Canon Support for PowerShot SD1400 IS | Canon U.S.A., Inc.
PowerShot SD1400 IS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | 14.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD) |
Total Pixels | Approx. 14.5 Megapixels |
Effective Pixels | Approx. 14.1 Megapixels |
Focal Length | 5.0 (W) - 20.0 (T) mm (35mm film equivalent: 28 - 112mm) |
Digital Zoom | 4x |
Focusing Range | Normal: 1.2 in. (3 cm) - infinity (W), 2.6 ft. (80 cm) - infinity (T) Macro: 1.2 in - 1.6 ft (3 - 50 cm) (W) |
Autofocus System | TTL Autofocus |
Optical Viewfinder | N/A |
LCD Monitor | 2.7-inch TFT color LCD (wide viewing angle type) |
LCD Pixels | Approx. 230,000 pixels |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/2.8 (W) - f/5.9 (T) |
Shutter Speed | 1-1/1500 sec. 15-1/1500 sec. (Total shutter speed range); Long Shutter operates with noise reduction when manually set at 1.3 - 15 sec. Shutter speeds differ depending on the shooting modeShutter speeds available in Long Shutter: 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1 (unit: sec.) |
Sensitivity | Auto, ISO 80/100/200/400/800/1600 equivalent (Standard Output Sensitivity. Recommended Exposure Index) |
Light Metering Method | Evaluative*, Center-Weighted average, Spot** * Control to incorporate facial brightness in Face Detection AF ** Metering frame is fixed to the center |
Exposure Control Method | Program AE; i-Contrast; AE Lock |
Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom *Facial color is evaluated in Face AiAF. |
Built-in Flash | Auto, Red-eye Reduction, Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro |
Flash Range | 30 cm - 4.0 m (W), 50 cm - 2.0 m (T) (12 in. - 13 ft (W) 1.6 - 6.6 (T))Image brightness may diminish depending on the shooting distance |
Recycling Time | 10 sec. or less (battery voltage=3.7V) |
Flash Exposure Compensation | N/A |
Shooting Modes | Auto*, P, Portrait, Night Snapshot, Kids & Pets, Indoor, Smart Shutter **, Low Light, Color Accent, Color Swap, Fisheye Effect, Miniature Effect, Beach, Underwater, Foliage, Snow, Fireworks, Long Shutter, Stitch Assist, Movie*Automatically detects shooting scene**Smile, Wink Self-timer, Face Detection Self-timer |
Photo Effects | My Colors Off, Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom* *Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available. |
Self Timer | Activates shutter after an approx. 10 sec. delay/approx. 2-sec. delay/custom* *Shoot start time (0-10 sec. (in one-second increments), 15/20/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified. |
Wireless Control | N/A |
Continuous Shooting | Approx. 0.7 fps shots/sec. (approx. 2.6 shots/sec. in Low Light) |
Storage Media | SD/SDHC/SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card |
File Format | Design rule for camera file system, DPOF (Version 1.1) compliant |
Image Recording Format | Normal, Fine |
JPEG Compression Mode | Still Image: Exif 2.2 (JPEG) Movie: MOV (Image: H.264; Audio: Linear PCM (Monaural)) |
Number of Recording Pixels | Still Image: 4320 x 3240 (Large), 3456 x 2592 (Medium 1), 2592 x 1944 (Medium 2), 1600 x 1200 (Medium 3/Date Stamp), 640 x 480 (Small), 4320 x 2432 (Widescreen), 2144 x 1608 (Low Light)Movie: HD 1280 x 720 (30 fps available up to 10 min or 4GB per clip), 640 x 480 (30 fps) or 320 x 240 (30 fps) or 320 x 240 (30 fps) available up to 60 min. or 4GB per clip |
Image data |
Movie data | *Actual frame rate is 29.97 fps Note: N=Normal F=Fine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Modes File | - Easy, Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Filtered Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist) - Still Image: Single, Magnification (approx. 2x-10x), Auto Rotate, Rotate, Resume, My Colors, My Category, By Date, By Folder, By File Type, Transition Effects, Histogram, Overexposure Warning, Index (100 thumbnails), Slide Show, Red-eye Correction, Trimming, Resize, i-Contrast - Movie: Normal playback*, slow motion**, pause, first frame, last frame, next frame previous frame, fast forward, fast rewind Display playback position and shooting time.*Audio settings available in 5 levels. ** 5 levels (including normal playback), sound not available. |
Erase Modes | - Select image, all images (all filtered images)The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased)- Movies can be erased one at a time: select image, select range, select all images (all filtered images)Prevents still images and movies protected on camera (specify during playback from being deleted). |
Computer Interface | Hi-Speed USB (Dedicated connector (female) with unified type of digital, audio and video* * mini-B compatible. |
Video Out | NTSC/PAL |
Audio Out | Monaural |
Other | Mini-HDMI cable: connection to high definition monitor; SD Memory card slot: direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
Power Source | 1. Rechargeable Lithium-ion Battery NB-4L 2. AC Adapter Kit ACK-DC10 (optional) |
Shooting Capacity | Still Image: approx. 230 shots* |
Playback Time | Approx. 6 hours*. *LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.63 x 2.21 x 0.70 in. (92.2 x 56.1 x 17.8mm) |
Weight | Approx. 4.69 oz./133g (includes batteries and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi) All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
