Canon Support for RF1200mm F8 L IS USM Lens | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Focal Length | 1200mm |
Maximum and Minimum Aperture | f/8 - f/64 |
Lens Mount Type | RF Mount, metal |
Compatible Cameras | Canon EOS R-series |
Minimum Focusing Distance | 4.3 m / 14.1 ft. |
Maximum Magnification | 0.29x |
Field of View, at Minimum Focus Distance | Approx. 241 mm × 161 mm / 9.5 x 6.3 in. |
Angle of View (Diagonal) | 02° 05' |
Canon RF Extender 1.4x/2x | Compatible |
Equivalent Focal Length / Maximum Aperture | RF1.4x - 1680mm f/11 RF2x - 2400mm f/16 |
Maximum close-focusing magnification | RF1.4x - 0.41x RF2x - 0.60x |
Autofocus with EOS R-series cameras* * (as of 2/2022) | Possible with either extender |
Image Stabilizer with EOS R-series cameras* * (as of 2/2022) | Possible with either extender |
Lens Construction | 26 elements in 18 groups |
Special Elements | (2) Fluorite, (1) Super UD Lenses, (1) UD (Ultra-low Dispersion) |
Lens Coating | Super Spectra Coating, Fluorine Coating, ASC |
Filter Size Diameter | ο52 mm |
Aperture Blades | 9, circular shape |
Image Stabilization | 4 stops correction with In-lens Optical Image Stabilization |
Focusing Drive System | Canon USM low-speed drive (Ring USM) |
Full-time Manual Focusing | Yes (Supports both ONE SHOT AF and SERVO AF with compatible EOS R-series cameras) |
Manual Focus Speed Selection | Yes (1, 2, and 3 settings, via switch on lens) 1= fastest MF; 3= slowest MF rotation |
Focus Distance Range Selection | Yes (3 positions, via switch on lens) FULL 4.3m/14.1 feet infinity 4.3m/14.1 feet 30m/98.4 feet 30m/98.4 feet infinity |
Dual Pixel CMOS AF Coverage (Horizontal x Vertical) | EOS R5/R6 - approx. 100% x 100% EOS R - approx. 88% x 100% |
With Extender RF1.4x | EOS R5/R6 - approx. 80% x 80% EOS R - approx. 80% x 80% |
With Extender RF2x | EOS R5/R6 - approx. 40% x 60% EOS R - approx. 40% x 60% |
Power Focus | Yes, via rotation of Playback Ring Lens Focus Preset switch set to OFF; Focus Mode switch set to "PF" Two focus speeds, based on ring rotation angle |
IS On-Off | Image Stabilizer switch, on lens barrel |
Optical Image Stabilization | Provided 4 stops correction (CIPA standard) with both EOS R and R5 |
IS Mode Selection | IS Modes 1, 2 and 3 (via switch on lens barrel) Mode 1 - general shake correction Mode 2 - correction during panning Mode 3 - correction only during exposure |
Panning Mode Support (SCN Mode) | Supported |
Control Ring | Dual-function Manual focus ring / Control Ring (selected using camera menu) |
Manual Focus Ring | Electronic ring system Full-time Manual focus possible No physical limit to ring rotational angle |
AF/MF Switch | YES - AF/PF/MF Switch |
MF/Control Ring Switch | None - must be selected in camera menu |
Distance Scale | None Distance scale available in EVF or Live View LCD screen of compatible EOS R-series cameras |
Distance Limiter Switch | FULL (2.6 m to infinity) / 2.6 m to 20 m / 20 m to infinity |
Focus Pre-set Function | Yes, via Playback Ring on lens barrel Off - On - On with beep tone, via lens switch Distance memorized via Focus Preset button Two distances can be memorized; immediate return to either via direction of Playback Ring |
Lens Function Buttons (AF-Stop Buttons) | Yes; four positioned on lens barrel |
Dust / Weather Resistant Construction | Yes - rubber ring on lens mount |
Maximum Outer Diameter x Length | Approx. ο6.6 in. x 21.1 in. (ο168.0mm x 537mm) |
Weight | Approx. 117.8 oz. / 7.4 lb. / 3340g |
Lens Hood | Canon Lens Hood (long) ET-160 (Bundled) Canon Lens Hood (short) ET-160B (Sold Separately) |
Lens Cap | Canon E-185C (Bundled) |
Dust Cap | Canon Lens Dust Cap RF (Bundled) |
Lens Case | Canon Lens Soft Case LS1200 (Bundled) |
Extension Tubes | None (No Canon RF mount extension tubes) |
Close-up Lenses 250D / 500D | Not compatible |
Drop-in Filters | Compatible - 52mm Drop-in Filter Holder 52 (WIII) Included Accepts 52mm screw-in filters Canon 52mm clear Protect Filter included |
Canon EF Lenses Limited Warranty |
The limited warranty set forth below is given by Canon U.S.A., Inc. (Canon U.S.A.) in the United States and Canon Canada Inc., in Canada (herein referred to collectively as "Canon") with respect to the Canon Binoculars and Photographic Lens Products packaged with this Limited Warranty and identified by model number on this limited warranty card (each a "Product")when purchased and used in the United States or Canada. This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase A Product, when delivered to you in new condition in its original container, is warranted against defects in materials or workmanship as follows: for a period of one (1) year from the date of original purchase, defective parts or a defective Product returned to Canon, or its authorized service providers, and proven to be defective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product, as determined by Canon or the authorized service provider in their sole discretion. Replaced parts and exchanged Products will become the property of Canon. When returning a Product for warranty service, the shipping charges must be prepaid and the Product should be shipped in its original container, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A copy of the warranty card and proof of purchase should be enclosed, as well as a description of the problem (including film samples, where appropriate). Repairs will be made and the Product will be returned, shipped at NO CHARGE, within the country of repair. This warranty only covers defective materials or workmanship encountered in normal use and service of a Product and does not apply in the following cases: a) Loss of or damage due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.b) If a Product is defective as a result of leaking batteries or liquid damage. (c) Defective materials or workmanship where the defect is due to a Product having been serviced or modified by other than Canon or a Canon authorized service provider. (d) Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications. (e) Damage resulting during shipment. (Claim must be presented and examined by the shipper.) (f) Damage or service resulting from modifications or alterations to a Product in any way (including any alteration or removal of its serial number or identification marks). NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO A PRODUCT SHALL BIND CANON (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, WITHOUT LIMITATION, ANY LOSS OF FILM) CAUSED BY THE USE OR MISUSE OF, OR INABILITY TO USE, A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. IN NO EVENT SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT SOLD BY CANON AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE OR MISUSE OF, OR INABILITY TO USE, THE PRODUCT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU). THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT, OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY. Canon U.S.A., Inc., One Canon Park, Melville, NY 11747
