Mac OS X v10.15 Sierra
We have discovered some issues with the compatibility of Canon’s Camera Window DC, EOS Utility and Map Utility software programs with Mac OS X v10.15 Sierra that may cause certain functions of such Canon software not to work. Before upgrading your OS to Mac OS X 10.15 Sierra, please review the compatibility chart below
Software |
Latest Versions |
Compatibility |
Support |
Workaround |
Digital Photo Professional |
3.14 |
C |
DPP 3.x cannot be used. |
Install and use DP 4.x. |
4.11.1 |
A |
Operated without serious problems |
EOS Utility |
3.11.1 |
A |
EOS Utility |
2.14.31.12 |
B |
(1) Even if a camera is connected, EOS Utility cannot be started (occurs only when it is being started for the first time). (4) The customer white balance setting values cannot be saved. |
(1) Select [OK] for the dialog boxes when you start EOS Utility from the Dock. |
GPS Log File Utility |
1.0.0 |
B |
A firmware update cannot be performed on the GP-E2. Countermeasures are under consideration. |
This phenomenon cannot be avoided. We are considering releasing a countermeasure version. |
Picture Style Editor |
1.22 |
A |
Operates without serious problem |
Picture Style File Registration Tool |
1.0.0 |
A |
Image Transfer Utility 1 |
1.2.5 |
A |
Image Transfer Utility 2 |
2.1.0 |
A |
Image Browser EX |
1.5.2 |
C |
Support discontinued |
Photo Stitch |
3.2.7 |
C |
Map Utility |
1.8.2 |
C |
Camera Window DC |
8.10.11a/ 8.10.11b |
C |
EOS Movie Utility |
1.7 |
C |
SELPHY CP Printer Driver |
6.9 |
C |
Canon XF Utility |
3.4.0 |
A |
Operated without serious problem |
Canon XF Plugin for Avid Media Access |
3.4.1 |
A |
Canon XF Plugin for Final Cut Pro X |
3.2.0 |
A |
Cinema RAW Development |
2.3.1 |
A |
Canon RAW Plugin for Avid Media Access |
2.2.1 |
A |
Canon RAW Plugin for Final Cut Pro X |
1.1.2 |
A |
Operates within serious problem |
MP4 Join Tool |
1.0.0 |
A |
EOS Utility Compatibility Chart
| Importing Images | Remote Shooting | Camera Setting | Acquiring GPS log (GPS-enabled camera only) | Web link setting | Lens data registration | Picture Style File Registration | Firmware Update | ||||||||||
| Software | Model | USB | Wi-Fi | USB | Wi-Fi | USB | Wi-Fi | USB | Wi-Fi | USB | Wi-Fi | USB | Wi-Fi | USB | Wi-Fi | USB | Wi-Fi |
| EOS Utility 3 | DSLR*1 | B | A | B | A | B | A | B | A | B | A | B | A | B | A | B | A |
| EOS Utility 3 | DSLR*2 | B | A | B | A | B | A | B | A | B | A | B | A | B | A | B | A |
| EOS Utility 3 | EOS M3 / EOS M10 | B | A | B | A | B | A | B | A | B | A | B | A | B | A | B | A |
| EOS Utility 2 | DSLR*3 | B | A | B | A | B | A | B | A | B | A | B | A | B | A | B | A |
| EOS Utility 2 | EOS M | B | A | B | A | B | A | B | A | B | A | B | A | B | A | B | A |
Details
A: The software is compatible with Mac OS X 10.15 Sierra.
B: The software has limited functionality with Mac OS X 10.15 Sierra.
C: The software is not compatible with Mac OS X 10.15 Sierra.
*1 EOS-1D X Mark II, EOS 5D Mark IV, EOS 80D
*2 EOS-1D C, EOS-1D X, EOS 5D Mark III, EOS 5DS, EOS 5DSR, EOS 6D, EOS 7D Mark II, EOS Rebel T6s, EOS Rebel T6i, EOS Rebel T6
*3 EOS 40D, EOS 50D, EOS 5D Mark II, EOS 5D Mark III, EOS 60D, EOS 60Da, EOS 6D, EOS 70D, EOS 7D, EOS 7D Mark II, EOS Rebel XS, EOS Rebel XSi, EOS Rebel T1i, EOS Rebel T2i, EOS Rebel T3i, EOS Rebel T3, EOS Rebel T4i, EOS Rebel T5, EOS Rebel T5i, EOS Rebel SL1, EOS-1D C, EOS-1D Mark III, EOS-1D Mark IV, EOS-1D X, EOS-1Ds Mark III
