Canon Support for PowerShot SD1400 IS | Canon U.S.A., Inc.
PowerShot SD1400 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 04.23.10
File Size 3.57 MB
Date 03.05.10
File Size 6.23 MB
Date 01.06.10
File Size 6.23 MB
Date 01.06.10
File Size 1.52 MB
Date 01.06.10
File Size 6.07 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
14.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 14.5 Megapixels
Effective Pixels
Approx. 14.1 Megapixels
Focal Length
5.0 (W) - 20.0 (T) mm (35mm film equivalent: 28 - 112mm)
Digital Zoom
4x
Focusing Range
Normal: 1.2 in. (3 cm) - infinity (W), 2.6 ft. (80 cm) - infinity (T)
Macro: 1.2 in - 1.6 ft (3 - 50 cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
2.7-inch TFT color LCD (wide viewing angle type)
LCD Pixels
Approx. 230,000 pixels
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W) - f/5.9 (T)
Shutter Speed
1-1/1500 sec.
15-1/1500 sec. (Total shutter speed range); Long Shutter operates with noise reduction when manually set at 1.3 - 15 sec. Shutter speeds differ depending on the shooting modeShutter speeds available in Long Shutter: 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1 (unit: sec.)
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent (Standard Output Sensitivity. Recommended Exposure Index)
Light Metering Method
Evaluative*, Center-Weighted average, Spot**
* Control to incorporate facial brightness in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Program AE; i-Contrast; AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
*Facial color is evaluated in Face AiAF.
Built-in Flash
Auto, Red-eye Reduction, Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro
Flash Range
30 cm - 4.0 m (W), 50 cm - 2.0 m (T) (12 in. - 13 ft (W) 1.6 - 6.6 (T))Image brightness may diminish depending on the shooting distance
Recycling Time
10 sec. or less (battery voltage=3.7V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto*, P, Portrait, Night Snapshot, Kids & Pets, Indoor, Smart Shutter **, Low Light, Color Accent, Color Swap, Fisheye Effect, Miniature Effect, Beach, Underwater, Foliage, Snow, Fireworks, Long Shutter, Stitch Assist, Movie*Automatically detects shooting scene**Smile, Wink Self-timer, Face Detection Self-timer
Photo Effects
My Colors Off, Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom*
*Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available.
Self Timer
Activates shutter after an approx. 10 sec. delay/approx. 2-sec. delay/custom*
*Shoot start time (0-10 sec. (in one-second increments), 15/20/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Approx. 0.7 fps shots/sec. (approx. 2.6 shots/sec. in Low Light)
Storage Media
SD/SDHC/SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format
Design rule for camera file system, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: MOV (Image: H.264; Audio: Linear PCM (Monaural))
Number of Recording Pixels
Still Image: 4320 x 3240 (Large), 3456 x 2592 (Medium 1), 2592 x 1944 (Medium 2), 1600 x 1200 (Medium 3/Date Stamp), 640 x 480 (Small), 4320 x 2432 (Widescreen), 2144 x 1608 (Low Light)Movie: HD 1280 x 720 (30 fps available up to 10 min or 4GB per clip), 640 x 480 (30 fps) or 320 x 240 (30 fps) or 320 x 240 (30 fps) available up to 60 min. or 4GB per clip
Image data
Movie data
*Actual frame rate is 29.97 fps
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
- Easy, Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Filtered Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist)
- Still Image: Single, Magnification (approx. 2x-10x), Auto Rotate, Rotate, Resume, My Colors, My Category, By Date, By Folder, By File Type, Transition Effects, Histogram, Overexposure Warning, Index (100 thumbnails), Slide Show, Red-eye Correction, Trimming, Resize, i-Contrast
- Movie: Normal playback*, slow motion**, pause, first frame, last frame, next frame previous frame, fast forward, fast rewind Display playback position and shooting time.*Audio settings available in 5 levels.
** 5 levels (including normal playback), sound not available.
Erase Modes
- Select image, all images (all filtered images)The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased)- Movies can be erased one at a time: select image, select range, select all images (all filtered images)Prevents still images and movies protected on camera (specify during playback from being deleted).
Computer Interface
Hi-Speed USB (Dedicated connector (female) with unified type of digital, audio and video*
* mini-B compatible.
Video Out
NTSC/PAL
Audio Out
Monaural
Other
Mini-HDMI cable: connection to high definition monitor; SD Memory card slot: direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1. Rechargeable Lithium-ion Battery NB-4L
2. AC Adapter Kit ACK-DC10 (optional)
Shooting Capacity
Still Image: approx. 230 shots*
Playback Time
Approx. 6 hours*.
*LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.63 x 2.21 x 0.70 in. (92.2 x 56.1 x 17.8mm)
Weight
Approx. 4.69 oz./133g (includes batteries and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
