Canon Support for PowerShot SX20 IS | Canon U.S.A., Inc.
PowerShot SX20 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 11.12.09
File Size 4.01 MB
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 08.20.09
File Size 6.05 MB
Date 11.12.09
File Size 6.94 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 12.4 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
5.0 (W) - 100 (T) mm f/2.8-5.7 (35mm equivalent: 28-560mm)
Digital Zoom
4x
Focusing Range
Normal: 1.6 ft./50cm-infinity (W), 3.3 ft./1m-infinity (T)
Macro: 3.9 in.-1.6 ft./10-50cm (W)
Super macro: 0-3.9 in./0-10cm (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
TFT color
LCD Monitor
2.5-inch TFT color Vari-Angle LCD with wide viewing angle
LCD Pixels
Approx. 230,000 pixels
LCD Coverage
100%
Maximum Aperture
f/2.8 (W) - f/5.7 (T)
Shutter Speed
15-1/3,200 sec. (settable in Tv and M)
Sensitivity
Auto*, ISO 80/100/200/400/800/1600 equivalent
(Standard output sensitivity. Recommended exposure index)
*Camera automatically sets the optical ISO speed according to shooting mode and subject brightness. The ISO speed also varies according to subject movement and camera shake when the shooting mode is set to Auto.
Light Metering Method
Evaluative*, Center-weighted average, Spot**
*Facial brightness is also evaluated in Face Detect.
** Metering frame is fixed to the center/linked to AF frame
Exposure Control Method
Program AE, i-Contrast, Manual; AE Lock, Program Shift, Safety Shift, Auto ISO Shift
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash), Custom
* The color of faces is evaluated in Face Detect.
Built-in Flash
Auto, Auto w/ Red-eye Reduction, Flash On, Flash On w/ Red-eye Reduction, Flash Off; FE lock, Safety FE, Slow Synchro
Flash Range
1.6-22 ft./50cm-6.8m (W), 3.3-12 ft./1.0-3.7m (T) (when sensitivity is set to ISO Auto)
Recycling Time
7 sec. or less (battery voltage=6.0V)
Flash Exposure Compensation
Shooting Modes
Auto, P, Av, Tv, M, C, Portrait, Landscape, Sports, Special Scene (Foliage, Snow, Beach, Sunset, Fireworks, Aquarium, Night Scene, Indoor, ISO 3200, Color Accent, Color Swap), Super Macro, Night Snapshot, Stitch Assist, Movie
Photo Effects
My Colors Off, Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom
Self Timer
Activates shutter after an approx. 2-sec./10-sec. delay, Face Detection Self-timer, Custom
Wireless Control
Not available
Continuous Shooting
Normal: approx. 1.0 fps; AF: approx. 0.7 fps; LV: approx. 0.7 fps (Large/Fine)
Storage Media
SD/SDHC Memory Card, MultiMediaCard, MMCplus Card, HC MMCplus Card
File Format
Design rule for camera file system, DPOF Version 1.1
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: MOV (Image: H.264; Audio: Linear PCM (Monaural/Stereo))
Number of Recording Pixels
Still Image: 4,000 x 3,000 (Large), 3,264 x 2,448 (Medium 1), 2,592 x 1,944 (Medium 2), 1,600 x 1,200 (Medium 3), 640 x 480 (Small), 3,840 x 2,160 (Widescreen)Movie: 1,280 x 720 (HD, 30 fps available up to 4GB or 29 minutes, 59 sec.), 640 x 480 (30 fps), 320 x 240 (30 fps) available up to 4GB or 60 minutes
Image data
Movie data
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Category, Transition Effects, Histogram, Index (4-130 thumbnails), Over Exposure Warning, Slide Show, Red-eye Correction, Trimming, Resize, Image Inspection Tool, i-Contrast;
Movie: Normal Playback, Special Playback, Editing, Auto Rotate, Resume
Erase Modes
Still Image: single image, all images
Movie: part of movie, all of movie
Computer Interface
USB 2.0 Hi-Speed (mini-B jack)
Video Out
NTSC/PAL
Audio Out
Stereo
Other
Memory card slot; direct connection to Canon and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
1. AA-size Alkaline Battery (x4)
2. Rechargeable AA-size NB-3AH Battery (x4)
3. Compact Power Adapter CA-PS700 (optional)Still Image: approx. 340 shots (AA-size Alkaline Battery), approx. 600 shots (AA-size NB-3AH Battery)*Approx. 720 min. (AA-size Alkaline Battery), approx. 840 min. (AA-size NB-3AH Battery)
*LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source
Shooting Capacity
Playback Time
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.88 x 3.48 x 3.42 in./124.0 x 88.3 x 86.9mm
Weight
Approx. 19.8 oz./560g (camera body only)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
