Canon Support for PowerShot SX120 IS | Canon U.S.A., Inc.
PowerShot SX120 IS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Type | 10.0 Megapixel, 1/2.5-inch type Charge Coupled Device (CCD) |
| Total Pixels | Approx. 10.3 Megapixels |
| Effective Pixels | Approx. 10.0 Megapixels |
| Focal Length | 6.0 (W) - 60.0mm (T) f/2.8 (W) - f/4.3 (T) (35mm equivalent: 36 (W) - 360 (T) mm) |
| Digital Zoom | 4x |
| Focusing Range | Normal: 1.6 ft./50cm-infinity (W), 3.3 ft./1m-infinity (T) Macro: 0.4 in.-1.6 ft./1-50cm (W) |
| Autofocus System | TTL Autofocus |
| Optical Viewfinder | None |
| LCD Monitor | 3.0-inch low-temperature polycrystalline silicon TFT color LCD with wide viewing angle |
| LCD Pixels | Approx. 230,000 pixels |
| LCD Coverage | 100% |
| Maximum Aperture | f/2.8 (W) - f/4.3 (T) |
| Shutter Speed | 15-1/2500 sec. (settable in Tv and M) |
| Sensitivity | Auto, ISO 80/100/200/400/800/1600 equivalent (Subject movement is taken into account while shooting in Auto and Easy modes) |
| Light Metering Method | Evaluative*, Center-weighted average, spot** * Facial brightness is also evaluated in Face Detect AF ** Fixed to center |
| Exposure Control Method | Program AE, Manual; AE Lock, Program Shift, Safety Shift, Auto ISO Shift |
| Exposure Compensation | +/-2 stops in 1/3-stop increments |
| White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom *The color of faces is evaluated in Face Detect |
| Built-in Flash | Auto, Auto w/Red-eye Reduction, Flash On, Flash On w/Red-eye Reduction, Flash Off; FE lock, Safety FE, Slow Synchro |
| Flash Range | 50 cm - 4.0 m (W), 1.0 cm - 2.5 m (T) (1.6 - 13 ft. (W), 3.3 - 8.2 ft. (T)) |
| Recycling Time | 12 sec. or less (battery voltage: 3.0 V) - LCD monitor is turned off during flash charging (Except when turning on the power) |
| Flash Exposure Compensation | +/-2 stops in 1/3-stop increments |
| Shooting Modes | Auto*, P, Av, Tv, M, Easy, Portrait, Landscape, Special Scene (Foliage, Snow, Beach, Sunset, Fireworks, Aquarium, ISO 3200), Indoor, Kids & Pets, Night Snapshot, Movie, Night Scene * Automatically detects the shooting scene. |
| Photo Effects | My Colors My Colors Off, Vivid, Neutral, Sepia, Black & White, Custom Color* *Adjustment of contrast, sharpness and saturation is available. - Saving original image is not available. |
| Self Timer | Activates shutter after an approx. 2-sec./10-sec. delay, Custom*, Face Self-Timer** * Shooting start time (0-10 sec. (in 1-second increments), 15/20/30 sec.) and number of shots (1-10 (in one-shot increments)) can be specified. ** When the number of detected faces increases, the shutter is released after 2 sec. delay. However, if no face is detected for 30 seconds or more, the shooting operation starts automatically. |
| Wireless Control | Not available |
| Continuous Shooting | Normal: approx. 1.3 fps; AF: approx. 0.9 fps; LV: approx. 0.9 fps |
| Storage Media | SD/SDHC memory card, MultiMediaCard, MMCplus card, HC MMCplus card |
| File Format | Design rule for camera file system, DPOF (Version 1.1) compliant |
| Image Recording Format | Normal, Fine |
| JPEG Compression Mode | Still Image: Exif 2.2 (JPEG) Movie: AVI (Image data: Motion JPEG; Audio data: WAVE (Monaural)) |
| Number of Recording Pixels | Still Image: 3,648 x 2,736 (Large), 2,816 x 2,112 (Medium 1), 2,272 x 1,704 (Medium 2), 1,600 x 1,200 (Medium 3), 640 x 480 (Small), 3,648 x 2,048 (Widescreen) Movie: 640 x 480 (30 fps/30 fps LP), 320 x 240 (30 fps) available up to 4GB or 60 minutes per clip. - Data stamp is available in all recording pixels |
| Image data |
| Movie data | Note: N=Normal, F=Fine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
| Playback Modes File | Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Category, Transition Effects, Histogram, Index (4-100 thumbnails), Over Exposure Warning, Slide Show, Red-eye Correction, Resize, Easy; Movie: Normal Playback, Special Playback, Auto Rotate, Resume, Easy |
| Erase Modes | Still Image: single image, select all images - The image data stored in the memory card with the design rule for camera file systems format can be erased. However, protected images cannot be erased) Movie: any movie file (files must be erased one at a time) |
| Computer Interface | Hi-Speed USB* (dedicated connector (female) with unified type of digital audio and video** * Use of USB logomark is not allowed. ** mini-B compatible. |
| Video Out | NTSC or PAL |
| Audio Out | Monaural |
| Other | Memory card slot; direct connection to Canon and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
| Power Supply | 1. AA-size Alkaline Battery (x2) 2. Rechargeable AA-size NiMH Battery NB-3AH (x2) 3. AC Adapter Kit ACK-800 (optional)Still Image: approx. 130 shots (AA-size Alkaline Battery), approx. 370 shots (AA-size Ni-MH Battery)*Approx. 7 hrs. (AA-size Alkaline Battery), approx. 9 hrs. (AA-size Ni-MH Battery) *LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
| Power Source | 1. AA-size Alkaline Battery (x2) 2. Rechargeable AA-size NiMH Battery NB-3AH (x2) 3. AC Adapter Kit ACK-800 (optional) |
| Shooting Capacity | Still Image: approx. 130 shots (AA-size Alkaline Battery), approx. 370 shots (AA-size Ni-MH Battery)* |
| Playback Time | Approx. 7 hrs. (AA-size Alkaline Battery), approx. 9 hrs. (AA-size Ni-MH Battery) *LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
| Operating Temperature | 32-104°F/0-40°C |
| Operating Humidity | 10-90% |
| Dimensions (W x H x D) | 4.35 x 2.77 x 1.76 in./110.6 x 70.4 x 44.7mm |
| Weight | Approx. 8.64 oz./245g (camera body only)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
