Web Content Viewer
Actions
Canon CX-G6400 4" Inkjet Card Printer
Inkjet Card Printers
Item Code: 1749C002AA
Features
Speed, Security & Accuracy
When guests and clients arrive, you need to check them in, get them their credentials and make sure they look good and accurate - so you definitely don't have time to wait, you need a printer that can keep up. This advanced printer can turn out business cards at speeds of up to 100 cards per minute and CR80 ID cards at speeds up to 45 cards per minute.1 This means more prints in less time, perfect for handling large volumes, such as at trade shows, and long lines at important events. All with an ultra-crisp print resolution of 1200 x 1200 dpi using dye-based inks for accurate color-critical graphics. When you're entrusted with personal information and secure details, security is paramount. Since all information is printed on the spot and not imprinted on thermal ribbons, experience peace of mind with inkjet.
Print on a Wide Variety of Media
Print what you need, no matter your event. The Canon CX-G6400 can print on matte papers, glossy papers, card stock, envelopes, and plastic all up to 4" wide. This versatility enables you to print business cards, visitor badges, and large format credentials on paper, as well as ID badges and credentials on plastic-all on the same machine-and with fewer stops to load new media.
More Output with Less & Easy Maintenance
The CX-G6400 uses easy-to-replace inkjet cartridges that last for thousands of prints. A great convenience during busy periods when seamless production is vital. When high volume printing is needed, the CX-G6400 offers superior ease of use and simplicity reflected in the design with only three buttons on the printer itself.
Specifications
Printer
Printing Method
Dye-based Inkjet
Print Mode
Single Sided (Simplex)
Print Speed (up to)
First Print Out Time: Business Card: 12 seconds or less1
Business Card: 100 Cards/minute (6,000 Cards Per Hour (CPH)) 1
Plastic Card (CR80): 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
4x6 Postcard: 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
Envelope: 28 Envelopes/minute
Number of Nozzles
5,185 dots
Print Resolution (Up to)
1200x1200 dpi
Ink Compatibility
4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Maximum Printable Area
Width: 107.8 mm / 4.2
Length: 297.0 mm / 11.7
Minimum Margin
Top/Bottom: 1.5 mm
Left/Right: 2.0 mm
Paper Thickness
Paper/Plastic: 0.21 - 0.76 mm / 8.27 - 30 mil
Envelope: 0.24 - 0.48 mm / 9.45 - 18.9 mil
Automatic Sheet Feeder
Paper feed capacity2
Plastic & Paper Card: 400 Cards
Envelope: 100 Envelopes
Paper Compatibility
Paper Card: Business Cards, Credential, Envelope, Postcard
Plastic Card: 2 x 3.5 PVC (CR80, CR100)
Custom Size: Paper/Plastic within Maximum Printable Size & Up to 30 mil
Body Durability
1.5 Million Sheets / 5 Years
Estimated Output Number
Approx. 24,000 Sheets per cartridge set2
Maximum Paper Size
Width: 85.0 - 120.0 mm / 3.3 - 4.7
Length: 49.0 - 300 mm / 1.9 - 11.8
General
OS Compatibility
Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit)3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
Power Source
AC 100v - 240v, 50/60 Hz
Power Consumption (approx.)
Maximum: Approx. 229 W
Operating: Approx. 135 W
Sleep Mode: Approx. 8.5 W or Less
Dimension (W x D x H)
23.4 (W) x 16.1 (D) x 18.3 (H)6
Weight
55.1lbs.6
Operating Temperature:
Temperature: 41° - 95°F (5° - 35°C)
Operating Humidity:
Humidity: 10-90% RH (Non-Condensing)
Noise
Acoustic Information4:
Operating Noise (Max.): 58dB or less
Standby Noise: 35dB or less
Cartridge Fill Volume
Black / Cyan / Magenta / Yellow: 105 ml
Maintenance Cartridge Info & Fill Volume
WT-X401 Maintenance Cartridge 1
Approx. 72,000 Sheets1
Operational Method
LCD: No
Buttons/LEDs: 3 Buttons / 8 LEDs
Warranty
2 Year Warranty5
Canon CX-G6400 Box Contents
Canon CX-G6400 Box Contents Canon CX-G6400 4" Inkjet Card Printer Head Package Unit Power Cord Set of Ink Tanks (BK, C, M, Y, 105 ml/each) Maintenance Cartridge (Installed) Printer Driver/User Guide CD Getting Started Guide & Unpacking Instructions Installation Adjustment Paper (Postcard Size) Warranty Card
Resources
Datasheet
Canon CX-G6400 4” Inkjet Card Printer
04/29/21
2.96 MB
This is to make Misc appear on the page when needed.
DISCLAIMERS
  1. Based upon standard business card print conditions with no image and print size of 2"x3.5" inkjet coated matte business card, 7.5% Duty/Color, 100 sheets x 3 jobs/day x 20 days/month. Print speed based on click to drop, average print coverage, with USB connectivity, Cards Per Hour (CPH).
  2. With Standard condition: 7.5%Duty, Business card size:100 sheets x 3 jobs / day
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit).
  4. Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
  5. Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  6. Printer weight measured excluding printhead or ink cartridges installed.
 Return to Top
