Canon Support for PowerShot SD940 IS | Canon U.S.A., Inc.
PowerShot SD940 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3 inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 12.4 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
5.0 (W) - 20.0 (T) mm (35mm equivalent: 28 (W) - 112 (T) mm)
Digital Zoom
4x
Focusing Range
Normal: 1.0 ft./30cm-infinity (W), 1.6 ft./50 cm-infinity (T)
Macro: 1.2 in.-1.6 ft./3-50cm (W)
Digital Macro: 1.2-3.9 in./3-10cm (W)
Autofocus System
TTL Autofocus
LCD Monitor
2.7-inch TFT color LCD widescreen with wide viewing angle
LCD Pixels
Approx. 230,000 dots
LCD Coverage
100%
Maximum Aperture
f/2.8 (W) - f/5.9 (T)
Shutter Speed
15-1/1500 sec.; Long Shutter operates with noise reduction when manually set at 1-15 sec.
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent (Standard output sensitivity. Recommended exposure index)
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face AiAF
** Metering frame is fixed to the center
Exposure Control Method
Program AE, i-Contrast; AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
*The color of the faces is evaluated in Face AiAF
Built-in Flash
Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro
Flash Range
1-13 ft./30cm-4.0m (W), 1.6-6.6 ft./50cm-2.0m (T) (when sensitivity is set to ISO Auto)
Recycling Time
10 sec. or less (battery voltage=3.7V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto, Program, Portrait, Foliage, Snow, Beach, Sunset, Fireworks, Aquarium, Underwater, ISO 3200, Indoor, Kids & Pets, Night Snapshot, Color Accent, Color Swap, Digital Macro, Long Shutter, Stitch Assist, Movie
Photo Effects
My Colors
My Colors Off, Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom
Self Timer
Activates shutter after an approx. 2-sec./10-sec. delay, Face Detection Self-timer
Wireless Control
Not available
Continuous Shooting
Approx. 0.8 fps
Storage Media
SD/SDHC Memory Card, MultiMediaCard, MMCplus card, HC MMCplus card
File Format
Design rule for camera file system, DPOF Version 1.1
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: MOV (Image: H.264; Audio: Linear PCM (Monaural))
Number of Recording Pixels
Still Image: 4,000 x 3,000 (Large), 3,264 x 2,448 (Medium 1), 2,592 x 1,944 (Medium 2), 1,600 x 1,200 (Medium 3/Date Stamp), 640 x 480 (Small), 4,000 x 2,248 (Widescreen)
Movie: High Definition: 1,280 x 720 (30 fps); Standard Definition: 640 x 480 (30 fps), 320 x 240 (30 fps)
Available up to 4GB or 10 min. (HD)/60 min. (SD) per clip
Image data
Movie data
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
Still Image: Single, Magnification (approx. 2x-10x), Auto Rotate, Rotate, Resume, My Colors, My Category, By Date, By Folder, By File Type, Transition Effects, Histogram, Overexposure Warning, Index (4-130 thumbnails), Slide Show, Red-eye Correction, Trimming, Resize, Image Inspection Tool, i-Contrast
Erase Modes
Still Image: single image, select range, select by date, select by category, select by folder, all images
Movie: part of movie, all of movie
Computer Interface
USB 2.0 Hi-Speed (mini-B jack)
Video Out
NTSC/PAL
Audio Out
Monaural
Other
Mini-HDMI cable: connection to high definition monitor; Memory card slot: direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
1. Rechargeable Lithium-ion Battery NB-4L.AC Adapter Kit ACK-DC10 (optional)Still Image: approx. 220 shots*Approx. 360 min. * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source
Shooting Capacity
Playback Time
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.52 x 2.16 x 0.79/89.5 x 54.9 x 20.0 mm
Weight
Approx. 120 g (4.23 oz.) (camera body only)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
