Canon Support for PowerShot SX30 IS | Canon U.S.A., Inc.
PowerShot SX30 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.15.10
File Size 10.96 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
14.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 14.5 Megapixels
Effective Pixels
Approx. 14.1 Megapixels
Focal Length
35x zoom: 4.3 (W) - 150.5 (T) mm (35mm film equivalent: 24 (W) - 840(T) mm)
Digital Zoom
4x
Focusing Range
Auto: 0 in./0 cm - infinity (W), 4.6 ft./1.4 m - infinity (T);Normal: 2.0 in./ 5 cm - infinity (W), 4.6 ft./1.4 m - infinity (T);Macro: 0 in. - 1.6 ft./ 0 - 50 cm (W)Manual Focus: 0 in./0 cm - infinity (W), 4.6 ft./1.4 m - infinity (T)
Autofocus System
TTL Autofocus, manual focus
Optical Viewfinder
Electronic Viewfinder available
LCD Monitor
2.7-inch TFT color LCD (Vari-angle type with wide viewing angle)
LCD Pixels
Approx. 230,000 pixels
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.7 (W) - f/5.8 (T)
- The following f/numbers are available in Av or M:
W: f/2.7, 3.2, 3.5, 4.0, 4.5, 5.0, 5.6, 6.3, 7.1, 8.0
T: f/5.8, 6.3, 7.1, 8.0
Shutter Speed
1 - 1/3200 sec.
15 - 1/3200 sec. (Total shutter speed range)
- Shutter speeds differs depending on the shooting mode.
- Shutter speeds available in Tv and M:
15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 0.8, 0.6, 0.5, 0.4, 0.3,1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80,1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000,1/1250, 1/1500, 1/1600, 1/2000, 1/2500, 1/3200 (Units: sec.)
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent (Camera automatically sets the optimal ISO speed according to shooting mode.)
Light Metering Method
Evaluative*, Center-weighted average, Spot*** Control to incorporate facial brightness in Face Detection AF** Metering frame is fixed to the center*2 Fixed to center
Exposure Control Method
AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Custom*Facial color is evaluated in Face AiAF.
Built-in Flash
Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro, Smart Flash
Flash Range
1.6 - 19 ft. (W), 4.6 - 9.2 ft. (T), (50 cm - 5.8 m (W), 1.4 - 2.8 m (T))
Recycling Time
10 sec. or less (battery voltage=7.4V)
Flash Exposure Compensation
Shooting Modes
Smart AUTO, P, Tv, Av, M, C1, C2, Portrait, Landscape, Sports, SCN*1, Movie*2
*1Smart Shutter*3, Low Light, Super Vivid, Poster Effect, Color Accent, Color Swap, Fisheye Effect, Miniature Effect, Beach, Foliage, Snow, Fireworks, Stitch Assist
*2Smart AUTO available
*3 Smile, Wink, Self-timer, Face Self-timer
Photo Effects
My Colors
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
* Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Custom*/approx. 10-sec. delay/approx. 2-sec. delay* Delay time (0 - 10 sec. (in one-second increments), 20/25/30 sec.) and number of shots(1 - 10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
Normal: Approx. 1.3 shots/sec. (when shooting in P mode),Approx. 3.6 shots/sec. (when shooting in Low Light mode)
AF: Approx. 0.6 shots/sec. (when shooting in P mode),Approx. 1.0 shots/sec. (when shooting in Low Light mode)
LV: Approx. 0.6 shots/sec. (when shooting in P mode),Approx. 1.1 shots/sec. (when shooting in Low Light mode)
- Under conditions where the flash does not fire automatically.
- Differs depending on the zoom position.
Storage Media
SD/SDHC Memory Card, SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format
Design rule for camera file system, DPOF Version 1.1 compliant
Image Recording Format
Normal, Fine
Number of Recording Pixels
Still Image: 4320 x 3240 (Large), 3072 x 2304 (Medium 1), 1600 x 1200 (Medium 2)*, 640 x 480 (Small), 3744 x 2104 (Widescreen), * Same as when shooting in Low Light
Image data
Movie data
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated fromCanon's standard shooting conditions. Figures for Movie Mode represent total capacityof the particular media.
Playback Modes File
- Easy, Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Jump, Slide Show (Playback Interval, Repeat, Effect, Playlist), Smart Shuffle- Still Images: Single, Index, Magnification, Trimming, Resize, Focus Check, Histogram, Overexposure Warning.- Videos: Normal Playback*, Editing, slow motion **, pause, first frame, last frame, next frame, previous frame, fast forward, fast rewind* Auto settings available in 5 levels** 5 levels (including normal playback), sound not available.
Erase Modes
Still Image: single image, select range, all imagesVideo: any video file
Computer Interface
USB 2.0 Hi-Speed USB (dedicated female connector with unified type of digital, audio and video)*2 mini-B compatible.
Video Out
Analog: NTSC/PAL, digital: HDMI mini connector
Audio Out
Stereo
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1. Battery Pack NB-7L
2. AC Adapter Kit ACK-DC50
Shooting Capacity
Approx. 400 shots (electronic viewfinder)Approx. 370 shots (LCD monitor)
Playback Time
Approx. 10 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.84 x 3.64 x 4.24 in. / 122.9 x 92.4 x 107.7mm
- CIPA compliant
Weight
Approx. 21.2 oz. / 601g (camera, including batteries and memory card)Note: 26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi).All data are based on Canon's Standard Test Method. Subject to change without notice.Canon, DIGIC, PIXMA and PowerShot are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft and Windows are trademarks or registered trademarks of the Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple Computer, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
