Canon Support for PowerShot SX740 HS | Canon U.S.A., Inc.
PowerShot SX740 HS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Compact digital still camera with built-in flash, 40x Optical, 4x Digital and 160x Combined Zoom with Optical Image Stabilizer |
Type | 20.3 Megapixel*, 1/2.3-inch CMOS * Image processing may cause a decrease in the number of pixels. |
Total Pixels | Approx. 21.1 Megapixels |
Effective Pixels | Approx. 20.3 Megapixels |
Focal Length | 4.3 (W) - 172.0 (T) mm (35mm film equivalent: 24-960mm) |
Optical Zoom | 40x |
Digital Zoom | Approx. 4x |
Focusing Range | Auto: 0.4 in. (1cm) - infinity (W), 6.6 ft. (2.0m) - infinity (T) Normal: 2.0 in. (5cm) - infinity (W), 6.6 ft. (2.0m) - infinity (T) Macro: 0.4 in. - 1.6 ft. (1-50cm) (W) |
Autofocus System | TTL Autofocus |
Optical Viewfinder | Not available |
LCD Monitor | 3.0-inch TFT Color LCD with wide viewing angle (4:3) |
LCD Pixels | Approx. 922,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/3.3 (W), f/6.9 (T) |
Shutter Speed | 1 - 1/3200 sec. 15 - 1/3200 sec. (in all shooting modes) |
Sensitivity | Auto: ISO 100-1600 P: ISO 100-3200 |
Light Metering Method | Evaluative, Center Weighted Average, Spot |
Exposure Compensation | ±3 stops in 1/3-stop increments |
White Balance Control | Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Custom, WB Correction |
Built-in Flash | Auto, On, Slow Synchro, Off |
Flash Range | Approx. 1.6-16.4 ft. (W), 6.6-8.2 ft. (T)Approx. 50.0cm - 5.0m (W), 2.0m-2.5m (T) |
Flash Exposure Compensation | ±2 stops in 1/3 increments |
Shooting Modes | P, M, Tv, Hybrid Auto, Auto, Standard, Vivid, Neutral, B/W, Sepia, Video Snapshot, Food |
Self Timer | Off / 2 sec. / 10 sec. / Custom |
Wireless Control | Built-in Wi-Fi™ and Bluetooth® |
Continuous Shooting | High-speed Continuous Shooting in One-Shot AF mode: Approx. 10.0 shots/sec. Low-speed Continuous Shooting in One-Shot AF mode: Approx. 4.0 shots/sec. High-speed Continuous Shooting in Servo AF mode: Approx. 7.4 shots/sec. Low-speed Continuous Shooting in Servo AF mode: Approx. 4.0 shots/sec. Continuous shooting speed may become slower due to the following factors: Tv value, Av value, subject conditions, shooting environment, use of flash, ISO speed, zoom position. |
Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards |
File Format | Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible |
Image Recording Format | Fine / Normal |
JPEG Compression Mode | Still Image: EXIF 2.31 (JPEG) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo)) |
Number of Recording Pixels | Still Images:
4K 3840 x 2160: 29.97 fps Full HD 1920 x 1080: 59.94 fps, 29.97 fps HD 1280 x 720: 59.94 fps |
Playback Modes File | Protect, Rotate, Erase, Set Image Search Conditions, Slideshow, Photobook Set-up, Rating, Movie Playback, Highlight Alert, Movie Frame Grab*, Resize**, Cropping**, Tilt Correction**, Red-Eye Correction** * 4K movies only. ** Applicable only to images taken with the same model. |
Video Out | HDMI (Type D) |
Audio Out | Stereo |
Other | Hi-Speed USB (Micro); direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-13L |
Shooting Capacity | Approx. 265 shots Approx. 370 shots in ECO Mode Video Recording Time (CIPA compliant): Approx. 60 min. Video Recording Time (Continuous Shooting): Approx. 100 min. |
Playback Time | Approx. 5 hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | Approx. 4.33 x 2.51 x 1.57 in. / 110.1 x 63.8 x 39.9mm |
Weight | Approx. 10.5 oz. / 299g (CIPA standard) Approx. 9.7 oz. / 275g (Body only) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
