Capturing a scene is often an exercise in managing extremes. A cinematographer may be exposing for a subject indoors while bright daylight pours through a window behind them. An exterior scene might include a subject in shadow against a brightly lit sky. Even practical lights within a frame can create areas that are significantly brighter than the primary subject.
In situations like these, dynamic range becomes especially important. The more information a camera can retain across the brightest highlights and darkest shadows of a scene, the more flexibility filmmakers have to shape the final image.
A new firmware update for the Canon Cinema EOS C400 and EOS C80 cameras adds Cinema Exposure Mode. This is a specialized shooting mode designed to give filmmakers greater control over how the camera’s dynamic range is allocated when shooting in Canon Log 2.
Rather than simply maintaining the same distribution of dynamic range as ISO increases, Cinema Exposure Mode can shift more of that range toward the highlights. The result is additional highlight latitude when it’s needed and greater flexibility for colorists working with the image in post-production.
Understanding Dynamic Range
To understand what Cinema Exposure Mode does, it helps to first look at dynamic range.
In its simplest terms, dynamic range describes the range between the darkest and brightest areas a camera can capture while retaining usable image information. It is typically measured in stops, with each stop representing a doubling or halving of light.
For cinematographers, greater dynamic range provides more latitude when working with high-contrast scenes. Instead of bright portions of an image quickly clipping to white or darker portions losing usable detail, the camera can retain information across a wider range of brightness values.
Where that range falls in relation to the scene’s exposure is also important.
One common reference point is 18% gray, which is traditionally used to represent middle gray when evaluating exposure. The available dynamic range of a camera can therefore be considered in terms of how many stops are available above middle gray for highlights and how many are available below it for shadows.
Cinema Exposure Mode provides filmmakers with a new way of controlling that balance.
Shifting the Balance
When shooting Canon Log 2 through the standard Custom Picture Menu, increasing ISO above its base value does not change the amount of dynamic range available above 18% gray. That value remains 6.3 stops, regardless of the ISO selected.
Cinema Exposure Mode changes that behavior.
As ISO is increased by a full stop above the camera’s base ISO, the allocation of dynamic range shifts farther into the highlights. Using a base ISO of 800 as an example, Canon Log 2 normally provides 6.3 stops of dynamic range above 18% gray. Increasing the setting by one stop to ISO 1600 while using Cinema Exposure Mode increases the highlight-side range to 7.3 stops above 18% gray.
Move another stop to ISO 3200, and that increases to 8.3 stops above 18% gray.
Cinema Exposure Mode provides up to two additional stops of dynamic range on the highlight side. Once that maximum is reached, increasing ISO farther does not continue shifting the range. ISO selections beyond two full stops from the base ISO maintain the maximum 8.3 stops above 18% gray.
An important distinction is that Cinema Exposure Mode isn’t adding dynamic range beyond what the sensor itself can capture. Instead, it changes how that available range is allocated between the highlight and shadow regions as a function of ISO sensitivity. Cinema Exposure Mode works exclusively with Canon Log 2 and is designed to maintain the sensor’s full 16 stops of dynamic range at higher ISO ranges.
In practical terms, filmmakers now have another way to decide where they want more of the camera’s available exposure latitude to fall.
Cinema Exposure Mode is available for the Cinema EOS C400 and EOS C80 cameras through the firmware update released August 19, 2026. Once the appropriate firmware has been installed, users can select Cinema Exposure Mode through the camera’s Capture Mode menu. Because the feature is designed specifically around Canon Log 2, Cinema Exposure Mode operates within the Canon Log 2 workflow.
Why More Highlight Latitude Matters
Consider an interview filmed inside an office with a large window behind the subject. The filmmaker may want to properly expose the person’s face while still retaining the view through the window. Because the exterior can be many stops brighter than the subject, protecting both portions of the image can be challenging.
A similar situation can occur when shooting a person strongly backlit by the sun. Exposure may be appropriate for the subject while the brightest areas of the sky approach the limits of what the camera can retain.
These are exactly the types of scenes where Cinema Exposure Mode can be particularly useful. By shifting more of the camera’s dynamic range toward the highlights, a cinematographer has greater latitude for retaining information in those bright portions of the frame and suppressing highlight clipping.
Other productions can present similar challenges: bright practical lights within a dark interior, reflective surfaces, sunlit areas alongside deep shade or any composition containing a significant difference between the subject exposure and the brightest elements in the frame.
Rather than allowing those highlights to reach clipping as quickly, Cinema Exposure Mode gives filmmakers additional room to preserve them.
Designed with Post-Production in Mind
While the benefits begin at capture, much of the creative advantage of Cinema Exposure Mode becomes apparent in post-production.
Log recording is designed to retain a wide range of image information for subsequent color correction and grading. Canon Log 2 is particularly well suited to workflows in which filmmakers expect to extensively shape the image after shooting.
Cinema Exposure Mode builds on that flexibility.
Preserving additional highlight information gives the colorist more image data to work with when balancing a difficult shot or creating the finished look. Highlights can be brought under control, shadows can be adjusted and contrast can be shaped without reaching the limits of the captured image as quickly.
This doesn’t mean that exposure becomes less important on set. Cinema Exposure Mode is another exposure tool, not a replacement for making deliberate exposure decisions. Its advantage is that cinematographers can choose an allocation of dynamic range that better matches the needs of a particular scene and the intended post-production workflow.
That can be especially valuable for productions involving extensive color grading, where retaining as much usable information as possible gives the colorist greater latitude and creative control.
Choosing When to Use Cinema Exposure Mode
Cinema Exposure Mode isn’t necessarily something that needs to be enabled for every shot. Its value becomes most apparent when the characteristics of the scene call for additional highlight-side latitude.
A cinematographer shooting a relatively low-contrast environment may have little need to shift additional dynamic range toward the highlights. But when bright areas become difficult to contain, or when preserving highlight detail is particularly important, Cinema Exposure Mode provides another option for managing the scene.
That makes understanding the image in front of the camera important. Instead of thinking only about whether an ISO setting makes an image brighter or darker, filmmakers can consider how changing ISO within Cinema Exposure Mode affects where the camera’s available dynamic range is being allocated.
It becomes another creative exposure decision: Where does this particular scene need the greatest latitude?
More Latitude, More Creative Control
Ultimately, Cinema Exposure Mode gives Cinema EOS C400 and EOS C80 users another way to approach one of cinematography’s most fundamental challenges: deciding how to capture and preserve the range of light within a scene.
For productions where protecting highlights is particularly important, filmmakers can shift more of the camera’s available dynamic range toward those brighter portions of the image. That can mean greater latitude when shooting challenging scenes with strong backlighting, bright windows or other high-contrast elements that might otherwise approach clipping.
Just as importantly, the benefits extend beyond the shoot itself. By retaining more usable image information in the highlights, Cinema Exposure Mode gives colorists greater flexibility to adjust highlights and shadows, shape contrast and create the desired look in post-production.
For cinematographers and post-production professionals working with extensive color-grading workflows, that additional flexibility translates into greater creative control. And by adding Cinema Exposure Mode to the Cinema EOS C400 and EOS C80 cameras, this firmware update is expanding the capabilities of cameras already in filmmakers’ hands. Plus, it gives users another tool for capturing challenging scenes while helping the cameras continue to meet evolving production and post-production demands.
