Canon Support for PowerShot SX70 HS | Canon U.S.A., Inc.
        PowerShot SX70 HS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Type | Compact digital still camera with built-in flash, 65x Optical, 4x Digital and 260x Combined Zoom with Optical Image Stabilizer |
| Type | 20.3 Megapixel*, 1/2.3-inch CMOS * Image processing may cause a decrease in the number of pixels. |
| Total Pixels | Approx. 21.1 Megapixels |
| Effective Pixels | Approx. 20.3 Megapixels |
| Focal Length | 3.8 (W) - 247.0 (T) mm (35mm film equivalent: 21-1365mm) |
| Optical Zoom | 65x |
| Digital Zoom | Approx. 4x |
| Focusing Range | Auto: 0.0 in. (0cm) - infinity (W), 5.9 ft. (1.8m) - infinity (T) Normal: 2.0 in. (5cm) - infinity (W), 5.9 ft. (1.8m) - infinity (T) Macro: 0.0 in. - 1.6 ft. (0 - 50cm) (W) |
| Autofocus System | TTL Autofocus |
| Optical Viewfinder | Electronic Viewfinder (Approx. 2,360,000 dots) |
| LCD Monitor | 3.0-inch TFT Color Vari-angle LCD with wide viewing angle (4:3) |
| LCD Pixels | Approx. 920,000 dots |
| LCD Coverage | Approx. 100% |
| Maximum Aperture | f/3.4 (W), f/6.5 (T) |
| Shutter Speed | 11/2000 sec. 151/2000 sec. (in all shooting modes) |
| Sensitivity | Auto: ISO 100-800 P: ISO 100-3200 |
| Light Metering Method | Evaluative, Center Weighted Average, Spot |
| Exposure Compensation | ±3 stops in 1/3-stop increments |
| White Balance Control | Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom, WB Correction |
| Built-in Flash | Auto, On, Slow Sync, Off |
| Flash Range | Approx. 1.6-21.3 ft. (W), 5.9-13.1 ft. (T) Approx. 50.0cm - 5.0m (W), 2.0-2.5m (T) |
| Shooting Modes | M, Av, Tv, P, Auto, Standard, Vivid, Neutral, B/W, Sepia |
| Self Timer | Off / 2 sec. / 10 sec. / Custom |
| Wireless Control | Built-in Wi-Fi® and Bluetooth® |
| Continuous Shooting | High-speed Continuous Shooting in One-Shot AF mode: Approx. 10.0 shots/sec. Low-speed Continuous Shooting in One-Shot AF mode: Approx. 3.0 shots/sec. High-speed Continuous Shooting in Servo AF mode: Approx. 5.7 shots/sec. Low-speed Continuous Shooting in Servo AF mode: Approx. 3.0 shots/sec. Continuous shooting speed may become slower due to the following factors: Tv value, Av value, subject conditions, shooting environment, use of flash, ISO speed, zoom position. |
| Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards |
| File Format | Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible |
| Image Recording Format | Fine / Normal |
| JPEG Compression Mode | Still Image: EXIF 2.31 (DCF2.0) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo)) |
| Number of Recording Pixels | Still Images: 1) 16:9 Large: 5184 x 2912; Medium: 3648 x 2048; Small: 2432 x 1368 2) 3:2 Large: 5184 x 3456; Medium: 3648 x 2432; Small: 2432 x 1616 3) 4:3 Large: 5184 x 3888; Medium: 3648 x 2736; Small: 2432 x 1824 4) 1:1 Large: 3888 x 3888; Medium: 2736 x 2736; Small: 1824 x 1824 5) Panoramic shot Horizontal, Maximum: 20960 x 2736; Min: 5184 x 2736. Vertical, 15744 x 3648; Minimum: 3648 x 3888 Videos: 4K* 3840 x 2160: 29.97 fps Full HD 1920 x 1080, 59.94 fps, 29.97 fps HD 1280 x 720: 59.94 fps *Shooting takes place by cropping pixels from the center of the sensor. |
| Playback Modes File | Protect, Rotate, Movie compression, Slideshow, Rating, Movie Playback, Highlight Alert, Movie Frame Grab*, Resize**, Cropping**, Tilt Correction**, Red-Eye Correction** * 4K movies only. ** Applicable only to images taken with the same model. |
| Video Out | HDMI (Type D) |
| Audio Out | Stereo |
| Other | Hi-Speed USB (Micro); direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
| Power Source | Battery Pack LP-E12 |
| Shooting Capacity | Number of still image shots (CIPA compliant): Screen ON: Approx. 325 shots Electronic color viewfinder On: Approx. 255 shots Screen ON: Approx. 405 shots in ECO Mode Video Recording Time (CIPA compliant): Screen ON: Approx. 85 min. Electronic color viewfinder On: Approx. 75 min. |
| Playback Time | Approx. 6 hrs. |
| Operating Temperature | 32-104°F/0-40°C |
| Operating Humidity | 10-90% |
| Dimensions (W x H x D) | Approx. 5.00 x 3.58 x 4.59 in. / 127.0 x 90.9 x 116.6mm |
| Weight | Approx. 1.34 lbs. / 608g (CIPA standard) Approx. 1.27 lbs. / 576g (Body only) |
| USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
| Wireless API | Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
 in the top right of the browser in the top right of the browser
 in the top right of the browser next to your download
