Mac OS X Big Sur v11
We have discovered some issues with the compatibility of Canon's Camera Window DC, EOS Utility and Map Utility software programs with Mac OS X v11 Big Sure that may cause certain functions of such Canon software not to work. Before upgrading your OS to Mac OS X 11 Big Sure, please review the compatibility chart below.
Software |
Latest Versions |
Compatibility |
Support |
Workaround |
Digital Photo Professional |
3.14 |
C |
DPP 3.x cannot be used. |
Install and use DP 4.x. |
4.11.1 |
A |
Operated without serious problems |
EOS Utility |
3.11.1 |
A |
EOS Utility |
2.14.31.12 |
B |
(1) Even if a camera is connected, EOS Utility cannot be started (occurs only when it is being started for the first time). (4) The customer white balance setting values cannot be saved. |
(1) Select [OK] for the dialog boxes when you start EOS Utility from the Dock. |
GPS Log File Utility |
1.0.0 |
B |
A firmware update cannot be performed on the GP-E2. Countermeasures are under consideration. |
This phenomenon cannot be avoided. We are considering releasing a countermeasure version. |
Picture Style Editor |
1.22 |
A |
Operates without serious problem. |
Picture Style File Registration Tool |
1.0.0 |
A |
Image Transfer Utility 1 |
1.2.5 |
A |
Image Transfer Utility 2 |
2.1.0 |
A |
Image Browser EX |
1.5.2 |
C |
Support discontinued |
Photo Stitch |
3.2.7 |
C |
Map Utility |
1.8.2 |
C |
Camera Window DC |
8.10.11a/ 8.10.11b |
C |
EOS Movie Utility |
1.7 |
C |
SELPHY CP Printer Driver |
6.9 |
C |
Canon XF Utility |
3.4.0 |
A |
Operated without serious problem. |
Canon XF Plugin for Avid Media Access |
3.4.1 |
A |
Canon XF Plugin for Final Cut Pro X |
3.2.0 |
A |
Cinema RAW Development |
2.3.1 |
A |
Canon RAW Plugin for Avid Media Access |
2.2.1 |
A |
Canon RAW Plugin for Final Cut Pro X |
1.1.2 |
A |
Operates within serious problem. |
MP4 Join Tool |
1.0.0 |
A |
Details
B: The software has limited functionality with Mac OS X 11 Big Sur.
C: The software is not compatible with Mac OS X 11 Big Sur.
