Canon Support for REALiS SX6000 D Pro AV | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 11.11.13
File Size 144.61 KB
Date 11.11.13
File Size 144.61 KB
Date 11.11.13
File Size 145.59 KB
Date 10.08.12
File Size 488.00 KB
Date 11.28.12
File Size 1.53 MB
Image Mode
Standard, Presentation, Vivid Photo, Photo/sRGB, DICOM SIM, Dynamic, Video, Cinema
Image Mode
PC: Standard/Presentation, Vivid Photo, User (1-5)<br/>Video: Dynamic, Photo/sRGB/Video, Cinema, User (1-5)
(Input) HDMI
Digital RGB Input
(Input) DVI-D 29pin
Digital RGB / Digital Video Input (supports Deep Color)
(Input) Mini D-Sub 15pin
Analog RGB / Component Video Input
Power
336W
Throw Ratio
1.5:1 - 2.25:1
Focal Length
23.0 - 34.5 mm, 1.5x Optical Zoom
F-Number
1.89 - 2.65
Projection Distances
4.26 - 95.14 ft. (1.3 - 29 m)
Lens Shift (Vertical)
Down 12% - Up 50%
Lens Shift (Horizontal)
Left 10% - Right 10%
Screen Sizes
40" - 600"
Throw Ratio
2.2:1 - 3.75:1
Focal Length
34.0 - 57.7 mm, 1.7x Optical Zoom
F-Number
2.0 - 2.8
6.23 - 159.12 ft. (1.9 - 48.5 m)
Down 12% - Up 50%
Screen Sizes
40" - 600"
Throw Ratio
0.8:1
Focal Length
12.8 mm
F-Number
2.0
2.29 - 17.06 ft. (0.7 - 5.2 m)
Down 5% - Up 5%
Left 2% - Right 2%
Screen Sizes
40" - 300"
Throw Ratio
3.7 &sim; 7.3:1
Focal Length
53.6 - 105.6mm
F-Number
2.34 - 2.81
15.1 &sim; 290.7 ft.
-12% &sim; 50%
&plusmn;10%
Screen Sizes
60" - 600"
Throw Ratio
1.06 - 1.58:1
Focal Length
15.56 - 23.34mm
F-Number
2.09 - 2.34
2.95-63.32 Feet (.9 - 19.3m)
Down 12% - Up 50%
Screen Sizes
40" - 600"
Projector Specifications
Imaging Device 0.72" LCOS Reflective LCD panels x 3
Aspect Ratio 4:3
Native Resolution SXGA+ (1400 x 1050)
Brightness 6000 Lumens
Uniformity 88%
Contrast Ratio 1000:1
Digital Keystone (Vertical) ± 20 degrees
Digital Keystone (Horizontal) ± 20 degrees
Optics
Projection Lens Projector does not ship with lens. 4 optional interchangeable lenses are available (see Optics listed below).
Image Adjustments
Mounting Ceiling, Rear, Rear-Ceiling, Upward, Downward
Tilt Angle Adjustable feet up to 6 degrees
Input Signals
Analog PC Input UXGA, WSXGA+, SXGA+, WXGA+, WXGA, SXGA, XGA, SVGA, VGA
Digital PC Input UXGA, WSXGA+, SXGA+, WXGA+, WXGA, SXGA, XGA, SVGA, VGA
Component Input 1080p, 1080i, 720p, 576p, 576i, 480p, 480i
Digital Video Input 1080p, 1080i, 720p, 576p, 480p
Terminals
(Input) DVI-I 29pin Analog PC, Digital PC input
(Input) HDMI: Digital PC/ Digital Video Input (supports Deep Color)
(Input) D-Sub 15pin Analog PC, Component Video Input
(Input) RJ-45 Yes
(Input) Stereo Mini Jack Audio Input x2
(Output) Stereo Mini Jack Audio Output x1
Built-in Speaker 5W (Mono)
Control Terminal D-sub 9pin: RS-232C
Network: RJ-45 (100BASE-TX / 10BASE-T)
Lamp
Lamp Type 330W NSH (AC)
Power: 336W
Remote Control
Sensor Wireless Infrared, Front/Back Wired Remote Control Connection
Ratings
Fan Noise (Quiet/Normal) 40dB
Power Consumption (Normal/Quiet/Stand-By) 435W / 1.7W (Standby) / 0.35W (Standby with LAN off)
Power Voltage AC 100 , 240V, 50/60Hz
Temperature Operating 41&deg; to 95&deg; F (5&deg; to 35&deg; C)
Temperature Storage 14&deg; to 140&deg; F (-10&deg; to 60&deg; C)
Dimension (WxHxD) 14.9 x 6.69 x 16.9 in. (without lens, including protruding parts)
Weight 18.74 lbs. without lens
Warranty 3 years parts and labor, 120 day lamp
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
