Canon Support for PowerShot SD3500 IS | Canon U.S.A., Inc.
PowerShot SD3500 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.05.10
File Size 6.23 MB
Date 01.06.10
File Size 6.23 MB
Date 01.06.10
File Size 1.52 MB
Date 01.06.10
File Size 6.07 MB
Date 04.23.10
File Size 3.42 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
14.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 14.5 Megapixels
Effective Pixels
Approx. 14.1 Megapixels
Focal Length
4.3 (W) - 21.5 (T) mm (35mm equivalent: 24 - 120mm)
Digital Zoom
4x
Focusing Range
Normal: 2.0 in./5 cm - infinity, 3.0 ft./90cm (T) - infinity
Macro: 2.0 in. - 1.6 ft./5 - 50cm (W) - infinity
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
3.5-inch LCD with wide viewing angle and Touch Panel Technology
LCD Pixels
Approx. 461,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W) - f/5.9 (T)
Shutter Speed
1 - 1/3000 sec.
15 - 1/3000 sec. (Total shutter speed range), Long Shutter operates with noise reduction when manually set at 1.3 - 15 sec. Shutter speeds differ depending on the shooting mode Shutter speeds available in Long Shutter: 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1 (unit: sec.)
Sensitivity
Auto*, ISO 80/100/200/400/800/1600 equivalent (Standard output sensitivity. Recommended exposure index)
* Camera automatically sets the optical ISO speed according to the shooting mode and subject brightness. The ISO speed also varies according to subject movement and camera shake when the shooting mode is set in Auto.
Light Metering Method
Evaluative*, Center-Weighted average, Spot**
* Facial brightness is also evaluated in Face AiAF
** Metering frame is fixed to the center
Exposure Control Method
Program AE; i-Contrast; AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Facial color is evaluated in Face AiAF
Built-in Flash
Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro
Flash Range
1.6 - 11 ft./50cm - 3.5m (W), 3.0 - 6.6 ft./90cm - 2.0m (T) Image brightness may diminish depending on the shooting distance.
Recycling Time
12 sec. or less (battery voltage=3.7V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto*, P, Portrait, Night Snapshot, Kids & Pets, Indoor, Smart Shutter*, Low Light, Color Accent, Color Swap, Fisheye Effect, Miniature Effect, Creative Light Effect, Beach, Foliage, Snow, Fireworks, Long Shutter, Movie*Automatically detects shooting scene**Smile, Wink Self-timer, Face Detection Self-timer
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom*
*Adjustment of contrast, sharpness saturation red, green, blue and skin tone are available.
Self Timer
Approx. 10 sec. delay/approx. 2-sec. delay custom*
*Shooting start time (0-10 sec. (in 1-second increments) 15/20/30 sec.) and number of shots (1-10 shots (in 1-shot increments) can be specified.
Wireless Control
N/A
Continuous Shooting
Approx. 0.7 shots/sec (approx. 2.7 shots/sec. in Low Light)
Storage Media
SD/SDHC/SDXC Memory Card, MultiMediaCard, MMCplus Card, HC MMCplus Card
File Format
Design rule for camera file system, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: MOV (Image: H.264; Audio: Linear PCM (Monaural))
Number of Recording Pixels
Still Image: 4,320 x 3,240 (Large), 3,456 x 2,592 (Medium 1), 2,592 x 1,944 (Medium 2), 1,600 x 1,200 (Medium 3/Date Stamp), 640 x 480 (Small), 4,320 x 2,432 (Widescreen), 2,144 x 1,608 (Low Light)Movie: HD 1,280 x 720 (30 fps available up to 10 min. or 4GB per clip), 640 x 480 (30 fps), 320 x 240 (30 fps) available up to 60 minutes or 4GB per clip
Image data
Movie data
*Actual frame rate is 29.97 fps
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
- Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display, Active Display), Rotate, Favorites, My Category, Smart Shuffle, Filtered Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist)
- Still Image: Single, Magnification (approx. 2x-10x), Auto Rotate, Rotate, Resume, My Colors, My Category, Transition Effects (3 types), Histogram, Overexposure Warning, Index (4 - 130 thumbnails), Slide Show, Red-eye Correction, Trimming, Resize, i-Contrast
- Movie: Normal Playback, Special Playback, Editing, Resume *Auto settings available in 5 levels
**5 levels (including normal playback), sound not available.
Erase Modes
Still Image: Select image, select all images (all filtered images)
Movie: part of movie, all of movie
Computer Interface
Hi-Speed USB (Dedicated connector (female) with unified type of digital, audio, and video*) HDMI (HDMITM mini connector)
* mini-B compatible.
Video Out
NTSC/PAL (Dedicated connector (female) with unified type of digital, audio, and video)
Audio Out
Monaural
Other
SD Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
1. Rechargeable Lithium-ion Battery NB-6L
2. AC Adapter Kit ACK-DC40 (optional)Still Image: approx. 220 shots*
*LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. Approx. 5 hours.
* LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source
Shooting Capacity
Playback Time
Approx. 5 hours.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.91 x 2.20 x 0.87 in./99.3 x 55.7 x 22.0 mm
Weight
Approx. 5.64 oz./160g (including batteries and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
