Firmware Notice: RC-IP1000: Firmware Version 1.2.0
Firmware Version 1.2.0 incorporates the following enhancements:
  1. Adds support for the following latest versions of remote PTZ camera’s firmware:
    CR-N700 (Ver. 1.6.0), CR-N500 (Ver. 1.7.0), CR-N300 (Ver. 1.7.0), CR-N100 (Ver. 1.2.0),
    CR-X300 (Ver. 1.4.0)
  2. Adds support for the following latest version of add-on applications:
    Auto Tracking Application RA-AT001 (Ver. 1.3.0)
  3. Adds support for the EOS C80.
  4. Enables the ability to START / STOP add-on applications and control their auto-start ON / OFF.
  5. Adds the ability to register a preset by pressing and holding the PRESET Select Button on the touch panel.
  6. Adds a new layout to the Preset List.
  7. Adds the ability to select ON / OFF for IP video reception.
  8. Enables assigning external output video switching to the USER button.
  9. Enables camera number selection using Elgato Stream Deck even when the main unit is in [PRESET / GROUP] mode.
  10. Enables control of cameras with the same IP address within a camera group by distinguishing them using port numbers.
  11. Adds a setting to disable user authentication for the XC protocol communication server function.
  12. Adds an ExCAM operation UI.
  13. Adds the ability to Enable / Disable High Bit Rate Streaming for RTP.
Refer to the RC-IP1000 Settings Guide for instructions on updating the firmware.
<Firmware file>
- update_rcip1200.rom
The firmware contains software modules developed by third parties.
For details and license conditions for each module, see ReadMe-E.txt in the downloaded file and rcip1000-ossinfo.pdf in the "ThirdPartySoftware" folder in the "LICENSE" folder.
Caution:
Do not turn off the power to the controller while performing the firmware update.
Update the camera, application, controller to the latest firmware.
Environment:
Windows 10 64bit, Windows 11
macOS 14, macOS 15
Supported Models:
LAN (XC Protocol)
CR-N700, CR-N500, CR-N300, CR-N100, CR-X300, EOS C500 Mark II, EOS C400, EOS C300 Mark III, C80, EOS C70, XF605
RS-422 (NU Protocol)
CR-X500, CR-X300, XF605
Preparations for a firmware update:
  1. Download the file to any folder.
  2. Extract files from a compressed file (ZIP file).
  3. For further instructions, refer to the RC-IP1000 Settings Guide for instructions on updating the firmware.
Support
Download Firmware Version 1.2.0.
To help obtain optimal performance, we recommend that you also download and install the most recent versions of Canon Software and the Instruction Manual.
If you have not already done so, please register the Canon Products. By registering, we will be able to notify you via email about future announcements.
This information is only for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone: 1-855-CINE-EOS (toll free) / 1-855-246-3367
TDD: 1-855-270-3277
