Cameras Menu
Lenses Menu
Video Menu
Ink, Toner & Paper Menu
Office Menu
Deals Menu
Office Product Deals
Support Menu
Shipping and Returns
Free Standard Shipping and Handling on Select Products
Offer valid November 2, 2026 12:05 a.m. ET through December 31, 2026 11:50 p.m. ET. Offer valid only on select products available for sale through the Canon online store. See product page for details. Offer not valid on bulk orders. Orders will be shipped to a street address in the 50 United States or the District of Columbia only. Free standard shipping and handling offer is a $5.99 to $15.99 Canon online store value. Offer subject to the Canon Terms of Sale. Dealers, distributors and other resellers are not eligible for this offer. Offer void where prohibited, taxed, or restricted.
Extended Returns
Purchases of eligible products made through the Canon online store only between November 2, 2026 and December 31, 2026 can be returned through January 15, 2027. Offer not valid on products that are considered final sale and/or not eligible for return.
Feature Notice: Possible Inaccurate Detection of the One-Touch Panel Open/Close Signal for the imageCLASS MF5960dn/MF5950dw/D1370/D1350
Update
We greatly appreciate your patronage of Canon products. We have become aware of a rare circumstance where a fax could be misdirected when the One-Touch Panel is used on the imageCLASS MF5960dn, imageCLASS MF5950dw, imageCLASS D1370, and imageCLASS D1350 products. This can occur when the Open/Close signal of the One-Touch panel is not accurately detected and therefore a fax may be sent to a different address than was intended. We offer our sincerest apologies to customers who may have been inconvenienced by this issue. Canon's quality management team has developed a firmware fix to ensure that all affected customers can continue using these products with confidence.
Phenomenon
When a One—Touch dial key is used to select the addressee, there is a slight possibility that a different addressee than the intended one could be selected. If the Start button is pushed without confirming the recipient visually on the control panel, the fax can be sent to an unintended addressee. This can occur when the Open/Close signal of the One-Touch panel is not accurately detected. For instance, if One-Touch dial key 01 is pushed, One-Touch dial key 08 (located in the same position as key 01 when One-Touch panel is opened) may be selected inadvertently as shown below in Figure 1.
Products
Affected Models
- imageCLASS MF5960dn
- imageCLASS MF5950dw
- imageCLASS D1370
- imageCLASS D1350
If you have one of the above listed models and the Panel firmware version on your machine is 02.49 or earlier, then your imageCLASS device may possibly be affected by this issue. Please confirm your Panel firmware version using the following procedure.
Procedure
Procedure to Verify Firmware Version on your Canon imageCLASS Product
- Push the [Report] button on the control panel.
- Select "Print Reports" and push [OK].
- Select "User Data List" and push [OK].
- Push [OK].
- Select "Yes" with left arrow key and push [OK].
Confirm the version of Panel firmware on the User Data List visually. If the Panel firmware version is 02.49 or earlier, please perform the firmware update. (Figure 2 below shows a version that requires the firmware update.) If the Panel version is 02.50 or later, there is no need to perform the firmware update, since the update has already been applied.
Countermeasure
The above phenomenon is eliminated by updating the firmware on your imageCLASSMF5960dn/MF5950dw/D1370/D1350 product. If the Panel firmware version is 02.49 or earlier, it is essential that you download the latest firmware for your imageCLASS model from the Canon USA website. To download the latest firmware, please use the links provided below for your specific imageCLASS model, then choose your Operating System and look in the > Firmware section.
If you need further assistance or have any questions, please contact the Canon USA Support Center at 1-800-OK-CANON (1-800-652-2666).
Thanks for signing up!
Footer
ABOUT CANON
MYCANON
ORDER HELP
PRODUCT RESOURCES
