Canon Support for PowerShot SX210 IS | Canon U.S.A., Inc.
PowerShot SX210 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
14.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 14.5 Megapixels
Effective Pixels
Approx. 14.1 Megapixels
Focal Length
5.0 (W) - 70.0 (T) mm (35mm film equivalent: 28 - 392mm)
Digital Zoom
4x
Focusing Range
2.0 in (5cm) - infinity (W), 3.3 ft (1m) - infinity (T)
Macro: 2.0 in - 1.6 ft (5 - 50cm) (W)
Autofocus System
TTL Autofocus, Manual focus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch TFT color LCD widescreen with wide viewing angle
LCD Pixels
Approx. 230,000 pixels
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.1 (W) - f/5.9 (T)
Shutter Speed
1 - 1/3200 sec.
15 - 1/3200 sec. (Total shutter speed range); Long Shutter operates with noise reduction when manually set at 1.3 - 15 sec.
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent (Standard output sensitivity. Recommended exposure index)
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Manual Exposure, i-Contrast, Program Shift, Safety Shift; AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Facial color is evaluated in Face Detection AF
Built-in Flash
Auto, Manual (3 levels), Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE Lock, Safety FE, Slow Synchro
Flash Range
12 in. - 11.5 (W), 3.3 - 6.6 ft (T), 75 cm - 3.5 m (W), (1.0 - 2.0m, (T))Image brightness may diminish depending on the shooting distance
Recycling Time
10 sec. or less (battery voltage: 3.7 V)
Flash Exposure Compensation
Shooting Modes
Auto*, P, Tv, Av, M, Easy, Portrait, Landscape, Night Snapshot, Kids & Pets, Indoor, SCN**
*Automatically detects shooting scene** Smart Shutter (Smile, Wink Self-timer, Face Detection Self-timer), Low Light, Color Accent, Color Swap, Fisheye Effect, Miniature Effect, Beach, Foliage, Snow, Fireworks, Stitch Assist
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color *
* Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
* Shooting start time (0-10 sec. (in one-second increments), 15/20/30 sec.) number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Normal: approx. 0.7 fps; AF: approx. 0.5 fps; LV: approx. 0.5 fps; Low Light: 2.6 fps
Storage Media
SD/SDHC/SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format
Design rule for Camera File System, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: MOV (Image: H.264; Audio: Linear PCM (Stereo))
Number of Recording Pixels
Still Image: 4,320 x 3,240 (Large), 3,456 x 2,592 (Medium 1), 2,592 x 1,944 (Medium 2), 1,600 x 1,200 (Medium 3/Date Stamp), 640 x 480 (Small), 4,320 x 2,432 (Widescreen), 2144 x 1,608 (Low Light)Movies: Standard, Color Accent, Color Swap: 1280 x 720 (30 fps), 640 x 480 (30 fps), 320 x 240 (30 fps); 4GB or approx. 29 min. 59 sec. (HD), 60 min. (SD) per clip
Image data
Movie data
*Actual frame rate is 29.97 fps
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
- Easy, Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display, Active Display), Rotate, Favorites, My Category, Jump, Smart Shuffle, Filter Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist)
- Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Colors, My Category, Transition Effects, Histogram, Overexposure Warning, Index (4-130 thumbnails), Slide Show, Red-eye Correction, Trimming, Resize, i-Contrast, Easy, Edit and Resume
- Movies: Normal Playback*, slow motion**, pause, first frame, last frame, next frame, previous frame, fast forward, fast rewind, editing, resume * Auto settings available in 5 levels
** 5 levels (including normal playback), sound not available.
Erase Modes
Select image, all images
The image data in the memory cared stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).Using the Movie editing function, sections of the movie (1 sec. increments) can be deleted.
Computer Interface
USB 2.0 Hi-Speed (mini-B jack)
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Audio Out
Stereo (dedicated connector (female) with unified type of digital, audio and video)
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
1. Rechargeable Lithium-ion Battery NB-5L
2. AC Adapter Kit ACK-DC30 (optional)
Shooting Capacity
Approx. 260 shots
Playback Time
Approx. 6 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.17 x 2.33 x 1.26 in./105.8 x 59.3 x 31.9mm
Weight
Approx. 7.58 oz./215g (including battery and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
