Canon Support for REALiS SX7 Mark II D | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.22.11
File Size 6.51 MB
Date 11.12.13
File Size 144.61 KB
Projector Specifications
Basic 0.7" Reflective LCD Panels (LCOS) x 3
Aspect Ratio 4:3
Native Resolution SXGA+ (1400 x 1050)
Brightness 4000 Lumens
Uniformity 88%
Contrast Ratio 1000:1
Digital Keystone (Vertical) ± 20 degrees (Auto/Manual)
Digital Keystone (Horizontal) ± 20 degrees (Auto/Manual)
Optics
Projection Lens F1.85 - 2.5, f=21.7 - 35.8 mm
Lens Shift 9:1, Fixed
Zoom 1.7x Powered, 12x Digital
Focus Powered (Auto/Manual)
Screen Size 40" - 300"
Throw Distance 3.9 - 29.5 ft.
Throw Ratio 1.46 - 2.43:1
Image Adjustments
Image Mode Standard, Presentation, Movie, Photo, Adobe RGB, sRGB
Color Adjust Dynamic Gamma, 6-Axis (RGBCMY) Color Adjustment
Wall Correction Auto / Manual
Mounting Ceiling / Rear / Ceiling and Rear
Tilt Angle Adjusting feet up to 10 degrees
Input Signals
Scanning Frequency H:15 , 100 kHz, V:50 , 100Hz, Dot clock: 170 MHz or less
Analog PC Input UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA
Digital PC Input SXGA+ / SXGA / WXGA / XGA / SVGA / VGA
Video/S-Video Input NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N
Component Input 1080i / 1035i / 720p / 576p / 576i / 480p / 480i
Digital Video Input 1080i / 1035i /720p / 576p / 480p
Terminals
(Input) DVI-I 29pin Digital PC input / Analog PC input / Digital video input
(Input) D-Sub 15pin Analog PC input / Component input
(Input) RCA x1 Video Input
(Input) Mini DIN 4pin S-Video input
(Input) RJ-45 N/A
(Input) Stereo Mini Jack Stereo audio input x3
(Output) D-Sub 15pin Analog PC out
(Output) Stereo Mini Jack Stereo audio output x1
Built-in Speaker 1W (Mono)
Control Terminal D-sub 9pin
Lamp
Lamp Type 275W NSH (AC)
Lamp Life 2000 / 3000 Hours
Remote Control
Sensor Wireless Infrared, Front / Back
Mouse Control Mouse Control Receiver (USB)
Ratings
Fan Noise (Quiet/Normal) 35 (normal) / 31 (quiet) dB
Power Consumption (Normal/Quiet/Stand-By) 360W (normal) / 290W (quiet) / 7W (stand-by)
Power Voltage AC 100 , 240V, 50/60Hz
Temperature Operating 41° to 95° F (5° to 35° C)
Temperature Storage -22° to 104° F (-30° to 60° C), 5%RH , 90%RH
Dimension (WxHxD) 10.5" x 13.2" x 4.5" (226 x 336 x 114mm)
Weight 10.6 lbs. (4.8 kg)
Warranty 3 years parts and labor, 120 day lamp
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
