Firmware Notice: DP-V2410: Firmware Version 1.5.1
Firmware Version 1.5.1 incorporates the following fix:
Fixes a frame delay issue that may occur when “Backlight Control” is set to “Off.”
Firmware Version 1.5.1 is for the DP-V2410 4K Reference Display running Firmware Version 1.5 and earlier. If the Reference Display's firmware is already version 1.5.1, it is not necessary to update the firmware.
Please note that Firmware Version 1.5.1 includes all the enhancements available in Firmware Version 1.5. The details of Firmware Version 1.5 are as follows.
  1. LUT files in .cube format can now be directly imported to the display unit.
  2. When outputting Canon Log video from a Cinema EOS camera*1 over SDI or HDMI, the display unit can now auto detect and display the color range (full or limited) matching the output video range (full range or narrow range).
  3. Added two LUTs to “CDL/User LUT” that convert video taken with RED Digital Cinema cameras to HDR (PQ) and SDR.
  4. Added a function to “Pixel Value Check” that indicates the xy chromaticity values of a specified pixel as well as its coordinate position on the chromaticity diagram.*2
  5. Added “Peak Range” to “Range Check” that highlights high-luminance range areas set with the normal “Over Range” setting.
  6. Errors detected by “Signal Monitoring” can now be exported as a log to USB memory sticks or other external memory devices. The error log is now preserved even after a power down-power up cycle.
  7. Changed the range of settings for the area size (width and height) and the area display position (horizontal and vertical) for the “Safety Zone Marker”. Also added “Box (Mask)” to the area shapes.
  8. Added “Area Marker 2”. It is now possible to set two area markers.
  9. Added 80% (UHD) – 95% (UHD) to the “Grid Marker” Interval setting.
  10. Added settings to adjust the channel order and display position on the “Audio Level Meter”.
  11. It is now possible to select and display 16:9 and 4:3 to match the aspect ratio when displaying SD-SDI signal video. Auto-detection and display with Payload ID is now also possible.
  12. The unit can now automatically detect and switch the display when the input signal switches between SD-SDI and HD-SDI.
  13. Added 10% and 5% to the display scaling options for HDR / SDR ratio graphs on the “Frame Luminance Monitor”.
  14. Improved web browser usability, including moving the position of the pixel value checker by click or touch on the View window during remote operation via Wi-Fi or LAN and allowing direct entry of values for the adjustment bar on the Control window.
  15. Added a setting to keep the unit button names continuously lit.
  16. Changed the behavior when using auto system gamma for Hybrid Log-Gamma (HLG).
  17. Added a power-save function.
*1 Cinema EOS camera models that permit Canon Log range selection
C500 Mark II / C300 Mark III (both SDI/HDMI are supported)
C700 / C700 GS / C700 FF (User LUT settings and SDI only)
(Current as of the end of May 2020)
*2 Only for the BT.2020 color gamut and a 1.0, 2.2, 2.35, 2.4, 2.6, PQ, or HLG (excluding HLG RGB) gamma curve.
Preparations for updating the firmware
It is recommended that current settings are exported before attempting to update the firmware. Once the firmware is updated, settings can be imported back to the display. The downloaded folder contains the new firmware. (Filename: "update_dpv2410.rom", file size: 25,438,809 bytes)It also contains the firmware update procedure document (multilingual PDF file in following languages: Japanese, English, French, German and Chinese (simplified characters).Before proceeding to update the firmware, please read the firmware update procedure document.
The following items are required to perform the firmware update:
  1. Display unit
  2. Personal computer
  3. USB memory (FAT16 or FAT32)
  4. Firmware (The downloaded file)
Support
Download Firmware Version 1.5.1 for the DP-V2410.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
If you have not already done so, please register your DP-V2410. By registering, we will be able to notify you via email about future announcements.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone: 1-800-OK-CANON
1-800-452-2666 / TDD: 1-855-270-3277
Email: Canon4K@cits.canon.com
Support options and hours of operation: www.usa.canon.com/support
