Firmware Notice: RF24-105mm F4 L IS USM: Firmware Version 2.0.7
Firmware Version 2.0.7 incorporates the following enhancement and fix:
  1. Adds full-time manual focus, which allows constant manual focus adjustment in both One-Shot and Servo AF modes. *This function is enabled when used with compatible cameras.
  2. Adds the ability to use the focus ring as a control ring.
    Example: By assigning the control ring the ability to change the aperture, you can adjust the aperture without click sounds being recorded by the microphone. *This function is enabled when used with compatible cameras.
  3. Improves other system stability.
Please perform the firmware update with only a firmware file to be updated stored on the memory card.
Firmware Version 2.0.7 is for lenses with firmware up to Version 2.0.6. If the lens’ firmware is already Version 2.0.7, it is not necessary to update the firmware.
Support
Download Firmware Version 2.0.7 for the RF 24-105mm F4 L IS USM.
To help obtain optimal performance of this camera, we recommend that you also download the RF 24-105mm F4 L IS USM Instructions.
If you have not already done so, please register the RF 24-105mm F4 L IS USM. By registering, we will be able to notify you via email about future announcements.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone: 1-800-OK-CANON / 1-800-652-2666
TDD: 1-855-270-3277
Email: carecenter@cits.canon.com
Support options and hours of operation: www.usa.canon.com/support
