Canon Support for RF100-400mm F5.6-8 IS USM | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.15.21
File Size 825.30 KB
Focal Length 100-400mm
Maximum and Minimum Aperture (Max.) f/5.6 f/8 (f/8 at 400mm position)
(Min.) f/32 f/45 (f/45 at 400mm position)
Lens Mount Type RF Mount; Metal Mount
Minimum Focusing Distance 3.94 feet (1.2m) at 100mm
2.89 feet (0.88m) at 200mm
3.44 feet (1.05m) at 400mm
Maximum Magnification 0.41x, at 400mm (0.09x at 100mm)
Field of View, at Minimum Focus Distance Approx.
(100mm) - 10.2 x 15.2 in. (260 x 386mm)
(400mm) - 2.2 x 3.3 in. (57 x 85mm)
Angle of View (Diagonal) Approx. 24° 6°10"
Compatible with Canon Extender RF1.4x / RF2x Yes
Equivalent Focal Length / Maximum Aperture RF1.4x - 140mm560mm, f/811
RF2x - 200800mm, f/1116
Maximum Close-focusing Magnification RF1.4x - 0.12x 0.58x
RF2x - 0.18x 0.83x
Autofocus with EOS R Series Cameras (as of September, 2021) Possible with either extender, at all zoom settings
Image Stabilizer, with EOS R series Cameras (as of September, 2021) Possible with either extender, at all zoom settings
Lens Construction 12 elements in 9 groups
Special Elements (One) UD-glass element
(One) Aspherical element
Lens Coating Canon SSC (Super Spectra Coating)
Filter Size Diameter ø67mm
Aperture Blades 9; circular shape
Focusing Drive System Nano USM; rear focusing system
Full-time Manual Focusing Yes (Lens Electronic MF)
Dual Pixel CMOS AF Coverage (Horizontal x Vertical) EOS R, EOS RP
Approx. 88% x 100%
With Extender RF1.4x - approx. 80% x 80%
With Extender RF2x - approx. 40% x 60%
EOS R5, EOS R6
Approx. 90% x 100%
Face+Tracking horizontal: approx. 100% x 100%
IS onoff Image Stabilizer switch, on lens barrel
Optical Image Stabilization Provided
5.5 stops optical IS correction (at 400mm)
Conforms to CIPA test standards, using EOS R
Coordinated IS (with EOS R-series cameras having In-Body Image Stabilization) Provided
6 stops Coordinated IS correction (at 400mm)
Conforms to CIPA test standards, using EOS R-series cameras with In-Body Image Stabilization
IS Mode Selection None (Automatic switching to panning correction IS, when panning is detected)
Panning Mode Support (SCN mode) Supported
Control Ring Provided (with click-stops)
Programmable via "Customize Dials" in cameras Custom Functions menu
58 clicks per revolution
Clicks can be removed by Canon service center, for a service fee
Manual Focus Ring Electronic ring system
Full-time Manual focus possible
No physical limit to ring rotational angle
Distance Scale None
Distance scale available in EVF or Live View LCD screen of compatible EOS R cameras
Distance Limiter Switch None
Dust / Weather Resistant Construction None
Maximum Outer Diameter x Length Approx. 6.48 in. x ø3.13 in. (164.7 x ø79.5mm)
Weight Approx. 22.4 oz. / 1.4 lb. / 635g
Lens hood Canon ET-74B Optional accessory, sold separately
Lens Cap (Front) Canon E-67 II (center pinch-type) (Bundled) (Rear) Canon Dust Cap RF
Dust Cap Canon Lens Dust Cap RF (Bundled)
Lens Case Canon Lens Case LP-1224 Optional accessory, sold separately
Extension Tubes None (No Canon RF mount extension tubes)
Close-up Lenses 250D / 500D None (no 67mm size available)
Canon EF Lenses Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. (Canon U.S.A.) in the United States and Canon Canada Inc., in Canada (herein referred to collectively as "Canon") with respect to the Canon Binoculars and Photographic Lens Products packaged with this Limited Warranty and identified by model number on this limited warranty card (each a "Product")when purchased and used in the United States or Canada.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase
A Product, when delivered to you in new condition in its original container, is warranted against defects in materials or workmanship as follows: for a period of one (1) year from the date of original purchase, defective parts or a defective Product returned to Canon, or its authorized service providers, and proven to be defective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product, as determined by Canon or the authorized service provider in their sole discretion. Replaced parts and exchanged Products will become the property of Canon.
When returning a Product for warranty service, the shipping charges must be prepaid and the Product should be shipped in its original container, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A copy of the warranty card and proof of purchase should be enclosed, as well as a description of the problem (including film samples, where appropriate). Repairs will be made and the Product will be returned, shipped at NO CHARGE, within the country of repair.
This warranty only covers defective materials or workmanship encountered in normal use and service of a Product and does not apply in the following cases:
a) Loss of or damage due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
b) If a Product is defective as a result of leaking batteries or liquid damage.
(c) Defective materials or workmanship where the defect is due to a Product having been serviced or modified by other than Canon or a Canon authorized service provider.
(d) Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
(e) Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
(f) Damage or service resulting from modifications or alterations to a Product in any way (including any alteration or removal of its serial number or identification marks).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO A PRODUCT SHALL BIND CANON (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, WITHOUT LIMITATION, ANY LOSS OF FILM) CAUSED BY THE USE OR MISUSE OF, OR INABILITY TO USE, A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. IN NO EVENT SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT SOLD BY CANON AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE OR MISUSE OF, OR INABILITY TO USE, THE PRODUCT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU). THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT, OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
Canon U.S.A., Inc., One Canon Park, Melville, NY 11747
Canon Canada Inc., 8000 Mississauga Road, Brampton, Ontario, L6Y 5Z7
Canon Sales and Service Center
Canon USA
One Canon Park,
Melville, NY 11747,USA
Tel: (1)-800-828-4040
Canon Canada Inc,
Brampton, Ontario, L6Y 5Z7, Canada
(1)-800-652-2666
Online Repair
What is the Control Ring's Clicking Sound Modification Service?
The click action of the control ring allows the user to have a sense of how much it is being turned. In some cases, the sound of the control ring operation may be recorded during video shooting.
Canon’s control ring’s modification service offers RF lenses and Control Ring Mount Adapter EF-EOS R owners the opportunity to remove/reattach control ring's clicking sound.
Pricing
Model Price*
RF Lens product $79.99
Control Ring Mount Adapter EF-EOS R $59.99
*Tax and freight fee are NOT included
*All pricing is subject to change
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone:1-800-OK-CANON (toll free)
1-800-652-2666
For additional support options: usa.canon.com/support
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
