Canon Support for PowerShot SX610 HS | Canon U.S.A., Inc.
PowerShot SX610 HS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
20.2 Megapixel, 1/2.3-inch CMOS
Total Pixels
Approx. 21.1 Megapixels
Effective Pixels
Approx. 20.2 Megapixels*
*Image processing may cause a decrease in the number of pixels.
Focal Length
4.5 (W) - 81.0 (T) mm (35mm film equivalent: 25-450mm)
Optical Zoom
18x
Digital Zoom
4.0x
Focusing Range
Normal/Auto: 2.0 in. (5cm) - infinity (W), 3.3 ft. (1m) - infinity (T)
Macro: 2.0 in. - 1.6 ft. (5-50cm) (W)
Infinity: 9.8 ft. (3m) - infinity (W, T)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
Not available
LCD Monitor
3.0-inch TFT Color LCD with wide viewing angle (4:3)
LCD Pixels
Approx. 922,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.8 (W), f/6.9 (T)
Shutter Speed
1-1/2000 sec.
15-1 sec. (Long Shutter mode)
Sensitivity
Auto, ISO 80-3200
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;2 stops in 1/3-stop increments
Videos: &plusmn;2 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Camera automatically sets the optimal ISO speed according to shooting mode.
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
Facial brightness is also evaluated in Face Detect.
Flash Range
1.6 ft. - 11 ft. (W), 3.3 - 6.6 ft. (T) (50cm - 3.5m (W), (1.0m - 2.0m (T))
Image brightness may diminish depending on the shooting distance
Recycling Time
10 sec. or less (battery voltage: 3.7 V)
Flash Exposure Compensation
Not Available
Shooting Modes
Auto, Hybrid Auto, P, Creative Shot1, Portrait, Smart Shutter2, High-Speed Burst, Handheld Night Scene, Low Light, Fisheye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Snow, Fireworks, Long Shutter
*1 Auto, Retro, Monochrome, Special and Natural effects
*2 Smile, Wink Self-timer, Face Self-timer
Shooting movies is possible with the movie button
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color *
*Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
Wi-Fi&trade; and NFC
Continuous Shooting
Normal: Approx. 2.5 shots/sec. (in Auto/P mode)
Approx. 7.2 shots/sec. (in High Speed Burst mode)
Storage Media
SD Memory Card, SDHC Memory Card, SDXC Memory Card
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Superfine / Fine
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG)
Video: MP4 (Image: H.264; Audio: MPEG-4 AAC-LC (Monaural))
Number of Recording Pixels
Still Images:
1) 16:9 - Large: 4608 x 2592; Medium 1: 3264 x 1832; Medium 2: 1920 x 1080; Small: 640 x 360
2) 3:2 - Large: 4608 x 3072; Medium 1: 3264 x 2176; Medium 2: 2048 x 1368; Small: 640 x 424
3) 4:3 - Large: 4608 x 3456; Medium 1: 3264 x 2448; Medium 2: 2048 x 1536; Small: 640 x 480
4) 1:1 - Large: 3456 x 3456; Medium 1: 2448 x 2448; Medium 2: 1536 x 1536; Small: 480 x 480
5) Medium: 2592 x 1944 (High-Speed Burst and Low Light)
Videos:
Full HD 1920 x 1080: 30 fps (29.97)
HD 1080 x 720: 30 fps (29.97)
Miniature Effect HD 1080 x 720: 6 fps / 3 fps / 1.5 fps
Miniature Effect 640 x 480: 6 fps / 3 fps / 1.5 fps
640 x 480: 30 fps (29.97)
Image data
Note: SF=Superfine / F=Fine
* When in High Speed Burst or Low Light.
&#8226; The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
&#42;1 Using an SD Speed Class 10 / UHS-I compatible memory card.
&nbsp;&#8226; Recording stops automatically once the file size reaches 4 GB or the memory card becomes full.
&nbsp;&#8226; Recording may stop unexpectedly if a memory card with a low Speed Class is used.
&#42;2 Actual frame rate is 29.97 fps.
Playback Modes File
Stills & Videos:
Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, Smart Shuffle, Group Playback, Slideshow (Repeat, Interval, Effect)
Still Images:
Single, Index (6-100 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Resize, My Colors, Histogram, Overexposure Warning
Videos:
Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2
Displays playback position and shooting time
*1 Audio settings available in 5 levels*2 Approximately 4 seconds*3 Slow motion available
Erase Modes
Select Image, Select Range, Select All Images
The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).Using the Movie editing function, sections of the movie can be deleted.
Video Out
Analog: NTSC or PAL, Digital: HDMI (HMDI&trade; micro connector)
Audio Out
Monaural (dedicated connector (female) with unified type of digital, audio and video)
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers &amp; PictBridge compatible printers
Power Source
Battery Pack NB-6L/NB-6LH, AC Adapter Kit ACK-DC40
Shooting Capacity
Approx. 270 shots
Approx. 400 shots in ECO Mode
Playback Time
Approx. 5 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.15 x 2.40 x 1.05 in. / 105.3 x 61.0 x 26.7mm
Weight
6.74 oz. / 191g (CIPA standard)
5.89 oz. / 167g (Body only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, Vietnamese).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
