Canon Support for PowerShot SX500 IS | Canon U.S.A., Inc.
PowerShot SX500 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 08.30.12
File Size 13.47 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
16.0 Megapixel, 1/2.3-inch CCD
Total Pixels
Approx. 16.6 Megapixels
Effective Pixels
Approx. 16.0 Megapixels
Focal Length
4.3 (W) - 129.0 (T) mm (35mm film equivalent: 24-720mm)
Optical Zoom
30x
Digital Zoom
4x
Focusing Range
Normal/Auto: 0 in (0cm) - infinity (W), 4.6 ft. (1.4m) - infinity (T)
Macro AF: 0 in - 1.6 ft. (0-50cm) (W)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch TFT Color LCD with wide viewing angle
LCD Pixels
Approx. 461,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.4 (W) - f/5.8 (T)
Shutter Speed
1-1/1600 sec.
15-1/1600 sec. (Total shutter speed range)
Sensitivity
Auto, ISO 100/200/400/800/1600
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift; AE Lock
Exposure Compensation
Still Images: &plusmn;2 stops in 1/3-stop increments
Videos: &plusmn;2 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto*, Day Light, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Camera automatically sets the optimal ISO speed according to shooting mode.
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
- Facial brightness is also evaluated in Face Detect.
Flash Range
1.6 ft. - 16 ft. (W), 4.6 - 9.8 ft. (T) (50cm - 5.0m (W), (1.4 - 3.0m (T))
Image brightness may diminish depending on the shooting distance
Recycling Time
10 sec. or less (battery voltage: 3.7 V)
Flash Exposure Compensation
+/-2 stops in 1/3-stop increments
Shooting Modes
M, Av, Tv, P, Live View Control, Auto*, SCN*1, Creative Filters*2, Discreet, Movie*3
- Shooting movies is possible with the movie button
*1 Portrait, Face Self-timer, Low Light, Snow, Fireworks
*2 Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect
*3 Standard, iFrame Movie
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
*Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Normal: Approx. 0.8 shots/sec. (in P mode)
Normal: Approx. 2.8 shots/sec. (in Low Light mode)
AF: Approx. 0.5 shots/sec. (in P mode)
LV: Approx. 0.6 shots/sec. (in P mode)
- Under conditions where the flash does not fire automatically.
- Differs according to zoom position.
Storage Media
SD Memory Card, SDHC Memory Card, SDXC Memory Card
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Superfine, Fine
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG)
Video: MOV (Image: H.264; Audio: Linear PCM (Stereo))
Number of Recording Pixels
Still Images:
[16:9]
Large: 4608 x 2592
Medium 1: 3264 x 1832
Medium 2: 1920 x 1080
Small: 640 x 360
[3:2]
Large: 4608 x 3072
Medium 1: 3264 x 2176
Medium 2: 1600 x 1064
Small: 640 x 424
[4:3]
Large: 4608 x 3456
Medium 1: 3264 x 2448
Medium 2: 1600 x 1200
Small: 640 x 480
[1:1]
Large: 3456 x 3456
Medium 1: 2448 x 2448
Medium 2: 1200 x 1200
Small: 480 x 480
Videos:
HD 1280 x 720: 25 fps
iFrame Movie HD 1280 x 720: 25 fps
Miniature Effect HD 1280 x 720: 5 fps / 2.5 fps / 1.25 fps
Miniature Effect 640 x 480: 6 fps / 3 fps / 1.5 fps
640 x 480: 30 fps (29.97)
Image data
&nbsp;* When shooting in Low Light&bull; The approximate number of images recordable on memory cards other than the above can be calculatedby using the above figures as a reference and extrapolating accordingly.
Movie data
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
*1 Playback frame is 25 fps.
*2 Playback frame is 30 fps*3.
*3 Actual frame rate is 29.97 fps.
Playback Modes File
Stills & Videos:
Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Operation Tools, Transition Effects, Scroll Display, Active Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Image Search, Slideshow (Playback Interval, Repeat, Effect, Playlist)
Still Images:
Single, Index (4-130 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure Warning
Videos:
Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2
- Displays playback position and shooting time
Using the software included with the camera (ImageBrowser EX), there are 8 levels (1/8x to 1x) of playback speed for Super Slow Motion Movies possible on a computer.
*1 Audio settings available in 5 levels
*2 Approximately 4 seconds
*3 Slow motion available
Erase Modes
Select Image, Select Range, All Images
- The image data in the memory cared stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).
- Using the Movie editing function, sections of the movie (1 sec. increments) can be deleted.
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Mini-HDMI connector
Audio Out
Stereo (dedicated connector (female) with unified type of digital, audio and video)
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-6L, Compact Power Adapter CA-DC10 (included with AC Adapter Kit CA-DC40)
Shooting Capacity
Approx. 195 shots
Playback Time
Approx. 4 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.09 x 2.74 x 3.16 in. / 104.0 x 69.5 x 80.2mm
Weight
12.0 oz. / 341g (CIPA standard)
11.2 oz. / 318g (camera only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, Vietnamese).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
