Canon Support for PowerShot SD450 | Canon U.S.A., Inc.
PowerShot SD450
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash, 3x Optical/4x Digital/12x Combined Zoom |
Image Capture Device
Type | 5.0 Megapixel, 1/2.5 inch type Charge Coupled Device (CCD) |
Total Pixels | Approx. 5.3 Megapixels |
Effective Pixels | Approx. 5.0 Megapixels |
Lens
Focal Length | 5.8-17.4mm f/2.8-4.9 zoom lens (equivalent to 35-105mm in 35mm format) |
Digital Zoom | 4x |
Focusing Range | Normal AF: 1.0 ft./30cm-infinity Macro AF: 1.2 in.-1.6 ft./3-50cm (WIDE), 1.0-1.6 ft./30-50cm (TELE) Digital Macro: 1.2-3.9 in./3-10cm (WIDE) |
Autofocus System | TTL Autofocus (continuous/single) |
Viewfinders
Optical Viewfinder | Real-image optical zoom viewfinder |
LCD Monitor | 2.5 inch low-temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approx. 115,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.8 (W) - f/4.9 (T) |
Shutter Speed | 15-1/1500 sec.; Slow shutter operates with noise reduction when manually set at 1.3-15 sec. |
Exposure Control
Sensitivity | AUTO, ISO 50/100/200/400 equivalent |
Light Metering Method | Evaluative, Center-weighted average, Spot* * Metering frame with Spot Mode is fixed to center or linked to AF frame. |
Exposure Control Method | Program AE AE Lock is available |
Exposure Compensation | +/- 2 stops in 1/3-stop increments |
White Balance
White Balance Control | Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), Custom |
Flash
Built-in Flash | Operation Modes: Auto, On/Off, Red-Eye Reduction On/Off, Slow Synchro |
Flash Range | Normal: 1.6-12 ft./50cm - 3.5m (W), 1.6-6.7 ft./50cm - 2.0m (T)Macro: 1.0-1.6 ft./30-50cm (W/T) (When ISO is set to Auto) |
Recycling Time | Approx. 10 sec. or less (battery voltage=3.7V) |
Flash Exposure Compensation | Not available |
Shooting Specifications
Shooting Modes | Auto; Manual, Special Scene (Portrait, Night Snapshot, Foliage, Snow, Beach, Fireworks, Underwater, Indoor, Kids & Pets), Digital Macro, My Colors, Stitch Assist, Movie |
Photo Effects | Vivid, Neutral, Low Sharpening, Sepia, Black & White |
Self Timer | Activates shutter after an approx. 2 sec./10 sec. delay, Custom |
Wireless Control | Not available |
Continuous Shooting | Approx. 2.1 fps |
Image Storage
Storage Media | SD Memory Card, MultiMediaCard |
File Format | Design rule for camera file system, DPOF Version 1.1 (Digital Print Order Format) |
Image Recording Format | Still Image: Exif 2.2 (JPEG) Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural)) |
JPEG Compression Mode | Normal, Fine, SuperFine |
Number of Recording Pixels | Still Image: 2,592 x 1,944 (Large), 2,048 x 1,536 (Medium 1), 1,600 x 1,200 (Medium 2), 640 x 480 (Small) Movie: 640 x 480/320 x 240 (30 fps/15 fps), 320 x 240 (1 min. at 60 fps), 160 x 120 (3 min. at 15 fps) |
Number of Recordable Images
Image data | |
Description | Note: N=Normal F=Fine SF=SuperFine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Time of Recordable Movies
Movie data | Note: N=Normal F=Fine SF=SuperFine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Specifications
Playback Modes File | Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotation, Histogram, Index (9 thumbnail images), Sound Memos, Slide Show Movie: Normal Playback, Special Playback, Editing |
Erasing Specifications
Erase Modes | Still Image: Single image, All images Movie: Part of movie, All of movie |
Interfaces
Computer Interface | USB 2.0 Hi-Speed |
Video Out | NTSC/PAL |
Audio Out | Monaural |
Other | Memory card slot. Direct connection to Canon CP, SELPHY, PIXMA Photo Printers and PictBridge compatible printers via camera's USB cable. |
Power Supply | 1. Rechargeable Lithium Battery NB-4L 2. AC Adapter Kit ACK-DC10Still Image: approx. 150 shots (NB-4L/LCD on), approx. 500 shots (NB-4L/LCD off)* * CIPA standardApprox. 180 min. (NB-4L)* * Canon Standard Test Methods. |
Power Source | 1. Rechargeable Lithium Battery NB-4L 2. AC Adapter Kit ACK-DC10 |
Shooting Capacity | Still Image: approx. 150 shots (NB-4L/LCD on), approx. 500 shots (NB-4L/LCD off)* * CIPA standard |
Playback Time | Approx. 180 min. (NB-4L)* * Canon Standard Test Methods. |
Physical Specifications
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.39 (W) x 2.11 (H) x 0.85 (D) in /86.0 (W) x 53.5 (H) x 21.6 (D) mm |
Weight | Approx. 4.93 oz./140g (camera body only) |
Computer System Requirements
Mac Requirements | Mac OS X (v10.2-10.4) Computer Model: The above OS should be pre-installed on computers with built-in USB ports CPU: PowerPC G3, G4 or G5 Interface: USB (Models with Apple genuine USB interface only) |
PC Requirements | Microsoft Windows 98 Second Edition/Me/2000 SP4/XP (including SP1 and SP2) Computer Model: The above OS should be pre-installed on computers with built-in USB ports CPU: Pentium 500MHz or higher processor Interface: USB (Windows 98/Me/2000/XP pre-installed models only) |
Note: 22 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai) All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, PowerShot, ELPH and DIGIC are registered trademarks, and SELPHY and PIXMA are trademarks, of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and the Windows logo are trademarks or registered trademarks of the Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple Computer, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
