Canon Support for PowerShot SD4000 IS | Canon U.S.A., Inc.
PowerShot SD4000 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 05.11.10
File Size 9.45 MB
Date 05.19.10
File Size 6.23 MB
Date 05.19.10
File Size 1.52 MB
Date 05.19.10
File Size 6.07 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
10.0 Megapixel 1/2.3-inch CMOS
Total Pixels
Approx. 10.6 Megapixels
Effective Pixels
Approx. 10.0 Megapixels
Focal Length
4.9 (W) - 18.6 (T) mm (35 mm film equivalent: 28 (W) - 105 (T) mm)
Digital Zoom
Approx. 4.0x (Up to approx. 15x in combination with the optical zoom)Still images: not available when the recording pixel setting is W.Movies: optical zoom not available while shooting.
Focusing Range
Normal AF: 1.2 in. (3 cm) - infinity (W), 12 in. (30 cm) - infinity (T);
Macro AF: Macro: 1.2 in. - 1.6 ft. (3 - 50 cm) (W), 12 in. - 1.6 ft. (30 - 50 cm) (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch TFT color LCD, with wide viewing angle
LCD Pixels
Approx. 230,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.0 (W) / f/5.3 (T)
The following f/numbers are available in Av:W: f/2.0/2.2/2.5/2.8/3.2/3.5/4.0/4.5/5.0/5.6/6.3/7.1/8.0T: f/5.3/5.6/6.3/7.1/8.0
Shutter Speed
1 - 1/2500 sec.
15 - 1/2500 sec. (Total shutter speed range)Shutter speeds differ depending on the shooting mode.Shutter speeds available in Tv mode:
15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 0.8, 0.6, 0.5, 0.4, 0.3, 1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80, 1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000,1/1250, 1/1600, 1/2000 (Unit: sec.)
Sensitivity
Auto*, ISO 125/200/400/800/1600/3200
* Camera automatically sets the optimal ISO speed according to shooting mode.
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face AiAF.
** Fixed to center.
Exposure Control Method
AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
*Facial color is evaluated in Face AiAF.
Built-in Flash
Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro, Smart Flash
Flash Range
30 cm - 6.0 m (W), 50 cm - 2.0 m (T) (12 in. - 20 ft. (W), 1.6 - 6.6 ft. (T))Image brightness may diminish depending on the shooting distance.
Recycling Time
10 sec. or less (battery voltage: 3.7 V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto*, Av, Tv, P, Portrait, Night Snapshot, Kids &amp; Pets, Indoor, Smart Shutter**, High-Speed Burst, Low Light, Color Accent, Color Swap, Fisheye Effect, Miniature Effect, Beach, Foliage, Snow, Fireworks, Stitch Assist, Movie
* Automatically detects shooting scene
** Smile, Wink Self-Timer, Face Self-Timer
Photo Effects
My Colors Off/Vivid/Neutral/Sepia/Black &amp; White/Positive Film/Lighter Skin/Darker Skin/Vivid Blue/Vivid Green/Vivid Red/Custom Color*
* Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available.
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
* Shooting start time (0 - 10 sec. (in one-second increments), 15/20/30 sec.) and number of shots (1 - 10 shots (in one-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Normal: Approx. 3.7 shots/sec.*
Low Light: Approx. 6.0 shots/sec.*
High-Speed Burst: Approx. 8.4 shots/sec.**Speed varies depending on zoom position * Depending on the shooting conditions, the camera settings and the zoom position, the shooting speed may slow down. As the number of images increases, the shooting speed may slow down.
** Depending on the shooting conditions, camera settings and the zoom position, the shooting speed may slow down. As the number of images increases, the shooting interval may take longer.
Storage Media
SD memory card, SDHC memory card, SDXC memory card, MultiMediaCard, MMCplus card, HC MMCplus card, Eye-Fi card
File Format
Design rule for camera file system, DPOF Version 1.1 compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: MOV (Image: Motion JPEG; Audio: Linear PCM (Stereo))
Number of Recording Pixels
Large: 3648 x 2736, Medium 1: 2816 x 2112
Medium 2: 2272 x 1704, Medium 3: 1600 x 1200
Small: 640 x 480, Widescreen: 3648 x 2048Low Light and High-speed Burst 1824 x 1368
Image data
Movie data
*Actual frame rate is 29.97 fps
**Actual frame rate is 239.76 fps
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated fromCanon's standard shooting conditions. Figures for Movie Mode represent total capacityof the particular media.
Playback Modes File
- Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Jump, Smart Shuffle, Filtered Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist)
- Still Images: Single, Index, Magnification, Information Display, Red-eye Correction, i-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure Warning
- Movies: Normal Playback*, Slow Motion**, Special Playback, Editing, Resume
* Auto settings available in 5 levels
** 5 levels (including normal playback), sound not available.
Erase Modes
Select image, select range, all images (all filtered images)
- The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).- Using the Movie editing function, sections of the movie (1 sec. increments) can be deleted.
Computer Interface
USB 2.0 Hi-Speed USB (dedicated female connector with unified type of digital, audio and video*)
*mini-B compatible.
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Audio Out
Stereo (dedicated connector (female) with unified type of digital, audio and video)
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
Battery Pack NB-6L, AC Adapter ACK-DC40Approx. 250 shotsApprox. 7 hours.
Power Source
Shooting Capacity
Approx. 250 shots
Playback Time
Approx. 7 hours.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.94 x 2.13 x 0.93 in./100.0 x 54.1 x 23.6 mm
Weight
Approx. 6.17 oz./175g (camera, including batteries and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Russian, Portuguese, Greek, Polish, Czech, Hungarian, Turkish,Traditional Chinese, Korean, Thai, Arabic, Romanian, Ukrainian, Farsi and Japanese)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
