Canon Support for varioPRINT 135/120/110 | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Finisher-AK1/AK2
File Name
Operating Information
File Name
Quick Reference Guide - Print from USB
File Name
Quick Reference Guide - Scan to USB
File Name
Quick Reference Guide - Make Basic Copy
File Name
Safety Information
File Name
Quick Reference Guide - Scan to Email
File Name
Professional Puncher-B1
File Name
Document Insertion Unit-F1
File Name
High Capacity Stacker-E1
File Name
Booklet Trimmer-D1
File Name
Duplex Color Image Reader Unit D1
File Name
Two Knife Booklet Trimmer-A1
File Name
Paper Folding Unit-F1
SELECT ERROR CODE
Model Name | varioPRINT 135/120/110 |
Type | DirectPress |
Printing Resolution | Engine: 600 x 2400 dpi / 200lpi PCL: 600 x 600 dpi Adobe PostScript 3: 600 x 2400 dpi, 1200 x 1200 dpi (Enhanced) |
Letter | (Simplex / Duplex:) 120/110/100 ipm / 135/120/110 ipm |
Ledger | (Simplex / Duplex:) 63/57/52 ipm / 70/63/57 ipm |
First Copy Time | 3.9 seconds |
Maximum Original Size | 12.6" x 19.2" (320 x 488 mm) |
Standard Paper Capacity | 4000 sheets (80 gsm) Trays 1 & 2: 1500 sheets (Ltr, Statement**) Tray 3: 500 sheets from 5.5" x 7.17" (140x 182mm) to 12.6" x 17" (320 x 432 mm) Tray 4: 500 sheets from 5.5" x 7.17" (140 x 182 mm) to 12.6" x 19.2" (320 x 488 mm)Feeding Technology (iPIM - internal Paper Input Module): Roller fed 14 lb. bond - 110 lb. cover (50-300 gsm) |
Acceptable Paper Weights
Duplexing | Up to 300 gsm |
Power Requirements | 208V/20A |
Dimension | 56.3" x 44.5" x 30.1" (1430mm x 1130mm x 765mm) |
Weight | 579.8 (263 kg) |
Estimated Toner Yield | 96,000 / per 2 bottles* |
Feeders
Description | Color Image Reader (Single-pass Duplex Automatic Document Feeder and Black & White/Color Scanner) |
Acceptable Originals | Statement, Letter, Legal, 11" x 17", Custom Sizes ADF: 5.5" x 5.04" (140 x 128mm) to 17" x 12" (432 x 305 mm) |
Scanning Speed | BW/Color: Up to 120 ipm (300 x 300 dpi) BW: Up to 100 ipm (600 x 600 dpi) Color: Up to 105 ipm (600 x 300 dpi) Up to 25 ipm (600 x 600 dpi) |
Capacity | 300 sheets (20 lb. bond) |
Power Source | From main unit |
Paper Supply Options
Description | ePIM (external Paper Input Module) |
Paper Capacity | 8,000 sheets with Duo Tray Option, (4,600 Standard) |
Paper Sizes | 8" x 8" (203 x 203 mm) to 12.6" x 19.2" (320 x 488 mm) |
Paper Weights | 14 lb. bond - 110 lb. cover (50-300 gsm)Feeding Technology: Air Separation, Suction Feeding |
Power Source | 120V/15A |
Dimensions | 40.9" x 38.6" x 29.5" (1040mm x 980mm x 750mm) |
Weight | 440.9 lbs (200 kg) |
Description | Document Insertion Unit-F1 (Optional) |
Paper Capacity | 400 Sheets (200 x 2) (20 lb. Bond) |
Paper Sizes | 13" x 19.2" |
Paper Weights | 14 lb. Bond to 110 lb. Cover (50gsm to 300gsm) |
Dimensions | 55.37" x 29.37" x 31.25" (1407mm x 746mm x 793mm) |
Weight | 134 lb. (61kg) |
