Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 01.26.16
File Size 8.06 MB
Date 01.26.16
File Size 5.81 MB
Pan-Tilt Section:
Operation Condition Outdoors
Operation Angle Panning: 340°, tilting + 30°, -50°
Operation Speed Panning: 0.5° - 25°/s, Tilting: 0.3° - 20°/s
Repeatability Less than +/- 10 arc degrees
Wiper Provided as a standard accessory
Washer Control terminal provided (pedestal unit)
MIC input Yes, pedestal section
Connector Receptacle DC terminal, Control (RS-422), SDI out, SD composite, Genlock, Aux out
Video output HD-SDI/SD-SDI Embedded audio output
BNC1Line (receptacle section)
SD Composite (NTSC/PAL) output
BNC1 Line (receptacle section)
GENLOCK input BNC 1 Line (receptacle section) (3value/BB)
Operating temperature Ambient - 15 , 40°C / Less than 90% humidity (Without condensation)
Wind Velocity-Resistance 0,25m/s Normal operation
25 , 40m/s Operation possible*
40 , 60m/s Non destruction
Noise Less than NC55
Power Source 10.5 to 15 V DC, 80 W
Dustproof waterproof efficiency IP45
Size (Including Camera & Lens) 318.5(W) x 390 (H) x 386 (D) mm
Mass (Including Camera & Lens) Approx. 17kg
*Some functions may be limited depending on operating environment.
Camera & Lens:
Image Sensor 1/3" 3CMOS
No. of Effective Pixels 2.07 megapixels (total no. of pixels: 2.37 megapixels)
Lens 4.1 to 73.8 mm, F1.6 to 2.8, approx. 7.4 to 134 mm (2/3" equivalent), 18x optical zooming, 1.5x digital extender
Focusing system AUTO, Manual
IRIS AUTO, Manual
Lowest Subject Brightness 0.08 lux (under F1.6, +33 dB, 1/4 shutter speed conditions)
Gain AUTO, 0dB, 6dB, 12dB, 18dB, 33dB
ND Filter 1/1, 1/4, 1/16, 1/64 (4 positions)
White balance AUTO, Set
Picture Quality Adjustments White balance, master pedestal, R-Gain, B-Gain, G-Gain, hue, master black (R/G/B), setup level, gamma, knee, sharpness, knee aperture, skin detail, color matrix, horizontal detail frequency
GENLOCK
Phase adjustment
Adjustment range approximately ±0.4H
Image Stabilizer Optical Shift method
* Suffix 1A corresponds to NTSC, 2A corresponds to PAL
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
