Canon Support for RF24-105mm F2.8 L IS USM Z | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Focal Length | 24-105 mm |
Maximum and Minimum Aperture | f/2.8 - f/22 |
Lens Mount Type | RF Mount |
Compatible Cameras | Canon EOS R-series, full-frame and APS-C (focal length equivelant to approx. 38.4-168mm when used on an APS-C camera) |
Minimum Focusing Distance | 0.45 m/1.48 ft. (at 24 mm), 0.45 m/1.48 ft. (at 105 mm) |
Maximum Magnification | 0.08x (at 24 mm), 0.29x (at 105 mm) |
Field of View | 24mm: approx. 16.0 x 10.7 in. (408 x 272mm); 105mm: approx. 4.8 x 3.2 in. (121 x 80mm) |
Angle of View (Diagonal) | Approx. 84° - 23° 20 |
Lens Construction | 23 elements in 18 groups |
Special Elements | 4 UD elements, 3 Aspheric elements |
Lens Coating | Canon SSC (Super Spectra Coating), ASC (Air Sphere Coating), Flourine coating |
Filter Size Diameter | ø82 mm |
Aperture Blades | 11 |
Image Stabilization | 5.5 stops correction with In-lens Optical Image Stabilization (8.0 stops correction with EOS R series in-body coordinated Image stabilization) |
Focusing Drive System | (Two) Canon Nano USM focus motors |
Full-time Manual Focusing | Yes (Supports both ONE SHOT AF and SERVO AF with compatible EOS R-series cameras) |
Dual Pixel CMOS AF Coverage (Horizontal x Vertical) | EOS R/RP/Ra/R100 Approx. 88% x 100% EOS R5/R6 With face + tracking-priority AF: Approx. 100% × 100% Other than with face + tracking-priority AF: Approx. 90% × 100% EOS R3, R6, Mark II, R8 R7, R10, R50 For whole area AF: Approx. 100% × 100% For non-whole area AF when subject has been detected: Approx. 100% × 100% When subject has not been detected: Approx. 90% × 100% |
Focusing / Control Ring | Yes, with click stops (click stops can be removed by a Canon service facility, for a fee) |
Manual Focus Ring | Electronic ring system Full-time Manual focus possible No physical limit to ring rotational angle |
AF/MF Switch | Yes |
Distance Scale | None (Electronic distance scale possible in viewfinder or LCD monitor, with compatible EOS R-series cameras) |
Distance Limiter Switch | Provided: Full/1 m to infinity |
Dust / Weather Resistant Construction | Yes |
Maximum Outer Diameter x Length | Approx. ø3.5 in. (ø88.5mm) x 7.8 in. (199mm) |
Weight | Approx. 46.9 oz. / 2.9 lbs. / 1330g |
Lens hood | Canon Lens Hood EW-88E (Bundled) |
Lens Cap | Canon Lens Cap E-82 II (Bundled) |
Dust Cap | Canon Lens Dust Cap RF (Bundled) |
Lens Case | Canon Lens Case LZ1326 (B) (Bundled) |
Lens Holder | Canon Lens Holder LH-E1 (not bundled, sold separately) |
Extension Tubes | None (No Canon RF mount extension tubes) |
Close-up Lenses 250D / 500D | Not compatible |
Canon RF Extender 1.4x/2x | Not compatible |
Canon Gelatin Filter Holder III/IV | Not compatible |
EOS System Lens Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. (Canon U.S.A.) in the United States and Canon Canada Inc., in Canada (herein referred to collectively as "Canon") with respect to the Canon Binoculars and Photographic Lens Products packaged with this Limited Warranty and identified by model number on this limited warranty card (each a "Product")when purchased and used in the United States or Canada.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase
A Product, when delivered to you in new condition in its original container, is warranted against defects in materials or workmanship as follows: for a period of one (1) year from the date of original purchase, defective parts or a defective Product returned to Canon, or its authorized service providers, and proven to be defective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product, as determined by Canon or the authorized service provider n their sole discretion. Replaced parts and exchanged Products will become the property of Canon.
When returning a Product for warranty service, the shipping charges must be prepaid and the Product should be shipped in its original container, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A copy of the warranty card and proof of purchase should be enclosed, as well as a description of the problem (including film samples, where appropriate). Repairs will be made and the Product will be returned, shipped at NO CHARGE, within the country of repair.
This warranty only covers defective materials or workmanship encountered in normal use and service of a Product and does not apply in the following cases:
(a) Loss of or damage due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
(b) If a Product is defective as a result of leaking batteries or liquid damage.
(c) Defective materials or workmanship where the defect is due to a Product having been serviced or modified by other than Canon or a Canon authorized service provider.
(d) Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
(e) Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
(f) Damage or service resulting from modifications or alterations to a Product in any way (including any alteration or removal of its serial number or identification marks).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO A PRODUCT SHALL BIND CANON (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, WITHOUT LIMITATION, ANY LOSS OF FILM) CAUSED BY THE USE OR MISUSE OF, OR INABILITY TO USE, A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. IN NO EVENT SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT SOLD BY CANON AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE OR MISUSE OF, OR INABILITY TO USE, THE PRODUCT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU). THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT, OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
Canon U.S.A., Inc., One Canon Park, Melville, NY 11747
Canon Canada Inc., 8000 Mississauga Road, Brampton, Ontario, L6Y 5Z7
Canon Sales and Service Center | |||
Canon USA One Canon Park, Melville, NY 11747,USA Tel: (1)-800-828-4040 |
Canon Canada Inc, 8000 Mississauga Road Brampton, Ontario, L6Y 5Z7, Canada (1)-800-652-2666 |
