Canon Support for PowerShot SX130 IS | Canon U.S.A., Inc.
PowerShot SX130 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.26.10
File Size 10.19 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3 inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 12.4 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
5.0 (W) - 60.0 (T) mm (35mm film equivalent: 28 (W) - 336 (T) mm)
Digital Zoom
4x
Focusing Range
Auto: 0.4 in. (1cm) - infinity (W), 3.3 ft. (1m) - infinity (T)
Normal: 2.0 in. (5 cm) - infinity (W), 3.3 ft. (1m) - infinity (T)
Macro: 0.4 in. - 1.6 ft. (1- 50cm) (W)
Manual Focus: 0.4 in. (1cm) - infinity (W), 3.3 ft (1m) - infinity (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
None
LCD Monitor
3.0-inch low-temperature polycrystalline silicon TFT color LCD with wide viewing angle
LCD Pixels
Approx. 230,000 pixels
LCD Coverage
100%
Maximum Aperture
f/3.4 (W) - f/5.6 (T)
Shutter Speed
1 - 1/2500 sec.
15-1/2500 sec. (Total shutter speed range)Shutter speeds differ depending on the shooting modeShutter speeds available in Tv and M:
15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 0.8, 0.6, 0.5, 0.4, 0.3,1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80,1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000,1/1250, 1/1600, 1/2000, 1/2500
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent
(Subject movement is taken into account while shooting in Auto and Easy modes)
Light Metering Method
Evaluative*1, Center-weighted average, spot*2
*1 Facial brightness is also evaluated in Face Detect AF
*2 Fixed to center
Exposure Control Method
Program AE, Manual; AE Lock, Program Shift, Safety Shift, Auto ISO Shift
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
*The color of faces is evaluated in Face Detect WB
Built-in Flash
Auto, Auto w/ Red-eye Reduction, Flash On, Flash Off; FE lock, Safety FE, Slow Synchro
Flash Range
1.6 9.8 ft. (W), 3.3 6.6 ft. (T)
(50cm 3.0m (W), 1.0cm 2.0m (T)
Recycling Time
12 sec. or less (battery voltage: 3.0 V)LCD monitor is turned off during flash charging (Except when turning on the power)
Flash Exposure Compensation
Shooting Modes
M, Av, Tv, P, Auto, Easy, Portrait, Landscape, Kids & Pets, SCN*1, Movie*2
*1 Smart Shutter*3, Low Light, Super Vivid, Poster Effect, Color Accent, Color Swap, Fish-eye Effect, Miniature Effect, Beach, Foliage, Snow, Fireworks
*2 Standard, Miniature Effect, Color Accent, Color Swap
*3 Smile, Wink-Self-timer, Face Self-timer
Photo Effects
My Colors
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, DarkerSkin, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
* Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Activates shutter after an approx. 2-sec./10-sec. delay, Custom*1, Face Self-Timer*2
*1 Shooting start time (0-15 sec. (in 1-second increments), 20/25/30 sec.) and number of shots (1-10 (in one-shot increments)) can be specified.
*2 When the number of detected faces increases, the shutter is released after 2 sec. delay. However, if no face is detected for 30 seconds or more, the shooting operation starts automatically.
Wireless Control
Not available
Continuous Shooting
Normal: Approx. 1.0 shots/sec. (when shooting in P mode),Approx. 3.0 shots/sec. (when shooting in Low Light mode)
AF: Approx. 0.6 shots/sec. (when shooting in P mode),Approx. 1.0 shots/sec. (when shooting in Low Light mode)
LV: Approx. 0.7 shots/sec. (when shooting in P mode),Approx. 1.1 shots/sec. (when shooting in Low Light mode)
- Under conditions where the flash does not fire automatically.
- Differs depending on the zoom position.
Storage Media
SD/SDHC memory card, SDXC memory card, MultiMediaCard, MMCplus card, HC MMCplus card
File Format
Design rule for camera file system, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.3 (JPEG)
Video: MOV (Image data: H.264; Audio data: Linear PCM (stereo))
Number of Recording Pixels
Still Image:
4,000 x 3,000 (Large), 2,816 x 2,112 (Medium 1), 1,600 x 1,200 (Medium 2), 640 x 480 (Small), 4,000 x 2248 (Widescreen)Fixed to 1600 x 1200 when in Low Light
Image data
Movie data
Note: N=Normal F=FineStorage Capacity varies depending on camera settings. This data is estimated fromCanon's standard shooting conditions. Figures for Movie Mode represent total capacity&nbsp;
Playback Modes File
Still Image: Single, Magnification (approx. 2x10x), Jump, Auto Rotate, Rotate, Resume, My Category, Transition Effects, Histogram, Index (4130 thumbnails), Over Exposure Warning, Slide Show, Red-eye Correction, Resize, Easy; i-Contrast, Smart Shuffle, My Colors, Operation Tools, Scroll Display, and Favorites.
Video: Normal Playback, Special Playback, Auto Rotate, Resume, Easy
Erase Modes
Select Image, single image, select all imagesThe image data stored in the memory card with the design rule for camera file systems format can be erased. However, protected images cannot be erased)Video: any video file (files must be erased one at a time)
Computer Interface
Hi-Speed USB*1 (dedicated connector (female) with unified type of digital stereo audio and video*2
*1 Use of USB logomark is not allowed.
*2 mini-B compatible.
Video Out
NTSC or PAL
Audio Out
Stereo
Other
Memory card slot; direct connection to Canon and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1. AA-size Alkaline Battery (x2)
2. Rechargeable AA-size NiMH Battery NB-3AH (x2)
3. AC Adapter Kit ACK-800 (optional)
Shooting Capacity
Still Image: approx. 130 shots (AA-size Alkaline Battery), approx. 370 shots (AA-size Ni-MH Battery)*
Playback Time
Approx. 7 hrs. (AA-size Alkaline Battery), approx. 9 hrs. (AA-size Ni-MH Battery)
*LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Operating Temperature
32-104&deg;F/0-40&deg;C
3295&deg; F/035&deg; C when NB-3AH is used
Operating Humidity
10-90%
Dimensions (W x H x D)
4.46 x 2.88 x 1.80 in. (113.3 x 73.2 x 45.8mm)
- CIPA compliant
Weight
Approx. 10.9 oz/308g (including the battery and memory card)
Approx. 9.17 oz./260g (camera body only)Note: 26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)All data are based on Canon's Standard Test Method. Subject to change without notice.Canon, DIGIC, PIXMA and PowerShot are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft and Windows are trademarks or registered trademarks of the Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple Computer, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
