October 28, 2019
Mac OS X v10.15 Catalina
We have discovered some issues with the compatibility of Canon’s Camera Window DC, EOS Utility and Map Utility software programs with Mac OS X v10.15 Catalina that may cause certain functions of such Canon software not to work. Before upgrading your OS to Mac OS X 10.15 Catalina, please review the compatibility chart below
| Software | Latest Versions | Compatability | Support | Workaround |
| Digital Photo Professional | 3.14 | C | DPP 3.x cannot be used. | Install and use DPP 4.x. |
| 4.11.1 | A | Operated without seroius problems | ||
| EOS Utility | 3.11.1 | A | Operated without seroius problems | |
| 2.14.31.12 | B | (1)Even if a camera is connected, EOS Utility cannot be started (occurs only when it is being started for the first time). (2)When a camera is first connected, the camera may not be recognized. (3)The flash function setting values cannot be saved. (4)The custom white balance setting values cannot be saved. (5)The IPTC information registration settings cannot be saved. Aside from the above, the main functions can be used. | (1) Select [OK] for the dialog boxes when you start EOS Utility from the Dock. (2) Start the [Image Capture] application. By doing so, the connected camera can be accurately recognized. If the camera can be accurately recognized, [Image Capture] does not need to be started hereafter. (3), (4), (5) This phenomenon cannot be avoided. We are considering releasing a countermeasure version. | |
| GPS Log File Utility | 1.0.0 | B | A firmware update cannot be performed on the GP-E2. Countermeasures are under consideration. | This phenomenon cannot be avoided. We are considering releasing a countermeasure version. |
| Picture Style Editor | 1.22 | A | Operates without serious problem. | |
| Picture Style File Registration Tool | 1.0.0 | A | Operates without serious problem. | |
| Image Transfer Utility 1 | 1.2.5 | A | Operates without serious problem. | |
| Image Transfer Utility 2 | 2.1.0 | A | Operates without serious problem. | |
| Image Browser EX | 1.5.2 | C | Support discontinued | |
| Photo Stitch | 3.2.7 | C | Support discontinued | |
| Map Utility | 1.8.2 | C | Support discontinued | |
| Camera Window DC | 8.10.11a/ 8.10.11b | C | Support discontinued | |
| EOS Movie Utility | 1.7 | C | Support discontinued | |
| SELPHY CP Printer Driver | 6.9 | C | Support discontinued | |
| Canon XF Utility | 3.4.0 | A | Operates without serious problem. | |
| Canon XF Plugin for Avid Media Access | 3.4.1 | A | Operates without serious problem. | |
| Canon XF Plugin for Final Cut Pro X | 3.2.0 | A | Operates without serious problem. | |
| Cinema RAW Development | 2.3.1 | A | Operates without serious problem. | |
| Canon RAW Plugin for Avid Media Access | 2.2.1 | A | Operates without serious problem. | |
| Canon RAW Plugin for Final Cut Pro X | 1.1.2 | A | Operates without serious problem. | |
| MP4 Join Tool | 1.0.0 | A | Operates without serious problem. |
Details
A: The software is compatible with Mac OS X 10.15 Catalina.
B: The software has limited functionality with Mac OS X 10.15 Catalina.
C: The software is not compatible with Mac OS X 10.15 Catalina.
MORE SUPPORT
