Canon Support for PowerShot SD450 | Canon U.S.A., Inc.
PowerShot SD450
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.05.10
File Size 6.23 MB
Date 10.25.07
File Size 11.57 MB
Date 05.23.08
File Size 1.60 MB
Date 10.25.07
File Size 1.60 MB
Date 10.25.07
File Size 316.36 KB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash, 3x Optical/4x Digital/12x Combined Zoom
Image Capture Device
Type 5.0 Megapixel, 1/2.5 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 5.3 Megapixels
Effective Pixels Approx. 5.0 Megapixels
Lens
Focal Length 5.8-17.4mm f/2.8-4.9 zoom lens (equivalent to 35-105mm in 35mm format)
Digital Zoom 4x
Focusing Range Normal AF: 1.0 ft./30cm-infinity
Macro AF: 1.2 in.-1.6 ft./3-50cm (WIDE), 1.0-1.6 ft./30-50cm (TELE)
Digital Macro: 1.2-3.9 in./3-10cm (WIDE)
Autofocus System TTL Autofocus (continuous/single)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 2.5 inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 115,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 (W) - f/4.9 (T)
Shutter Speed 15-1/1500 sec.; Slow shutter operates with noise reduction when manually set at 1.3-15 sec.
Exposure Control
Sensitivity AUTO, ISO 50/100/200/400 equivalent
Light Metering Method Evaluative, Center-weighted average, Spot*
* Metering frame with Spot Mode is fixed to center or linked to AF frame.
Exposure Control Method Program AE
AE Lock is available
Exposure Compensation +/- 2 stops in 1/3-stop increments
White Balance
White Balance Control Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), Custom
Flash
Built-in Flash Operation Modes: Auto, On/Off, Red-Eye Reduction On/Off, Slow Synchro
Flash Range Normal: 1.6-12 ft./50cm - 3.5m (W), 1.6-6.7 ft./50cm - 2.0m (T)Macro: 1.0-1.6 ft./30-50cm (W/T) (When ISO is set to Auto)
Recycling Time Approx. 10 sec. or less (battery voltage=3.7V)
Flash Exposure Compensation Not available
Shooting Specifications
Shooting Modes Auto; Manual, Special Scene (Portrait, Night Snapshot, Foliage, Snow, Beach, Fireworks, Underwater, Indoor, Kids & Pets), Digital Macro, My Colors, Stitch Assist, Movie
Photo Effects Vivid, Neutral, Low Sharpening, Sepia, Black & White
Self Timer Activates shutter after an approx. 2 sec./10 sec. delay, Custom
Wireless Control Not available
Continuous Shooting Approx. 2.1 fps
Image Storage
Storage Media SD Memory Card, MultiMediaCard
File Format Design rule for camera file system, DPOF Version 1.1 (Digital Print Order Format)
Image Recording Format Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural))
JPEG Compression Mode Normal, Fine, SuperFine
Number of Recording Pixels Still Image: 2,592 x 1,944 (Large), 2,048 x 1,536 (Medium 1), 1,600 x 1,200 (Medium 2), 640 x 480 (Small)
Movie: 640 x 480/320 x 240 (30 fps/15 fps), 320 x 240 (1 min. at 60 fps), 160 x 120 (3 min. at 15 fps)
Number of Recordable Images
Image data
Description Note: N=Normal F=Fine SF=SuperFine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Time of Recordable Movies
Movie data Note: N=Normal F=Fine SF=SuperFine
Playback Specifications
Playback Modes File Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotation, Histogram, Index (9 thumbnail images), Sound Memos, Slide Show
Movie: Normal Playback, Special Playback, Editing
Erasing Specifications
Erase Modes Still Image: Single image, All images
Movie: Part of movie, All of movie
Interfaces
Computer Interface USB 2.0 Hi-Speed
Video Out NTSC/PAL
Audio Out Monaural
Other Memory card slot. Direct connection to Canon CP, SELPHY, PIXMA Photo Printers and PictBridge compatible printers via camera's USB cable.
Power Supply 1. Rechargeable Lithium Battery NB-4L
2. AC Adapter Kit ACK-DC10Still Image: approx. 150 shots (NB-4L/LCD on), approx. 500 shots (NB-4L/LCD off)*
* CIPA standardApprox. 180 min. (NB-4L)*
* Canon Standard Test Methods.
Power Source 1. Rechargeable Lithium Battery NB-4L
Shooting Capacity Still Image: approx. 150 shots (NB-4L/LCD on), approx. 500 shots (NB-4L/LCD off)*
* CIPA standard
Playback Time Approx. 180 min. (NB-4L)*
Physical Specifications
Operating Temperature 32-104&deg;F/0-40&deg;C
Operating Humidity 10-90%
Dimensions (W x H x D) 3.39 (W) x 2.11 (H) x 0.85 (D) in /86.0 (W) x 53.5 (H) x 21.6 (D) mm
Weight Approx. 4.93 oz./140g (camera body only)
Computer System Requirements
Mac Requirements Mac OS X (v10.2-10.4)
Computer Model: The above OS should be pre-installed on computers with built-in USB ports
CPU: PowerPC G3, G4 or G5
Interface: USB (Models with Apple genuine USB interface only)
PC Requirements Microsoft Windows 98 Second Edition/Me/2000 SP4/XP (including SP1 and SP2)
CPU: Pentium 500MHz or higher processor
Interface: USB (Windows 98/Me/2000/XP pre-installed models only)
Note: 22 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai)
All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, PowerShot, ELPH and DIGIC are registered trademarks, and SELPHY and PIXMA are trademarks, of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and the Windows logo are trademarks or registered trademarks of the Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple Computer, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
