Canon Support for Color imageCLASS MF641Cw | Canon U.S.A., Inc.
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
Color imageCLASS MF641Cw Spec Sheet
Color imageCLASS MF641Cw | |
MAIN UNIT | |
CORE FUNCTIONS | Print, Copy, Scan, Send (Lite) |
ITEM CODE | 3102C019 |
PROCESSOR | Canon Custom Processor |
CONTROL PANEL | 5" Color Touch Panel |
MEMORY | 1 GB |
STANDARD INTERFACE CONNECTION | USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection |
PAPER CAPACITY (LETTER, 20 LB. BOND) | 250 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 250-sheet Paper Cassette, 1-sheet Stack Bypass |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | 75 Sheets |
SUPPORTED MEDIA TYPES | Cassettes: Thin, Plain, Recycled, Color, Thick, Coated, |
SUPPORTED MEDIA SIZES | Cassettes: Letter, Legal, Statement, Executive |
SUPPORTED MEDIA WEIGHTS | Cassettes: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2) |
WARM-UP TIME | From Power On: 13 Seconds or Less; |
DIMENSIONS (W x D x H) | Standard (Desktop): 16.9" x 16.5" x 14.3" (429 mm x 419 mm x 363 mm) |
INSTALLATION SPACE (W x D x H) | Standard (Desktop): 17.8" x 33.3" x 26.8" (451 mm x 847 mm x 681 mm) |
WEIGHT3 | Unit: Approx. 39.6 lb. (18 kg) |
SUPPORTED OS | Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X v10.9.5 (or later) |
WHAT COMES IN THE BOX | MF641Cw Product, Cartridge 054 CMY Starter: 680 Yield/Black Standard: 1,500 Yield, Power Cord, Starter Guide, User Software DVD-ROM, Warranty Card5 |
PRINT SPECIFICATIONS | |
PRINTING METHOD | Laser Beam Printing |
PRINT SPEED4 | Up to 18 ppm (Letter/Legal) |
FIRST PRINT-OUT TIME | Approx. 10.3 Seconds |
RECOMMENDED MONTHLY PAGE VOLUME | 150 - 2,500 Pages |
PRINT RESOLUTION (dpi) | 600 x 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II |
DIRECT PRINT | Available from USB Memory (JPEG, TIFF, PDF) |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1 | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print |
COPY SPECIFICATIONS | |
COPY SPEED | Up to 18 ppm (Letter/Legal) |
FIRST COPY-OUT TIME (LETTER) | Platen: 11.2 seconds/13.1 seconds (BW/Color) |
COPY RESOLUTION (dpi) | 600 x 600 |
COPY SIZE | Platen: Up to Letter |
MULTIPLE COPIES | Up to 999 Copies |
MAGNIFICATION | 25% - 400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 78% |
PRESET ENLARGEMENTS | 129%, 200%, 400% |
COPY FEATURES | Paper Setting, Favorite Setting, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
SCAN SPECIFICATIONS | |
TYPE | Color Contact Image Sensor |
SCAN SIZE | Platen: Up to Letter |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book |
PULL SCAN | ScanGear MF for TWAIN, and WIA |
SCAN RESOLUTION (dpi) | 300 x 600, 600 x 600 |
SCAN TO MOBILE DEVICES | Canon PRINT Business |
MEMORY MEDIA | Standard USB Memory (JPEG, TIFF, PDF) |
SEND SPECIFICATIONS | |
DESTINATION | Email/Internet FAX (SMTP), SMB, FTP |
ADDRESS BOOK | LDAP (50)/Local (300)/Speed Dial (281) |
SEND RESOLUTION (dpi) | 600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other) |
COMMUNICATION PROTOCOL | File: FTP, SMB |
FILE FORMAT | Standard: TIFF, JPEG, PDF (Compact, Searchable) |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Department ID Authentication |
NETWORK | Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication before SMTP |
DOCUMENT | Standard: Secure Print |
WI-FI® AUTHENTICATION METHODS | Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES) WPA2-PSK (AES) |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86º F; |
POWER REQUIREMENTS | AC 120-127 V:6.5 A, 60 Hz |
POWER CONSUMPTION | Maximum: Approx. 900 W |
STANDARDS | ENERGY STAR® Qualified, Rated EPEAT Silver2 |
FOOTNOTES | |
1 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information. |
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
