Canon Support for SELPHY CP1500 | Canon U.S.A., Inc.
SELPHY CP1500
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.19.22
File Size 142.00 B
Canon PRINT App - iOS
With the Canon PRINT App, easily print your favorite social media memories from popular platforms such as Facebook™ and Instagram™ right from your iOS® or Android™ device.
Canon PRINT App - Android
SELPHY Photo Layout - iOS
Download the SELPHY Photo Layout App for a fun and easy way to arrange your pictures into unique layouts. Flex your creative muscles by selecting from a range of customizable formats, including bookmarks, borders and labels.
SELPHY Photo Layout - Android
Printer Type Compact Photo Printer
Printing Method Dye-sublimation thermal transfer
Print Resolution 300x300 dpi, Cyan, Magenta, Yellow Film 256 levels/color (16.8 million colors)
Print Features Borderless/Bordered Printing, Bookmark Printing, 2-up fixed size print, Index Print, Reprint, QR Code Print, overcoat pattern printing, Shuffle Print
Hardware Features 3.5" LCD Screen, Wireless Printing, Anti-theft wire lock slot, 18 language support
OS Compatibility macOS, Windows 111
App support Canon PRINT Inkjet/SELPHY, SELPHY Photo Layout v3.02
Print Longevity 100 years3
Print Finishes Glossy / Semi-Gloss / Satin (user selectable)
WiFi compatible with 802.11 b/g (2.4 GHz), AirPrint4,5
USB USB 2.0 Type C (USB charging not supported) for computer and flash drive
Card Slots Direct: SD, SDHC, or SDXC
With adapter: miniSD, miniSDHC, microSD, microSDHC, micro SDXC
AC Compact power adapter Included
USB-C charging Not Supported
Battery Pack (optional) NB-CP2LH (sold separately) Up to 54 prints on a full charge
Maximum Outer Diameter x Length Approx. 7.2" (W) x 2.3" (H) x 5.2" (D)
Weight Approx. 1.9 Lbs
PCPL-CP400 Postcard and L size paper cassette (Included)
PCC-CP400 Card size paper cassette (for card size printing)
Supported Paper Sizes Postcard (4.0 x 6.0)
L Size (3.5 x 4.7)
Card Size (2.1 x 3.4)
Square Label (2.1 x 2.1)
Output tray capacity up tp 18 sheets
1. Operation can only be guaranteed on a PC with pre-installed Windows 11, latest version of macOS recommended.
2. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app or SELPHY Layout app, available for free on the App Store and at Google Play. Your device must be connected to the same working network with wireless 802.11 b/g capability as your printer.
3. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, display/storage conditions, and environmental factors.
4. Wireless printing requires a working network with wireless 802.11b/g 2.4ghz compatibility. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
5. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
Canon Card Photo Printer Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. in the United States and Canon Canada Inc. in Canada with respect to the Canon brand Card Photo Printer (the “Product”) purchased with this limited warranty, when purchased and used in the United States or Canada. This limited warranty only applies to the Product packaged with this limited warranty. Canon U.S.A., Inc. will be referred to collectively herein as “Canon.”
The product, when delivered to you in new condition in its original container, is warranted against defects in materials and workmanship under normal use and service for a period of 1(one) year from the date of original purchase. Defective parts or a defective Product returned to Canon, or an Authorized Service Center, and proven to be detective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product as determined by Canon or the Authorized Service Center. Warranty replacement shall not extend the original period. This warranty does not cover any accessories, nor does it cover any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. Non-Canon brand equipment and software that may be distributed with the Product are sold “as is” and without warranty of any kind by Canon, including any implied warranty or condition regarding merchantability or fitness for a particular purpose, and all such warranties and conditions are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or Authorized Service Center. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the printer, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon) that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. Use of supplies or parts (other thank those distributed by Canon)
  4. If the Product has had its serial number or dating defaced, altered or removed.
  5. If the Product is used for commercial or industrial use.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCTS AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY, GUARANTY OR CONDITION, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON, OR ITS AUTHORIZED SERVICE CENTER. (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATION ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON, OR ITS AUTHORIZED SERVICE CENTER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON, OR ITS AUTHORIZED SERVICE CENTER, BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE.  WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON, OR ITS AUTHORIZED SERVICE CENTER. (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
For Products Purchased in the U.S.A.
You may obtain technical support for your Product as follows:
E-mail support via our Web Site at www.usa.canon.com
Telephone assistance from a Canon U.S.A. Customer Care representative free of charge during regular business hours (currently Monday-Friday 9:00am-8:00pm EST, excluding holidays) at 1-800-OK-Canon (1-800-652-2666)
For Products Purchased in Canada
You may obtain technical support for your product as follows:
Telephone assistance from a Canon Canada customer Care representative free of charge during regular business hours (currently Monday-Friday 9:00am-8:00pm EST, excluding holidays) at 1-800-OK-Canon (1-800-652-2666)
Have your Product serial number and your date of purchase available when you make the call to expedite service. A Canon Customer Care representative will attempt to diagnose the nature of the problem and correct it over the telephone. If the problem cannot be corrected over the telephone, you will be asked to follow the applicable procedures for Mail-In Service. Note that a dated proof of purchase is required at the time of service. This requirement will be satisfied by providing a copy of your dated bill of sale.
*Technical support program specifics subject to change without notice.
MAIL-IN SERVICE
MAIL-IN SERVICE is a program under which your Product is repaired by a Canon U.S.A. or Canon Canada Authorized Service Center. You will be given the name, address and phone number of an Authorized Service Center, by contacting the Canon U.S.A. Customer Care Center at 1-800-828-4040 or Canon Canada Customer Information Centre at 1-800-OK-CANON (1-800-652-2666). It is your responsibility to properly package and send the defective product together with a copy of your dated proof of purchase, a complete explanation of the problem and a return address to the Authorized Service Center at your expense. Do not include any other items with the defective Product. The defective Product covered by this limited warranty will be repaired and returned to you without charge by the Authorized Service Center. Any product received bye the Authorized Service Center this is not covered by the limited warranty will be returned unrepaired, or, at the discretion of the Authorized Service Center, you may receive a written estimate of repair at such cost as the Authorized Service Center may establish from time to time.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
Canon Canada Inc.
6390 Dixie Road
Mississauga, Ontario L5T 1P7
Canada
(The above addresses are not to be used for the MAIL-IN SERVICE program.)
Title Firmware Notice: SELPHY CP1500: Firmware Version 1.0.6.0
Advisory Type Firmware Notice
Date 12.11.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
