Canon Support for PowerShot SX60 HS | Canon U.S.A., Inc.
PowerShot SX60 HS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
16.0 Megapixel*, 1/2.3-inch CMOS
*Image processing may cause a decrease in the number of pixels
Total Pixels
Approx. 16.8 Megapixels
Effective Pixels
Approx. 16.1 Megapixels
Focal Length
3.8 (W) - 247.0 (T) mm (35mm film equivalent: 21-1365mm)
Digital Zoom
4.0x
Focusing Range
0.0 in (0 cm) - infinity (W), 5.9 ft. (1.8 m) - infinity (T)
Macro 0.0 in. (0 cm) - 1.6 ft. (50 cm) (W)
Autofocus System
TTL Autofocus (Continuous, Servo AF), Manual Focus
Optical Viewfinder
Electronic Viewfinder (Approx. 922,000 dots)
LCD Monitor
3.0-inch Color Vari-angle LCD with wide viewing angle
LCD Pixels
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.4 (W), f/6.5 (T)
Shutter Speed
1-1/2000 sec.
15-1/2000 sec. (in Tv and M modes)
Sensitivity
Auto*, ISO 100/125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200
(When in P mode)/6400 (When in Low Light mode)
*Optimal ISO speed is automatically set depending on the shooting mode
Light Metering Method
Evaluative*, Center-weighted average, Spot**
*1 Facial brightness is evaluated (Face Detect AE) in Face Detect.
*2 Fixed to Center, linked to AF frame
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;2 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto*, Daylight, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Custom 1, Custom 2, Multi-area White Balance, White Balance Correction
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
Facial brightness is also evaluated in Face Detect.
Flash Range
1.6 ft. (50 cm) - 18 ft. (5.5 m) (W), 5.9 ft. (1.8 m) - 9.8 ft. (3.0 m) (T)
Recycling Time
10 sec. or less (Battery voltage: 3.7 V)
Flash Exposure Compensation
Shooting Modes
C1, C2, M, Av, Tv, P, Hybrid Auto, Auto, Creative Shot, Sports, SCN*1, Creative Filters*2, Movie*3
*1 Portrait, Smart Shutter*4, Handheld Night Scene, Low Light, Snow, Fireworks
*2 High Dynamic Range, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect
*3 Standard, Manual (Movie), iFrame Movie, Super Slow Motion Movie
*4 Smile, Wink Self-timer, Face Self-timer
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color *
*Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
Not Available
Continuous Shooting
Normal: Approx. 6.4* shots/sec. (in AUTO & P mode)AF: Approx. 3.8* shots/sec. (in P mode)LV: Approx. 4.6* shots/sec. (in P mode)Under conditions where the flash does not fire automatically. Differs depending on the zoom position.*Using an 8 GB, UHS-I compatible memory card that meets Canon's testing standards. The number of shots changes depending on subjects, brands of memory cards, etc. Shooting in RAW (including RAW+JPEG) is excluded.
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Superfine / Fine
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG), RAW (12 bit, CR2 (Canon Original))
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo))
Number of Recording Pixels
Still Images:
1) 16:9 - Large: 4608 x 2592; Medium 1: 3264 x 1832; Medium 2: 1920 x 1080; Small: 640 x 360
2) 3:2 - Large: 4608 x 3072; Medium 1: 3264 x 2176; Medium 2: 2048 x 1368; Small: 640 x 424
3) 4:3 - Large: 4608 x 3456; Medium 1: 3264 x 2448; Medium 2: 2048 x 1536; Small: 640 x 480
4) 1:1 - Large: 3456 x 3456; Medium 1: 2448 x 2448; Medium 2: 1536 x 1536; Small: 480 x 480
5) 4:5 - Large: 2768 x 3456; Medium 1: 1952 x 2448; Medium 2: 1232 x 1536; Small: 384 x 480Videos:
Full HD 1920 x 1080: 60 fps*3 / 30 fps*2
Full HD iFrame Movie HD 1920 x 1080: 30 fps*2
HD 1280 x 720: 30 fps*2
640 x 480: 30 fps*2
Super Slow Motion Movie 640 x 480: 120 fps*1
Super Slow Motion Movie 320 x 240: 240 fps*1
Miniature Effect for Movie 1280 x 720: 6 fps*1 / 3 fps*1 / 1.5 fps*1
Miniature Effect for Movie: 640 x 480: 6 fps*1 / 3 fps*1 / 1.5 fps*1
Digest Movie: 1280 x 720: 30fps*2*1 Playback frame rate is 30 fps*2.
*2 Actual frame rate is 29.97 fps.
*3 Actual frame rate is 59.94 fps.
Image data
Note: SF=Superfine F=Fine *When in Low Light.
&#8226; The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
Playback Modes File
Stills & Videos:
Auto Rotate (Automatic vertical/horizontal detection), Index Continuous Display, Image Advance (Operation Tools, Transition Effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Movie Digest, Slideshow (Playback Interval, Repeat, Effect, Playlist)Still Images:
Single, Index, Magnification (2-10x), Switch to other images while zoomed, Information Display, Red-eye Correction, Photobook Setup, Cropping, Resize, My Colors, Face ID info, Histogram, RGB Histogram, Location Information, Overexposure Warning Videos:
Normal Playback*1, Pause, Slow Motion, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2, Erase chapters, Editing, Movie Transcoding
Using the software included with the camera (ImageBrowser EX), there are 8 levels (1/8x to 1x) of playback speed for Super Slow Motion Movies possible on a computer.
Erase Modes
Select Image, Select Range, Select All Images
The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).Using the Movie editing function, sections of the movie can be deleted. RAW+JPEG images can be erased individually.
Video Out
Analog: NTSC or PAL, Digital: HDMI (HDMI&trade; mini connector)
Audio Out
Stereo
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers &amp; PictBridge compatible printers.
External Microphone input terminal (&phi;3.5mm stereo mini jack)
Power Source
Battery Pack NB-10L, AC Adapter Kit ACK-DC80
Shooting Capacity
Approx. 340 shots when using LCD monitor
Approx. 450 shots when using ECO mode
Playback Time
Approx. 6 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
5.02 x 3.65 x 4.50 in. / 127.6 x 92.6 x 114.3 mm
Weight
1.43 lb. / 650 g (CIPA standard)
1.34 lb. / 607 g (camera only)
Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, Vietnamese).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
