Canon Support for Wireless File Transmitter WFT-E8A | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.08.16
File Size 4.64 MB
Date 03.08.16
File Size 3.31 MB
Software Development Kit
Type
IEEE 802.11ac/n/a/g/b wireless LAN support; Image transfer accessory
Compatible Cameras
EOS-1D X Mark II Camera
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser-based remote image/video capture with downloading, playback and browsing of images/video over a network
Linked Shooting
Max. 10 receiver cameras
Transmission Range: Approx. 328 ft. / 100m from the sender camera (when signal strength is favorable)
WFT Server Start: Possible at manual connection with receiver camera
Transmission Range
Linked Shooting:
Wireless LAN:
Using an access point: Max. approx. 492 ft./150m
Transmitting directly to a smartphone: Max. approx. 49.2 ft./15m
In linked shooting: Max. approx. 328 ft. / 100m
With no obstructions between the transmitting and receiving antennas and no radio interference
Camera Connection
Terminal
Wired LAN Connection
None
External Device Connection
Available
Power Supply
Powered by the camera
Image Transfer Capacity
When a fully charged Wireless File Transmitter WFT-E8A is used with the EOS-1D X Mark II camera. Under Camera & Imaging Products Association (CIPA) conditions for testing shooting capacity, when using automatic image transfer with images that are approx. 6MB. Fewer images can be transferred if the wireless LAN transfer speed drops, and for consecutive image transfer over wireless LAN. If the remaining battery level drops below 19%, captured images cannot be transferred.
W x H x D
Approx. 0.97 x 2.24 x 1.34 in. / 24.7 x 57.0 x 34.1mm
Ounces/grams
Approx. 1.34 oz. / 38g
Temperature
32°F to 113°F/0°C to 45°C
Humidity
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: EOS C700 - EOS C700 PL: Firmware Version 1.0.7.1.00
Advisory Type
Date 12.12.18
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
