Canon Support for PowerShot SX510 HS | Canon U.S.A., Inc.
PowerShot SX510 HS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | 12.1 Megapixel, 1/2.3-inch CMOS |
Total Pixels | Approx. 12.8 Megapixels |
Effective Pixels | Approx. 12.1 Megapixels |
Focal Length | 4.3 (W) - 129.0 (T) mm (35mm film equivalent: 24-720mm) |
Optical Zoom | 30x |
Digital Zoom | 4.0x |
Focusing Range | Normal: 2.0 in. (5cm) - infinity (W), 4.6 ft. (1.4m) - infinity (T) Auto/Manual: 0.0 in. (0cm) - infinity (W), 4.6 ft. (1.4m) - infinity (T) Macro AF: 0.0 in. - 1.6 ft. (0-50cm) (W) |
Autofocus System | TTL Autofocus, Manual Focus |
Optical Viewfinder | Not available |
LCD Monitor | 3.0-inch TFT Color LCD with wide viewing angle |
LCD Pixels | Approx. 461,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/3.4 (W) - f/5.8 (T) |
Shutter Speed | 1-1/1600 sec. 15-1/1600 sec. (in Tv and M modes) |
Sensitivity | Auto, ISO 80-3200 |
Light Metering Method | Evaluative*, Center-weighted average, Spot** * Facial brightness is evaluated in Face Detection AF ** Metering frame is fixed to the center |
Exposure Control Method | Manual Exposure, Program Shift, Safety Shift; AE Lock |
Exposure Compensation | Still Images: ±2 stops in 1/3-stop increments Videos: ±2 stops in 1/3-stop increments (not available during shooting) |
White Balance Control | Auto*, Day Light, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom * Camera automatically sets the optimal ISO speed according to shooting mode. |
Built-in Flash | Auto, Flash On, Slow Synchro, Flash Off Facial brightness is also evaluated in Face Detect. |
Flash Range | 1.6 ft. - 16 ft. (W), 1.6 - 9.8 ft. (T) (50cm - 5.0m (W), (50cm - 3.0m (T)) Image brightness may diminish depending on the shooting distance |
Recycling Time | 10 sec. or less (battery voltage: 3.7 V) |
Flash Exposure Compensation | ± 2 stops in 1/3-stop increments |
Shooting Modes | M, Av, Tv, P, Live View Control, Auto, Movie Digest, SCN*1, Creative Filters*2, Discreet, Movie*3 Shooting movies is possible with the movie button *1 Portrait, Face Self-timer, High-speed Burst, Low Light, Snow, Fireworks *2 Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect *3 Standard, Super Slow Motion Movie |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color* *Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available |
Self Timer | Approx. 10-sec. delay/approx. 2-sec. delay/custom* *Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified. |
Wireless Control | Not Available |
Continuous Shooting | Normal: Approx. 3.8 shots/sec. (in P mode) Normal: Approx. 10.5 shots/sec. (in High-speed Burst mode) AF: Approx. 1.0 shots/sec. (in P mode) LV: Approx. 1.0 shots/sec. (in P mode) Under conditions where the flash does not fire automatically.Differs according to zoom position. |
Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
File Format | Design rule for Camera File system, DPOF (Version 1.1) compliant |
Image Recording Format | Superfine / Fine |
JPEG Compression Mode | Still Image: Exif. 2.3 (JPEG) Video: MOV (Image: H.264; Audio: Linear PCM (Stereo)) |
Number of Recording Pixels | Still Images: 16:9 - Large: 4000 x 2248; Medium 1: 2816 x 1584; Medium 2: 1920 x 1080; Small: 640 x 3603:2 - Large: 4000 x 2664; Medium 1: 2816 x 1880; Medium 2: 1600 x 1064; Small: 640 x 4244:3 - Large: 4000 x 3000; Medium 1: 2816 x 2112; Medium 2: 1600 x 1200; Small: 480 x 4801:1 - Large: 2992 x 2992; Medium 1: 2112 x 2112; Medium 2: 1200 x 1200; Small: 480 x 480Videos: Full HD 1920 x 1080: 24 fps*1 HD 1280 x 720: 30 fps*2 Miniature Effect HD 1280 x 720*3: 6 fps / 3 fps / 1.5 fps Miniature Effect 640 x 480*3: 6 fps / 3 fps / 1.5 fps 640 x 480: 30 fps*2 *1 Actual frame rate is 23.976 fps. *2 Actual frame rate is 29.97 fps. *3 Playback rate is 30 fps*2 |
Image data | Note: SF=Superfine, F=Fine* When in Low Light or High-speed Burst.• The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Movie data | *1 Actual frame rate is 23.976 fps. *2 Actual frame rate is 29.97 fps. *3 Playback rate is 30 fps*2 |
Playback Modes File | Stills & Videos: Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Slideshow (Interval, Repeat, Effect) Still Images: Single, Index (4-130 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Resize, My Colors, Histogram, Overexposure Warning Videos: Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2 Displays playback position and shooting timeUsing the software included with the camera (ImageBrowser EX), there are 8 levels (1/8x to 1x) of playback speed for Super Slow Motion Movies possible on a computer. *1 Audio settings available in 5 levels *2 Approximately 4 seconds *3 Slow motion available |
Erase Modes | Select Image, Select Range, All Images The image data in the memory cared stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).Using the Movie editing function, sections of the movie (1 sec. increments) can be deleted. |
Video Out | NTSC/PAL (dedicated connector (female) with unified type of digital, autio and video), Mini-HDMI connector |
Audio Out | Stereo (dedicated connector (female) with unified type of digital, audio and video) |
Other | USB, SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-6LH, Compact Power Adapter CA-DC10 (included with AC Adapter Kit ACK-DC40) |
Shooting Capacity | Approx. 250 shots Approx. 330 shots in ECO Mode |
Playback Time | Approx. 5 hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.09 x 2.74 x 3.16 in. / 104.0 x 69.5 x 80.2mm |
Weight | 12.3 oz. / 349g (CIPA standard) 11.1 oz. / 316g (camera only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, Vietnamese).All data are based on Canon's Standard Test Method. Subject to change without notice.Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
