Canon Support for PowerShot SX710 HS | Canon U.S.A., Inc.
PowerShot SX710 HS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | 20.3 Megapixel, 1/2.3-inch CMOS |
Total Pixels | Approx. 21.1 Megapixels |
Effective Pixels | Approx. 20.3 Megapixels* *Image processing may cause a decrease in the number of pixels. |
Focal Length | 4.5mm (W) - 135.0mm (T) (35mm film equivalent: 25-750mm) |
Optical Zoom | 30x |
Digital Zoom | 4.0x |
Focusing Range | Auto: 0.4 in. (1 cm) - infinity (W), 4.6 ft. (1.4 m) - infinity (T); Normal: 2.0 in. (5 cm) - infinity (W), 4.6 ft. (1.4 m) - infinity (T); Macro: 0.4 in. - 1.6 ft. (1 - 50 cm); Sports: 3.3 ft. (1 m) - infinity (W), 26.0 ft. (8m) - infinity (T) |
Autofocus System | TTL Autofocus, Manual Focus |
Optical Viewfinder | Not available |
LCD Monitor | 3.0-inch TFT Color LCD with wide viewing angle (4:3) |
LCD Pixels | Approx. 922,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/3.2 (W), f/6.9 (T) |
Shutter Speed | 1 - 1/3200 sec. 15 - 1/3200 sec. (in Tv and M Modes) |
Sensitivity | Auto, ISO 80-3200 Available in 1-step increments |
Light Metering Method | Evaluative*1, Center-weighted average, Spot*2 *1 Facial brightness is evaluated (Face Detect AE) in Face Detect. *2 Fixed to Center, linked to AF frame |
Exposure Control Method | AE Lock |
Exposure Compensation | ±2 stops in 1/3-stop increments |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom * Facial color is evaluated in Face Detect (Face Detect WB). Adjusts the white balance separately for the main subject and the background when the flash fires |
Built-in Flash | Auto, On, Slow Synchro, Off Facial brightness is also evaluated in Face Detect |
Flash Range | 1.6 - 11 ft. (W), 4.6 - 6.6 ft. (T) / (50cm - 3.5m (W), 1.4 - 2.0m (T)) Image brightness at the corners may diminish depending on the shooting distance |
Recycling Time | 10 seconds or less (battery voltage: 3.7 V) |
Flash Exposure Compensation | ±2 stops in 1/3 increments |
Shooting Modes | M, Av, Tv, P, Live View Control, Hybrid Auto, Auto, Creative Shot1, Sports, Portrait, SmartShutter2, Handheld Night Scene, Low Light, Snow, Fireworks, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect, Standard Movie, Short Clip, iFrame Movie *1Auto, Retro, Monochrome, Special and Natural effects 2Smile, Wink Self-timer, Face Self-timer Shooting movies is possible with the movie button |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color* * Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available. |
Self Timer | Approx. 10-sec. delay, Approx. 2-sec. delay, Custom |
Wireless Control | Wi-Fi™ and NFC |
Continuous Shooting | Normal: Approx. 3.1 shots/sec. (in P mode) Normal: Approx. 8.5 shots/sec. (in High-speed Burst HQ) Under conditions where the flash does not fire automatically. Differs depending on the zoom position. |
Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards |
File Format | Design rule for Camera File system, DPOF (Version 1.1) compliant |
Image Recording Format | JPEG (Superfine, Fine) |
JPEG Compression Mode | Still Image: Exif 2.3 JPEG Video: MP4 (Image data: MPEG-4 AVC/H.264; Audio data: MPEG-4 AAC-LC (Stereo)) |
Number of Recording Pixels | Still Images: 1) 16:9 - Large: 5184 x 2912; Medium 1: 3648 x 2048; Medium 2: 1920 x 1080; Small: 640 x 360 2) 3:2 - Large: 5184 x 3456; Medium 1: 3648 x 2432; Medium 2: 2048 x 1368; Small: 640 x 424 3) 4:3 - Large: 5184 x 3888; Medium 1: 3648 x 2736; Medium 2: 2048 x 1536; Small: 640 x 480 4) 1:1 - Large: 3888 x 3888; Medium 1: 2736 x 2736; Medium 2: 1536 x 1536; Small: 480 x 480 5) In Low Light: Medium: 2592 x 1944 Videos: Full HD 1920 x 1080: 60 fps (59.94), 30 fps (29.97) iFrame Movie 1920 x 1080: 30 fps (29.97) HD 1280 x 720: 30 fps (29.97) Digest Movie 1280 x 720: 30 fps (29.97) Miniature Effect 1280 x 720*1: 6 fps, 3 fps, 1.5 fps Miniature Effect 640 x 480*1: 6 fps, 3 fps, 1.5 fps Short Clip 1280 x 720: 30 fps (29.97) 1Playback: 30 fps (29.97) |
Image data | Note: SF=Superfine / F=Fine * When in Low Light. • The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Movie data | *1 Using an SD Speed Class 10 / UHS-I compatible memory card. • Recording stops automatically once the file size reaches 4 GB or the memory card becomes full. • Recording may stop unexpectedly if a memory card with a low Speed Class is used. *2 Actual frame rate is 59.94 fps. *3 Actual frame rate is 29.97 fps. |
Playback Modes File | Still Images & Videos: Auto Rotate, Transition Effects (Off, Fade), Scroll Display, Rotate, Favorites, Search Jump (Favorites, Date, Still Images, Movies, Digest, Jump 10 Images, Jump 100 Images), Smart Shuffle, Group Playback, Movie Digest, Filtered Playback, Slideshow Still Images: Single, Index, Magnification (Approx. 2x-10x), Thumbnails, Information Display, Histogram, Overexposure Warning, Resume Playback, Red-Eye Correction, Cropping, i-Contrast, Resize, My Colors Videos: Normal Playback, Skip Backward, Previous Frame, Next Frame, Skip Forward, Resume Playback, Erase Clip, Edit Digest Movie |
Erase Modes | Select*1, Select Range, Select All Images The image data in memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased). RAW+JPEG images can be erased individually. *1 Movies can be erased individually. |
Video Out | Analog: NTSC or PAL, Digital: HDMI (HDMI™ micro connector) |
Audio Out | Stereo |
Other | SD memory card slot; direct connection to Canon SELPHY, PIXMA and PictBridge-compatible printers |
Power Source | Battery Pack NB-6LH, AC Adapter Kit ACK-DC40 |
Shooting Capacity | Approx. 230 Shots Approx. 315 Shots in ECO Mode |
Playback Time | Approx. 4 hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.44 x 2.59 x 1.37 in. / 112.7 x 65.8 x 34.8mm |
Weight | Approx. 9.49 oz. / 269g (CIPA standard) Approx. 8.64 oz. / 245g (Body only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, Vietnamese).All data are based on Canon's Standard Test Method. Subject to change without notice.Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
