluding protrusions) |
Weight | Approx. 5.82 oz./ 165g (Camera body only) |
Computer System Requirements
Mac Requirements | Computer Model: Power Macintosh, PowerBook, eMac, iMac or iBook OS: Mac OS 9.0 - 9.2, Mac OS X (v10.1/ 10.2). CPU: PowerPC. Interface: USB (Models with Apple genuine USB interface only). |
PC Requirements | Computer Model: IBM PC/ AT compatible. OS: Microsoft Windows 98 (including Second Edition)/ Me/ 2000/ XP.CPU: Pentium 150MHz or higher processor (Windows 98/ Me/ 2000),Pentium 300MHz or higher processor (Windows XP). Interface: USB (Windows 98/ Me/ 2000/ XP pre-install model only). |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
