Canon Support for Color imageCLASS LBP622Cdw | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Products ChromeOS
Color imageCLASS LBP622Cdw Spec Sheet
MAIN UNIT
CORE FUNCTIONS
Print
ITEM CODE
3104C005
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5-line LCD
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
250 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 1-sheet Stack Bypass
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
75 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (10 Envelopes)
Manual Feed Slot: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (1 Envelope)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive,
Envelope: COM10, Monarch, C5, DL,
Custom (Min. 3" x 5" to Max. 8.5" x 14")
Manual Feed Slot: Letter, Legal, Statement, Executive
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
Manual Feed Slot: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
WARM-UP TIME
From Power On: 13 Seconds or Less;
From Sleep Mode: 6.1 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 17.2" x 16.7" x 11.5" (437 mm x 425 mm x 292 mm)
Box: 21.8" x 22.2" x 15" (553 mm x 564 mm x 381 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 17.0" x 40.0" x 11.3" (430 mm x 1011 mm x 287 mm)
WEIGHT2
Unit: Approx. 35.2 lb. (16.0 kg)
Boxed Weight: Approx. 41.8 lb. (19.0 kg)
SUPPORTED OS
Windows 7/ Windows 8.1/ Windows 10/ Windows Server 2008/ Windows Server 2008 R2/ Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X v10.9.5 (or later)
WHAT COMES IN THE BOX
LBP622Cdw Product, Cartridge 054 CMY Starter: 680 Yield/Black Starter: 910 Yield, Power Cord, Starter Guide, User Software DVD-ROM, Warranty Card3
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED4
Up to 22 ppm (Letter); Up to 17.9 ppm (Legal)
FIRST PRINT-OUT TIME
Approx. 10.3 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
150 - 2,500 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II
DOUBLE-SIDED PRINTING
Automatic (Standard)
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1
Apple® AirPrint,® Canon PRINT Business, Mopria™ Print
Service
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
NETWORK
Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication before SMTP
DOCUMENT
Standard: Secure Print
WI-FI® AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES) WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 900 W
Standby: Approx. 7.9 W
Sleep Mode: Approx. 0.7 W
Typical Electricity Consumption (TEC) Rating: 0.21 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver2
FOOTNOTES
1 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
2 For current EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
3 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
4 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
Title Regarding Vulnerability Against Buffer Overflow for Canon Laser Printer and Small Office Multifunctional Printers
Date 11.18.22
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
Title Service Notice: Vulnerability Mitigation/Remediation for Small Office Multifunctional Printers and Laser Printers
Date 03.15.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
