Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Product
Product Category ENG Lens
Product Series CJ14ex4.3B
Image Composition
Object Image Format 2/3 inch
Aspect Ratio 16:9
Zoom Ratio 14X
Focal Length Range 4.3 , 60 mm
Focal Length Range with Extender 8.6 , 120 mm (with 2x Extender)
Angular Field of View 96.3&deg; x 64.2&deg; at 4.3mm
9.1&deg; x 5.2&deg; at 60mm
Angular Field of View with Extender 58.3&deg; x 34.9&deg; at 8.6mm (with 2x Extender)
4.6&deg; x 2.6&deg; at 120mm (with 2x Extender)
Optical Brightness
Maximum Relative Aperture (F-Number) 1:1.8 at 4.3 - 40 mm
1:2.7 at 60 mm
Maximum Relative Aperture (F-Number) with Extender 1:3.6 at 8.6 - 80 mm
1:5.4 at 120 mm (with 2x Extender)
Scene Composition
MOD From Front of Lens 0.30 Meter
Scene Object Dimensions at MOD 76.4 x 43.0 cm at 4.3 mm
5.2 x 2.9 cm at 60 mm
Scene Object Dimensions at MOD with Extender 38.2 x 21.5 cm at 8.6 mm
2.6 x 1.5 cm at 120 mm
Physical Attributes
Width 6.4in (163.5mm)
Height 4.3in (108.0mm)
Dimensions 9.8in (247.8mm)
Weight 4.7 lbs. (2.11 kg)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
